[GRASS-SVN] r35840 - grass/branches/develbranch_6/imagery/i.atcorr
svn_grass at osgeo.org
Tue Feb 10 08:36:32 EST 2009
Author: neteler
Date: 2009-02-10 08:36:32 -0500 (Tue, 10 Feb 2009)
New Revision: 35840
grass/branches/develbranch_6/imagery/i.atcorr/Iwave.cpp
code layout cosmetics
Modified: grass/branches/develbranch_6/imagery/i.atcorr/Iwave.cpp
--- grass/branches/develbranch_6/imagery/i.atcorr/Iwave.cpp 2009-02-10 13:36:26 UTC (rev 35839)
+++ grass/branches/develbranch_6/imagery/i.atcorr/Iwave.cpp 2009-02-10 13:36:32 UTC (rev 35840)
@@ -9,6 +9,16 @@
#ifdef WIN32
#pragma warning(disable:4305) /* disable warning about initialization of a float by a double */
#endif
+/* Adding new band filters:
+ * o bands are defined by their discrete filter function
+ * o 1500 is the number of wavelength spectral description slots.
+ * - a 'for' loop fills up the slots with 0
+ * - then the ffu.s array is filled with each of the spectral bands data one after the other.
spectral band of meteosat
@@ -67,7 +77,7 @@
int i;
for(i = 0; i < 40; i++) ffu.s[0] = 0;
for(i = 0; i < 305; i++) ffu.s[40+i] = sr[i];
- for(i = 345; i < 1501; i++)ffu.s[i] = 0;
+ for(i = 345; i < 1501; i++) ffu.s[i] = 0;
@@ -103,7 +113,7 @@
ffu.wlinf = 0.49f;
ffu.wlsup = 0.8999999f;
int i = 0;
- for(i = 0; i < 96; i++) ffu.s[i] = 0;
+ for(i = 0; i < 96; i++) ffu.s[i] = 0;
for(i = 0; i < 165; i++) ffu.s[96+i] = sr[i];
for(i = 261; i < 1501; i++) ffu.s[i] = 0;
@@ -141,7 +151,7 @@
ffu.wlinf = 0.49f;
int i = 0;
@@ -577,7 +587,7 @@
switch(iwa)
- case 1: for(i = 0; i < 80; i++) ffu.s[120+i] = sr1[i];
+ case 1: for(i = 0; i < 80; i++) ffu.s[120+i] = sr1[i];
break;
case 2: for(i = 0; i < 173; i++) ffu.s[176+i] = sr2[i];
break;
@@ -754,7 +764,7 @@
break;
case 3: for(i = 0; i < 81; i++) ffu.s[192+i] = sr3[i];
break;
- case 4: for(i = 0; i < 129; i++) ffu.s[88+i] = sr4[i];
+ case 4: for(i = 0; i < 129; i++) ffu.s[88+i] = sr4[i];
break;
case 5: for(i = 0; i < 73; i++) ffu.s[88+i] = sr5[i];
break;
@@ -762,7 +772,7 @@
break;
case 7: for(i = 0; i < 81; i++) ffu.s[196+i] = sr7[i];
break;
- case 8: for(i = 0; i < 129; i++) ffu.s[88+i] = sr8[i];
+ case 8: for(i = 0; i < 129; i++) ffu.s[88+i] = sr8[i];
break;
@@ -893,9 +903,9 @@
break;
case 4: for(i = 0; i < 89; i++) ffu.s[192+i] = sr4[i];
break;
- case 5: for(i = 0; i < 156; i++) ffu.s[501+i] = sr5[i];
+ case 5: for(i = 0; i < 156; i++) ffu.s[501+i] = sr5[i];
break;
- case 6: for(i = 0; i < 185; i++) ffu.s[680+i] = sr6[i];
