[GRASS-SVN] r35826 -
grass/branches/releasebranch_6_4/scripts/v.colors
svn_grass at osgeo.org
Mon Feb 9 08:06:52 EST 2009
Author: neteler
Date: 2009-02-09 08:06:52 -0500 (Mon, 09 Feb 2009)
New Revision: 35826
grass/branches/releasebranch_6_4/scripts/v.colors/description.html
example cosmetics
Modified: grass/branches/releasebranch_6_4/scripts/v.colors/description.html
--- grass/branches/releasebranch_6_4/scripts/v.colors/description.html 2009-02-09 13:06:32 UTC (rev 35825)
+++ grass/branches/releasebranch_6_4/scripts/v.colors/description.html 2009-02-09 13:06:52 UTC (rev 35826)
@@ -32,22 +32,40 @@
v.db.addtable map=rand5k_elev column='elevation double precision'
v.what.rast vector=rand5k_elev raster=elevation.10m column=elevation
v.colors map=rand5k_elev column=elevation color=bcyr
+# display colorized points map
d.mon x0
d.vect -a rand5k_elev
</pre></div>
+<p>
+Colorizing the roads map in Spearfish:
+<div class="code"><pre>
+g.copy vect=roads,myroads
+echo "1 red
+2 yellow
+3 orange
+4 black
+5 grey" > colors.txt
+v.colors myroads column=cat rules=colors.txt
+# display colorized roads map
+d.mon x0
+d.vect -a myroads
+</pre></div>
<P>
+Colorizing a TIN (polygons) generated by <em>v.delaunay</em>:
-Colorizing a TIN generated by <em>v.delaunay</em>:
# new columns for x,y,z of centroids
v.db.addtable map=tin \
columns="east double precision, north double precision, height double precision, GRASSRGB varchar(11)"
# transfer geometry for colorizing (we need the centroid height)
-v.to.db tin opt=coor col="east,north,height"
+v.to.db tin option=coor columns="east,north,height"
v.db.select tin
v.colors tin column=height rgb_column=GRASSRGB color=rainbow
@@ -57,23 +75,7 @@
d.vect -a tin
</pre></div>
-<p>
-Colorizing the roads map in Spearfish:
-<div class="code"><pre>
-g.copy vect=roads,myroads
-echo "1 red
-2 green
-3 blue
-4 orange
-5 purple" > colors.txt
-v.colors myroads column=cat rules=colors.txt
-# display colorized roads map
-d.mon x0
-d.vect -a myroads
-</pre></div>
<H2>SEE ALSO</H2>
<EM>
