[GRASS-SVN] r35817 - grass/trunk/raster/r.surf.contour
svn_grass at osgeo.org
Sun Feb 8 20:20:12 EST 2009
Author: hamish
Date: 2009-02-08 20:20:12 -0500 (Sun, 08 Feb 2009)
New Revision: 35817
grass/trunk/raster/r.surf.contour/contour.h
grass/trunk/raster/r.surf.contour/main.c
remove unused code
Modified: grass/trunk/raster/r.surf.contour/contour.h
--- grass/trunk/raster/r.surf.contour/contour.h 2009-02-08 22:24:47 UTC (rev 35816)
+++ grass/trunk/raster/r.surf.contour/contour.h 2009-02-09 01:20:12 UTC (rev 35817)
@@ -27,7 +27,6 @@
extern CELL **con;
extern FLAG *seen, *mask;
extern NODE *zero;
-extern CELL on, off;
/* add_in.c */
NODE *add_in(int, int, int, int, NODE *, int *);
Modified: grass/trunk/raster/r.surf.contour/main.c
--- grass/trunk/raster/r.surf.contour/main.c 2009-02-08 22:24:47 UTC (rev 35816)
+++ grass/trunk/raster/r.surf.contour/main.c 2009-02-09 01:20:12 UTC (rev 35817)
@@ -38,8 +38,8 @@
CELL **con;
FLAG *seen, *mask;
NODE *zero;
-CELL on, off;
int main(int argc, char *argv[])
int r, c;
@@ -51,9 +51,9 @@
CELL value;
struct History history;
struct GModule *module;
- struct Flag *flag1;
struct Option *opt1, *opt2;
G_gisinit(argv[0]);
module = G_define_module();
@@ -75,17 +75,10 @@
opt2->gisprompt = "new,cell,raster";
opt2->description = _("Output elevation raster map");
- flag1 = G_define_flag();
- flag1->key = 'f';
- flag1->description = _("Unused; retained for compatibility purposes, "
- "will be removed in future");
- on = 1;
- off = 0;
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
con_name = opt1->answer;
alt_name = opt2->answer;
