[GRASS-SVN] r35946 -
grass/branches/releasebranch_6_4/lib/vector/Vlib
svn_grass at osgeo.org
Thu Feb 19 06:45:50 EST 2009
Author: hamish
Date: 2009-02-19 06:45:50 -0500 (Thu, 19 Feb 2009)
New Revision: 35946
grass/branches/releasebranch_6_4/lib/vector/Vlib/sindex.c
add back G_percent() which was removed circa r34754. The fn can minutes to complete. (merge from devbr6)
Modified: grass/branches/releasebranch_6_4/lib/vector/Vlib/sindex.c
--- grass/branches/releasebranch_6_4/lib/vector/Vlib/sindex.c 2009-02-19 11:42:55 UTC (rev 35945)
+++ grass/branches/releasebranch_6_4/lib/vector/Vlib/sindex.c 2009-02-19 11:45:50 UTC (rev 35946)
@@ -161,6 +161,8 @@
/* Nodes */
for (i = 1; i <= plus->n_nodes; i++) {
+ G_percent(i, total, 3);
Node = plus->Node[i];
if (!Node)
G_fatal_error(_("BUG (Vect_build_sidx_from_topo): node does not exist"));
@@ -171,6 +173,8 @@
/* Lines */
done = plus->n_nodes;
for (i = 1; i <= plus->n_lines; i++) {
+ G_percent(done + i, total, 3);
Line = plus->Line[i];
if (!Line)
G_fatal_error(_("BUG (Vect_build_sidx_from_topo): line does not exist"));
@@ -188,6 +192,8 @@
/* Areas */
done += plus->n_lines;
for (i = 1; i <= plus->n_areas; i++) {
Area = plus->Area[i];
if (!Area)
G_fatal_error(_("BUG (Vect_build_sidx_from_topo): area does not exist"));
@@ -205,6 +211,8 @@
/* Isles */
done += plus->n_areas;
for (i = 1; i <= plus->n_isles; i++) {
Isle = plus->Isle[i];
if (!Isle)
G_fatal_error(_("BUG (Vect_build_sidx_from_topo): isle does not exist"));
