[GRASS-SVN] r35965 - grass/trunk/raster/r.sun2
Thu Feb 19 19:07:48 EST 2009
Author: hamish
Date: 2009-02-19 19:07:47 -0500 (Thu, 19 Feb 2009)
New Revision: 35965
   grass/trunk/raster/r.sun2/local_proto.h
   grass/trunk/raster/r.sun2/main.c
   grass/trunk/raster/r.sun2/rsunglobals.h
   grass/trunk/raster/r.sun2/rsunlib.c
   grass/trunk/raster/r.sun2/sunradstruct.h
run tools/grass_indent.sh
Modified: grass/trunk/raster/r.sun2/local_proto.h
--- grass/trunk/raster/r.sun2/local_proto.h	2009-02-20 00:04:28 UTC (rev 35964)
+++ grass/trunk/raster/r.sun2/local_proto.h	2009-02-20 00:07:47 UTC (rev 35965)
@@ -1,10 +1,10 @@
 /* main.c */
-void where_is_point(double *length, struct SunGeometryVarDay *sunVarGeom,
-	struct GridGeometry *gridGeom);
-int searching(double *length, struct SunGeometryVarDay *sunVarGeom,
+void where_is_point(double *length, struct SunGeometryVarDay *sunVarGeom,
+		    struct GridGeometry *gridGeom);
+int searching(double *length, struct SunGeometryVarDay *sunVarGeom,
 int useCivilTime();
 void setUseCivilTime(int val);
@@ -27,39 +27,43 @@
 double brad(double, double *bh, struct SunGeometryVarDay *sunVarGeom,
-		struct SunGeometryVarSlope *sunSlopeGeom,
-		struct SolarRadVar *sunRadVar);
-double drad(double, double bh, double *rr, struct SunGeometryVarDay *sunVarGeom,
-double brad_angle_loss(double, double *bh, struct SunGeometryVarDay *sunVarGeom,
+	    struct SunGeometryVarSlope *sunSlopeGeom,
-double drad_angle_loss(double, double bh, double *rr, struct SunGeometryVarDay *sunVarGeom,
+double drad(double, double bh, double *rr,
+	    struct SunGeometryVarDay *sunVarGeom,
-void com_par( struct SunGeometryConstDay *sungeom,
-		struct SunGeometryVarDay *sunVarGeom,
-		struct GridGeometry *gridGeom,
-		double latitude, double longitude);
+double brad_angle_loss(double, double *bh,
+		       struct SolarRadVar *sunRadVar);
+double drad_angle_loss(double, double bh, double *rr,
+void com_par(struct SunGeometryConstDay *sungeom,
+	     struct GridGeometry *gridGeom,
+	     double latitude, double longitude);
 void com_par_const(double longitTime, struct SunGeometryConstDay *sungeom,
 double lumcline2(struct SunGeometryConstDay *sungeom,
-		unsigned char *horizonpointer);
+		 unsigned char *horizonpointer);
-typedef	double (*BeamRadFunc)(double sh, double *bh, struct SunGeometryVarDay *sunVarGeom,
-typedef	double (*DiffRadFunc)(double sh, double bh, double *rr, struct SunGeometryVarDay *sunVarGeom,
+typedef double (*BeamRadFunc) (double sh, double *bh,
+			       struct SunGeometryVarDay * sunVarGeom,
+			       struct SunGeometryVarSlope * sunSlopeGeom,
+			       struct SolarRadVar * sunRadVar);
+typedef double (*DiffRadFunc) (double sh, double bh, double *rr,
Modified: grass/trunk/raster/r.sun2/main.c
--- grass/trunk/raster/r.sun2/main.c	2009-02-20 00:04:28 UTC (rev 35964)
+++ grass/trunk/raster/r.sun2/main.c	2009-02-20 00:07:47 UTC (rev 35965)
@@ -1,3 +1,4 @@
 r.sun: This program was writen by Jaro Hofierka in Summer 1993 and re-engineered
 in 1996-1999. In cooperation with Marcel Suri and Thomas Huld from JRC in Ispra
@@ -107,7 +108,8 @@
 	     struct SolarRadVar *sunRadVar,
-	     unsigned char *horizonpointer, double latitude, double longitude);
+	     unsigned char *horizonpointer, double latitude,
+	     double longitude);
 void calculate(double singleSlope, double singleAspect,
@@ -131,6 +133,7 @@
 float **lumcl, **beam, **insol, **diff, **refl, **globrad;
 unsigned char *horizonarray = NULL;
 double civilTime;
  * double startTime, endTime;
@@ -140,10 +143,12 @@
     la_min = 90.;
 double offsetx = 0.5, offsety = 0.5;
 char *tt, *lt;
  * double slope;
 double o_orig, z1;
  * double lum_C11, lum_C13, lum_C22, lum_C31, lum_C33;
  * double sinSolarAltitude; */
@@ -160,6 +165,7 @@
 double horizonStep;
 double ltime, tim, timo;
 double declination;		/* Contains the negative of the declination at the chosen day */
  * double lum_C31_l, lum_C33_l;
@@ -199,9 +205,9 @@
 	struct Option *elevin, *aspin, *aspect, *slopein, *slope, *linkein,
 	    *lin, *albedo, *longin, *alb, *latin, *lat, *coefbh, *coefdh,
-	    *incidout, *beam_rad, *insol_time, *diff_rad, *refl_rad, *glob_rad,
-	    *day, *step, *declin, *ltime, *dist, *horizon, *horizonstep,
-	    *numPartitions, *civilTime;
