[GRASS-SVN] r35907 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Feb 17 09:32:43 EST 2009
Author: martinl
Date: 2009-02-17 09:32:43 -0500 (Tue, 17 Feb 2009)
New Revision: 35907
grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
grass/trunk/gui/wxpython/gui_modules/vdigit.py
wxGUI/vdigit: fix 'copy features' tool
(merge from develbranch_6, r35906)
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py 2009-02-17 14:29:38 UTC (rev 35906)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py 2009-02-17 14:32:43 UTC (rev 35907)
@@ -27,6 +27,8 @@
import dbm
import gdialogs
import gcmd
+import utils
+import globalvar
from debug import Debug
from preferences import globalSettings as UserSettings
from vdigit import GV_LINES as VDigit_Lines_Type
Modified: grass/trunk/gui/wxpython/gui_modules/vdigit.py
--- grass/trunk/gui/wxpython/gui_modules/vdigit.py 2009-02-17 14:29:38 UTC (rev 35906)
+++ grass/trunk/gui/wxpython/gui_modules/vdigit.py 2009-02-17 14:32:43 UTC (rev 35907)
@@ -190,13 +190,14 @@
ret = gcmd.RunCommand('v.edit',
parent = self,
quiet = True,
+ read = True,
map = bgmap,
tool = 'select',
bbox= '%f,%f,%f,%f' % (pos1[0], pos1[1], pos2[0], pos2[1]))
if not ret:
- return ids
+ return []
output = ret.splitlines()[0] # first line
ids = output.split(',')
ids = map(int, ids) # str -> int
