[GRASS-SVN] r35803 - in grass/branches/develbranch_6/gui/wxpython:
gui_modules vdigit
svn_grass at osgeo.org
Sun Feb 8 09:49:46 EST 2009
Author: martinl
Date: 2009-02-08 09:49:46 -0500 (Sun, 08 Feb 2009)
New Revision: 35803
grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
grass/branches/develbranch_6/gui/wxpython/vdigit/digit.cpp
grass/branches/develbranch_6/gui/wxpython/vdigit/digit.h
grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp
grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h
grass/branches/develbranch_6/gui/wxpython/vdigit/pseudodc.i
wxGUI: use local pseudoDC class (if not available switch to wx.PseudoDC)
(merge from trunk, r35802)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py 2009-02-08 14:43:28 UTC (rev 35802)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py 2009-02-08 14:49:46 UTC (rev 35803)
@@ -33,6 +33,7 @@
from vdigit import VDigitCategoryDialog
from vdigit import VDigitZBulkDialog
from vdigit import VDigitDuplicatesDialog
+from vdigit import PseudoDC
class MapWindow(object):
@@ -217,13 +218,13 @@
### self.OnSize(None)
# create PseudoDC used for background map, map decorations like scales and legends
- self.pdc = wx.PseudoDC()
+ self.pdc = PseudoDC()
# used for digitization tool
self.pdcVector = None
# decorations (region box, etc.)
- self.pdcDec = wx.PseudoDC()
+ self.pdcDec = PseudoDC()
# pseudoDC for temporal objects (select box, measurement tool, etc.)
- self.pdcTmp = wx.PseudoDC()
+ self.pdcTmp = PseudoDC()
# redraw all pdc's, pdcTmp layer is redrawn always (speed issue)
self.redrawAll = True
@@ -283,8 +284,8 @@
if pdctype == 'image': # draw selected image
bitmap = wx.BitmapFromImage(img)
w,h = bitmap.GetSize()
- pdc.DrawBitmap(bitmap, coords[0], coords[1], True) # draw the composite map
- pdc.SetIdBounds(drawid, (coords[0],coords[1], w, h))
+ pdc.DrawBitmap(bitmap, wx.Point(coords[0], coords[1]), True) # draw the composite map
+ pdc.SetIdBounds(drawid, wx.Rect(coords[0],coords[1], w, h))
elif pdctype == 'box': # draw a box on top of the map
if self.pen:
@@ -298,22 +299,30 @@
rheight = y2-y1
rect = wx.Rect(x1,y1,rwidth,rheight)
pdc.DrawRectangleRect(rect)
- pdc.SetIdBounds(drawid,rect)
+ pdc.SetIdBounds(drawid, rect)
# self.ovlcoords[drawid] = coords
elif pdctype == 'line': # draw a line on top of the map
if self.pen:
pdc.SetBrush(wx.Brush(wx.CYAN, wx.TRANSPARENT))
pdc.SetPen(self.pen)
- pdc.DrawLine(coords[0], coords[1], coords[2], coords[3])
- pdc.SetIdBounds(drawid,(coords[0], coords[1], coords[2], coords[3]))
+ pdc.DrawLine(wx.Point(coords[0], coords[1]),
+ wx.Point(coords[2], coords[3]))
+ pdc.SetIdBounds(drawid, wx.Rect(coords[0], coords[1], coords[2], coords[3]))
elif pdctype == 'polyline': # draw a polyline on top of the map
if self.polypen:
pdc.SetPen(self.polypen)
- pdc.DrawLines(coords)
+ ### pdc.DrawLines(coords)
+ if (len(coords) < 2):
+ return
+ i = 1
+ while i < len(coords):
+ pdc.DrawLine(wx.Point(coords[i-1][0], coords[i-1][1]),
+ wx.Point(coords[i][0], coords[i][1]))
+ i += 1
# get bounding rectangle for polyline
xlist = []
@@ -327,7 +336,7 @@
x2=max(xlist)
y1=min(ylist)
y2=max(ylist)
- pdc.SetIdBounds(drawid,(x1,y1,x2,y2))
+ pdc.SetIdBounds(drawid, wx.Rect(x1,y1,x2,y2))
# self.ovlcoords[drawid] = [x1,y1,x2,y2]
elif pdctype == 'point': # draw point
@@ -338,7 +347,7 @@
coords[1] - 5,
coords[0] + 5,
coords[1] + 5)
- pdc.SetIdBounds(drawid, coordsBound)
+ pdc.SetIdBounds(drawid, wx.Rect(coordsBound))
elif pdctype == 'text': # draw text on top of map
@@ -356,7 +365,7 @@
pdc.DrawText(img['text'], coords[0], coords[1])
else:
pdc.DrawRotatedText(img['text'], coords[0], coords[1], rotation)
- pdc.SetIdBounds(drawid, (coords[0], coords[1], w, h))
+ pdc.SetIdBounds(drawid, wx.Rect(coords[0], coords[1], w, h))
pdc.EndDrawing()
@@ -462,8 +471,8 @@
# self.bufferLast = wx.BitmapFromImage(self.buffer.ConvertToImage())
self.bufferLast = dc.GetAsBitmap(wx.Rect(0, 0, self.Map.width, self.Map.height))
- pdcLast = wx.PseudoDC()
- pdcLast.DrawBitmap(bmp=self.bufferLast, x=0, y=0)
+ pdcLast = PseudoDC()
+ pdcLast.DrawBitmap(self.bufferLast, wx.Point(0, 0), False)
pdcLast.DrawToDC(dc)
# draw decorations (e.g. region box)
@@ -895,7 +904,6 @@
pass
self.RefreshRect(r, False)
pdc.SetId(self.lineid)
