[GRASS-SVN] r35918 - in grass/branches/develbranch_6: include
lib/vector/Vlib vector/v.out.ascii
svn_grass at osgeo.org
Wed Feb 18 08:31:10 EST 2009
Author: martinl
Date: 2009-02-18 08:31:10 -0500 (Wed, 18 Feb 2009)
New Revision: 35918
grass/branches/develbranch_6/include/Vect.h
grass/branches/develbranch_6/lib/vector/Vlib/cats.c
grass/branches/develbranch_6/vector/v.out.ascii/b2a.c
vlib: Vect_field_cat_get() added
v.out.ascii: fix trac #495
Modified: grass/branches/develbranch_6/include/Vect.h
--- grass/branches/develbranch_6/include/Vect.h 2009-02-18 05:40:19 UTC (rev 35917)
+++ grass/branches/develbranch_6/include/Vect.h 2009-02-18 13:31:10 UTC (rev 35918)
@@ -58,6 +58,7 @@
int Vect_cat_get(struct line_cats *, int, int *);
int Vect_cat_del(struct line_cats *, int);
int Vect_field_cat_del(struct line_cats *, int, int);
+int Vect_field_cat_get(struct line_cats *, int, struct ilist *);
int Vect_cat_in_array(int, int *, int);
int Vect_reset_cats(struct line_cats *);
int Vect_destroy_cats_struct(struct line_cats *);
Modified: grass/branches/develbranch_6/lib/vector/Vlib/cats.c
--- grass/branches/develbranch_6/lib/vector/Vlib/cats.c 2009-02-18 05:40:19 UTC (rev 35917)
+++ grass/branches/develbranch_6/lib/vector/Vlib/cats.c 2009-02-18 13:31:10 UTC (rev 35918)
@@ -5,7 +5,7 @@
* Higher level functions for reading/writing/manipulating vectors.
- * (C) 2001-2008 by the GRASS Development Team
+ * (C) 2001-2009 by the GRASS Development Team
* This program is free software under the
* GNU General Public License (>=v2).
@@ -13,9 +13,9 @@
* for details.
* \author Original author CERL, probably Dave Gerdes or Mike
- * Higgins. Update to GRASS 5.7 Radim Blazek and David D. Gray.
- * \date 2001-2008
+ * Higgins
+ * \author Update to GRASS 5.7 Radim Blazek and David D. Gray.
+ * \author Various updates by Martin Landa <landa.martin gmail.com>
#include <stdlib.h>
@@ -48,7 +48,7 @@
- \brief Creates and initializes line_cats structure.
+ \brief Creates and initializes line_cats structure (lower level fn)
This structure is used for reading and writing vector cats. The
library routines handle all memory allocation.
@@ -179,6 +179,37 @@
+ \brief Get list of categories of given field.
+ \param Cats line_cats structure
+ \param field layer number
+ \param[out] cats pointer to list where cats will be written
+ \return number of found categories
+ \return -1 on invalid field
+int Vect_field_cat_get(struct line_cats *Cats, int field, struct ilist *cats)
+ int n;
+ /* reset list of categories */
+ Vect_reset_list(cats);
+ /* check input value */
+ if (field < 1 || field > GV_FIELD_MAX)
+ return -1;
+ /* go through cats and find if field exist */
+ for (n = 0; n < Cats->n_cats; n++) {
+ if (Cats->field[n] != field)
+ continue;
+ Vect_list_append(cats, Cats->cat[n]);
+ return cats->n_values;
\brief Delete all categories of given layer
\param[in] Cats line_cats structure
Modified: grass/branches/develbranch_6/vector/v.out.ascii/b2a.c
--- grass/branches/develbranch_6/vector/v.out.ascii/b2a.c 2009-02-18 05:40:19 UTC (rev 35917)
+++ grass/branches/develbranch_6/vector/v.out.ascii/b2a.c 2009-02-18 13:31:10 UTC (rev 35918)
@@ -17,6 +17,7 @@
struct line_cats *Cats;
char *xstring = NULL, *ystring = NULL, *zstring = NULL;
struct Cell_head window;
+ struct ilist *fcats;
/* where */
struct field_info *Fi;
@@ -61,6 +62,7 @@
Points = Vect_new_line_struct(); /* init line_pnts struct */
Cats = Vect_new_cats_struct();
+ fcats = Vect_new_list();
proj = Vect_get_proj(Map);
@@ -182,17 +184,20 @@
else {
fprintf(ascii, "%s%s%s", xstring, fs, ystring);
- if (Cats->n_cats > 0) {
- if (Cats->n_cats > 1) {
+ Vect_field_cat_get(Cats, field, fcats);
+ if (fcats->n_values > 0) {
+ if (fcats->n_values > 1) {
G_warning(_("Feature has more categories. Only first category (%d) "
- "is exported."), Cats->cat[0]);
+ "is exported."), fcats->value[0]);
- fprintf(ascii, "%s%d", fs, Cats->cat[0]);
+ fprintf(ascii, "%s%d", fs, fcats->value[0]);
/* print attributes */
if (columns) {
for(i = 0; columns[i]; i++) {
- if (db_select_value(driver, Fi->table, Fi->key, Cats->cat[0],
+ if (db_select_value(driver, Fi->table, Fi->key, fcats->value[0],
columns[i], &value) < 0)
G_fatal_error(_("Unable to select record from table <%s> (key %s, column %s)"),
Fi->table, Fi->key, columns[i]);
