[GRASS-SVN] r35944 - grass-addons/vector/v.in.gshhs
svn_grass at osgeo.org
Thu Feb 19 06:13:03 EST 2009
Author: mmetz
Date: 2009-02-19 06:13:03 -0500 (Thu, 19 Feb 2009)
New Revision: 35944
grass-addons/vector/v.in.gshhs/main.c
changed line selection policy and bugfix
Modified: grass-addons/vector/v.in.gshhs/main.c
--- grass-addons/vector/v.in.gshhs/main.c 2009-02-19 10:44:22 UTC (rev 35943)
+++ grass-addons/vector/v.in.gshhs/main.c 2009-02-19 11:13:03 UTC (rev 35944)
@@ -324,6 +324,10 @@
if (getme) {
+ /* abusing getme flag a bit */
+ if (getme == 2)
+ getme = 0;
Vect_reset_line(Points);
Vect_reset_cats(Cats);
/* simple table and cats for layer 1: not unique, just per slevel */
@@ -346,36 +350,27 @@
lon -= 360.0;
lat = p.y * GSHHS_SCL;
- if (getme == 2) { /* overlap */
+ if (getme == 0) { /* overlap */
/* datum border wrap around work around, clumsy code but works */
if (maxx > 180. && lon < 0) {
- if (lat >= minx && lat <= maxx && (lon + 360.) >= miny && (lon + 360.) <= maxy) {
- /* vertex inside current region, do nothing */
+ if (lat >= miny && lat <= maxy && (lon + 360.) >= minx && (lon + 360.) <= maxx) {
+ /* vertex inside current region, import line */
+ getme = 1;
- else {
- /* vertex outside current region, skip whole line */
- Vect_reset_line(Points);
- getme = 0;
else {
- if (lat >= minx && lat <= maxx && lon >= miny && lon <= maxy) {
+ if (lat >= miny && lat <= maxy && lon >= minx && lon <= maxx) {
+ getme = 1;
- else {
- getme = 0;
- if (getme)
- Vect_append_point(Points, lon, lat, 0.);
+ Vect_append_point(Points, lon, lat, 0.);
} /* done with line */
- if (Points->n_points) {
+ if (getme && Points->n_points) {
/* change thresh if you want longer line segments */
Vect_write_line_tiled(&VectMap, type, Points, Cats, 2.);
@@ -532,7 +527,7 @@
if (maxy < (curry - lasty))
maxy = curry - lasty;
- if (i && ((maxx - minx) > thresh || (maxy - miny) > thresh)) {
+ if (BPoints->n_points > 1 && ((maxx - minx) > thresh || (maxy - miny) > thresh)) {
lastx = BPoints->x[BPoints->n_points - 1]; /* keep last x for new line */
lasty = BPoints->y[BPoints->n_points - 1]; /* keep last y for new line */