self.Draw(pdc, drawid=self.lineid, pdctype='line', coords=mousecoords)
def DrawLines(self, pdc=None, polycoords=None):
@@ -1380,7 +1388,7 @@
self.OnLeftDownVDigitCopyCA(event)
elif digitToolbar.GetAction() == "copyLine":
- self.OnLeftDownCopyLine(event)
+ self.OnLeftDownVDigitCopyLine(event)
elif digitToolbar.GetAction() == "zbulkLine":
self.OnLeftDownVDigitBulkLine(event)
@@ -1580,6 +1588,9 @@
digitToolbar = self.parent.toolbars['vdigit']
digitClass = self.parent.digit
+ pos1 = self.Pixel2Cell(self.mouse['begin'])
+ pos2 = self.Pixel2Cell(self.mouse['end'])
if UserSettings.Get(group='vdigit', key='bgmap',
subkey='value', internal=True) == '':
# no background map -> copy from current vector map layer
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py 2009-02-08 14:43:28 UTC (rev 35802)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py 2009-02-08 14:49:46 UTC (rev 35803)
@@ -57,7 +57,7 @@
digitErr = ''
except ImportError, err:
GV_LINES = None
- PseudoDC = None
+ PseudoDC = wx.PseudoDC
digitErr = err
print >> sys.stderr, "%sWARNING: Digitization tool is disabled (%s). " \
"Detailed information in README file." % \
Modified: grass/branches/develbranch_6/gui/wxpython/vdigit/digit.cpp
--- grass/branches/develbranch_6/gui/wxpython/vdigit/digit.cpp 2009-02-08 14:43:28 UTC (rev 35802)
+++ grass/branches/develbranch_6/gui/wxpython/vdigit/digit.cpp 2009-02-08 14:49:46 UTC (rev 35803)
@@ -23,10 +23,10 @@
\param driver display driver instance
\param window parent window for message dialog
-Digit::Digit(DisplayDriver *ddriver, void *window)
+Digit::Digit(DisplayDriver *ddriver, wxWindow *window)
display = ddriver;
- display->parentWin = (wxWindow *) window;
+ display->parentWin = window;
if (display->mapInfo) {
InitCats();
Modified: grass/branches/develbranch_6/gui/wxpython/vdigit/digit.h
--- grass/branches/develbranch_6/gui/wxpython/vdigit/digit.h 2009-02-08 14:43:28 UTC (rev 35802)
+++ grass/branches/develbranch_6/gui/wxpython/vdigit/digit.h 2009-02-08 14:49:46 UTC (rev 35803)
@@ -44,7 +44,7 @@
int RemoveActionFromChangeset(int, action_type, int);
public:
- Digit(DisplayDriver *, void *);
+ Digit(DisplayDriver *, wxWindow *);
~Digit();
int InitCats();
Modified: grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp
--- grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp 2009-02-08 14:43:28 UTC (rev 35802)
+++ grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp 2009-02-08 14:49:46 UTC (rev 35803)
@@ -30,14 +30,14 @@
\return
-DisplayDriver::DisplayDriver(void *device, void *deviceTmp)
+DisplayDriver::DisplayDriver(gwxPseudoDC *device, gwxPseudoDC *deviceTmp)
G_gisinit(""); /* GRASS functions */
mapInfo = NULL;
- dc = (gwxPseudoDC *) device;
- dcTmp = (gwxPseudoDC *) deviceTmp;
+ dc = device;
+ dcTmp = deviceTmp;
points = Vect_new_line_struct();
pointsScreen = new wxList();
Modified: grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h
--- grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h 2009-02-08 14:43:28 UTC (rev 35802)
+++ grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h 2009-02-08 14:49:46 UTC (rev 35803)
@@ -175,7 +175,7 @@
public:
/* constructor */
- DisplayDriver(void *, void *);
+ DisplayDriver(gwxPseudoDC *, gwxPseudoDC *);
/* destructor */
~DisplayDriver();
Modified: grass/branches/develbranch_6/gui/wxpython/vdigit/pseudodc.i
--- grass/branches/develbranch_6/gui/wxpython/vdigit/pseudodc.i 2009-02-08 14:43:28 UTC (rev 35802)
+++ grass/branches/develbranch_6/gui/wxpython/vdigit/pseudodc.i 2009-02-08 14:49:46 UTC (rev 35803)
@@ -1,4 +1,3 @@
#include <wx/wxPython/wxPython.h>
#include <wx/wxPython/pyclasses.h>
@@ -20,8 +19,19 @@
gwxPseudoDC();
~gwxPseudoDC();
void Clear();
+ void ClearId(int);
void RemoveAll();
- void RemoveId(int id);
+ void RemoveId(int);
+ void BeginDrawing();
+ void EndDrawing();
+ void SetBackground(const wxBrush&);
+ void SetId(int);
+ void DrawBitmap(const wxBitmap&, const wxPoint&,
+ bool);
+ void SetBrush(const wxBrush&);
+ void SetPen(const wxPen&);
+ void SetIdBounds(int, wxRect&);
+ void DrawLine(const wxPoint&, const wxPoint&);
%extend {
void DrawToDC(void *dc) {
self->DrawToDC((wxDC *) dc);
@@ -34,6 +44,8 @@
self->GetIdBounds(id, rect);
return rect;
+ void TranslateId(int id, int dx, int dy) {
+ self->TranslateId(id, (wxCoord) dx, (wxCoord) dy);