+ case 6: for(i = 0; i < 185; i++) ffu.s[680+i] = sr6[i];
break;
@@ -908,7 +918,7 @@
.09, .13, .21, .29, .45, .61, .72,
.82, .85, .89, .92, .95, .96, .98,
.99, .99, 1.00, 1.00, 1.00, 1.00, 1.00,
- 1.00, 1.00, .99, .99, .98, .98, .98,
+ 1.00, 1.00, .99, .99, .98, .98, .98,
.97, .97, .96, .96, .96, .96, .95,
.95, .93, .91, .89, .87, .85, .82,
.73, .65, .54, .43, .38, .33, .24,
@@ -936,7 +946,7 @@
.03, .03, .05, .07, .10, .14, .17,
.20, .31, .41, .48, .56, .66, .75,
.83, .90, .93, .97, .98, .99, 1.00,
- 1.00, 1.00, .99, .99, .98, .97, .96,
+ 1.00, 1.00, .99, .99, .98, .97, .96,
.94, .93, .90, .88, .87, .86, .84,
.83, .82, .82, .82, .82, .82, .83,
.83, .83, .83, .83, .81, .80, .78,
@@ -952,7 +962,7 @@
.45, .68, .76, .83, .89, .94, .94,
.94, .94, .95, .95, .96, .97, .98,
- 1.00, 1.00, .99, .98, .97, .96, .95,
+ 1.00, 1.00, .99, .98, .97, .96, .95,
.94, .93, .92, .92, .91, .90, .89,
.88, .87, .86, .86, .85, .83, .82,
.81, .80, .78, .77, .76, .76, .75,
@@ -986,7 +996,7 @@
break;
case 3: for(i = 0; i < 81; i++) ffu.s[162+i] = sr3[i];
break;
- case 4: for(i = 0; i < 127; i++) ffu.s[214+i] = sr4[i];
+ case 4: for(i = 0; i < 127; i++) ffu.s[214+i] = sr4[i];
break;
@@ -1115,13 +1125,13 @@
break;
case 6: for(i = 0; i < 40; i++) ffu.s[738+i] = sr6[i];
break;
- case 7: for(i = 0; i < 117; i++) ffu.s[1332+i] = sr7[i];
+ case 7: for(i = 0; i < 117; i++) ffu.s[1332+i] = sr7[i];
break;
case 8: for(i = 0; i < 13; i++) ffu.s[82+i] = sr8[i];
break;
case 9: for(i = 0; i < 25; i++) ffu.s[384+i] = sr9[i];
break;
- case 10: for(i = 0; i < 27; i++) ffu.s[543+i] = sr10[i];
+ case 10: for(i = 0; i < 27; i++) ffu.s[543+i] = sr10[i];
break;
@@ -1447,11 +1457,11 @@
break;
case 4: for(i = 0; i < 70; i++) ffu.s[196+i] = sr4[i];
break;
- case 5: for(i = 0; i < 116; i++) ffu.s[502+i] = sr5[i];
+ case 5: for(i = 0; i < 116; i++) ffu.s[502+i] = sr5[i];
break;
- case 6: for(i = 0; i < 147; i++) ffu.s[706+i] = sr6[i];
+ case 6: for(i = 0; i < 147; i++) ffu.s[706+i] = sr6[i];
break;
- case 7: for(i = 0; i < 164; i++) ffu.s[101+i] = sr7[i];
+ case 7: for(i = 0; i < 164; i++) ffu.s[101+i] = sr7[i];
@@ -1742,9 +1752,9 @@
cin.ignore(numeric_limits<int>::max(),'\n');
/* moved rest further on */
- else if(iwave == 2) meteo();
- else if(iwave == 3) goes_east();
- else if(iwave == 4) goes_west();
+ else if(iwave == 2) meteo();
+ else if(iwave == 3) goes_east();
+ else if(iwave == 4) goes_west();
else if(iwave <= 16) avhrr(iwave - 4);
else if(iwave <= 24) hrv(iwave - 16);
else if(iwave <= 30) tm(iwave - 24);
