[GRASS-SVN] r35910 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Feb 17 11:08:25 EST 2009
Author: martinl
Date: 2009-02-17 11:08:24 -0500 (Tue, 17 Feb 2009)
New Revision: 35910
grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
grass/trunk/gui/wxpython/gui_modules/vdigit.py
wxGUI/vdigit: select features from bgmap by bbox/point, multiple selection allowed
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py 2009-02-17 14:53:04 UTC (rev 35909)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py 2009-02-17 16:08:24 UTC (rev 35910)
@@ -1291,8 +1291,9 @@
digitToolbar = self.parent.toolbars['vdigit']
digitClass = self.parent.digit
- self.copyIds = []
- self.layerTmp = None
+ if not hasattr(self, "copyIds"):
+ self.copyIds = []
+ self.layerTmp = None
def OnLeftDownVDigitBulkLine(self, event):
@@ -1605,7 +1606,7 @@
self.UpdateMap(render=False, renderVector=False)
else:
# copy features from background map
- self.copyIds = digitClass.SelectLinesFromBackgroundMap(pos1, pos2)
+ self.copyIds += digitClass.SelectLinesFromBackgroundMap(pos1, pos2)
if len(self.copyIds) > 0:
color = UserSettings.Get(group='vdigit', key='symbol',
subkey=['highlight', 'color'])
@@ -1622,9 +1623,13 @@
'type=point,line,boundary,centroid',
'width=2']
- self.layerTmp = self.Map.AddLayer(type='vector',
- name=globalvar.QUERYLAYER,
- command=dVectTmp)
+ if not self.layerTmp:
+ self.layerTmp = self.Map.AddLayer(type='vector',
+ name=globalvar.QUERYLAYER,
+ command=dVectTmp)
+ else:
+ self.layerTmp.SetCmd(dVectTmp)
self.UpdateMap(render=True, renderVector=False)
else:
Modified: grass/trunk/gui/wxpython/gui_modules/vdigit.py
--- grass/trunk/gui/wxpython/gui_modules/vdigit.py 2009-02-17 14:53:04 UTC (rev 35909)
+++ grass/trunk/gui/wxpython/gui_modules/vdigit.py 2009-02-17 16:08:24 UTC (rev 35910)
@@ -175,7 +175,7 @@
def SelectLinesFromBackgroundMap(self, pos1, pos2):
"""Select features from background map
- @param pos1,pos2 bounding box defifinition
+ @param pos1,pos2 bounding box
bgmap = str(UserSettings.Get(group='vdigit', key='bgmap', subkey='value',
internal=True))
@@ -186,16 +186,26 @@
x1, y1 = pos1
x2, y2 = pos2
ret = gcmd.RunCommand('v.edit',
parent = self,
quiet = True,
read = True,
map = bgmap,
tool = 'select',
- bbox= '%f,%f,%f,%f' % (pos1[0], pos1[1], pos2[0], pos2[1]))
+ bbox = '%f,%f,%f,%f' % (x1, y1, x2, y2))
if not ret:
+ x, y = pos1
+ ret = gcmd.RunCommand('v.edit',
+ parent = self,
+ quiet = True,
+ read = True,
+ map = bgmap,
+ tool = 'select',
+ coords = '%f,%f' % (x, y),
+ thresh = self.driver.GetThreshold(type='selectThresh'))
+ if not ret:
return []
output = ret.splitlines()[0] # first line