+	    *incidout, *beam_rad, *insol_time, *diff_rad, *refl_rad,
+	    *glob_rad, *day, *step, *declin, *ltime, *dist, *horizon,
+	    *horizonstep, *numPartitions, *civilTime;
     parm;
@@ -233,7 +239,8 @@
     parm.elevin->type = TYPE_STRING;
     parm.elevin->required = YES;
     parm.elevin->gisprompt = "old,cell,raster";
-    parm.elevin->description = _("Name of the input elevation raster map [meters]");
+    parm.elevin->description =
+	_("Name of the input elevation raster map [meters]");
     parm.elevin->guisection = _("Input_options");
     parm.aspin = G_define_option();
@@ -241,7 +248,8 @@
     parm.aspin->type = TYPE_STRING;
     parm.aspin->required = NO;
     parm.aspin->gisprompt = "old,cell,raster";
-    parm.aspin->description = _("Name of the input aspect map (terrain aspect or azimuth of the solar panel) [decimal degrees]");
+    parm.aspin->description =
+	_("Name of the input aspect map (terrain aspect or azimuth of the solar panel) [decimal degrees]");
     parm.aspin->guisection = _("Input_options");
     parm.aspect = G_define_option();
@@ -258,7 +266,8 @@
     parm.slopein->type = TYPE_STRING;
     parm.slopein->required = NO;
     parm.slopein->gisprompt = "old,cell,raster";
-    parm.slopein->description = _("Name of the input slope raster map (terrain slope or solar panel inclination) [decimal degrees]");
+    parm.slopein->description =
+	_("Name of the input slope raster map (terrain slope or solar panel inclination) [decimal degrees]");
     parm.slopein->guisection = _("Input_options");
     parm.slope = G_define_option();
@@ -294,7 +303,8 @@
     parm.albedo->type = TYPE_STRING;
     parm.albedo->required = NO;
     parm.albedo->gisprompt = "old,cell,raster";
-    parm.albedo->description = _("Name of the ground albedo coefficient input raster map [-]");
+    parm.albedo->description =
+	_("Name of the ground albedo coefficient input raster map [-]");
     parm.albedo->guisection = _("Input_options");
     if (parm.albedo->answer == NULL) {
@@ -303,7 +313,8 @@
 	parm.alb->type = TYPE_DOUBLE;
 	parm.alb->answer = ALB;
 	parm.alb->required = NO;
-	parm.alb->description = _("A single value of the ground albedo coefficient [-]");
+	parm.alb->description =
+	    _("A single value of the ground albedo coefficient [-]");
 	parm.alb->guisection = _("Input_options");
@@ -312,7 +323,8 @@
     parm.latin->type = TYPE_STRING;
     parm.latin->required = NO;
     parm.latin->gisprompt = "old,cell,raster";
-    parm.latin->description = _("Name of the latitudes input raster map [decimal degrees]");
+    parm.latin->description =
+	_("Name of the latitudes input raster map [decimal degrees]");
     parm.latin->guisection = _("Input_options");
     if (parm.latin->answer == NULL) {
@@ -320,7 +332,8 @@
 	parm.lat->key = "lat";
 	parm.lat->type = TYPE_DOUBLE;
 	parm.lat->required = NO;
-	parm.lat->description = _("A single value of latitude [decimal degrees]");
+	parm.lat->description =
+	    _("A single value of latitude [decimal degrees]");
 	parm.lat->guisection = _("Input_options");
@@ -329,7 +342,8 @@
     parm.longin->type = TYPE_STRING;
     parm.longin->required = NO;
     parm.longin->gisprompt = "old,cell,raster";
-    parm.longin->description = _("Name of the longitude input raster map [decimal degrees]");
+    parm.longin->description =
+	_("Name of the longitude input raster map [decimal degrees]");
     parm.longin->guisection = _("Input_options");
     parm.coefbh = G_define_option();
@@ -371,7 +385,8 @@
     parm.incidout->type = TYPE_STRING;
     parm.incidout->required = NO;
     parm.incidout->gisprompt = "new,cell,raster";
-    parm.incidout->description = _("Output incidence angle raster map (mode 1 only)");
+    parm.incidout->description =
+	_("Output incidence angle raster map (mode 1 only)");
     parm.incidout->guisection = _("Output_options");
     parm.beam_rad = G_define_option();
@@ -388,7 +403,8 @@
     parm.insol_time->type = TYPE_STRING;
     parm.insol_time->required = NO;
     parm.insol_time->gisprompt = "new,cell,raster";
-    parm.insol_time->description = _("Output insolation time raster map [h] (mode 2 only)");
+    parm.insol_time->description =
+	_("Output insolation time raster map [h] (mode 2 only)");
     parm.insol_time->guisection = _("Output_options");
     parm.diff_rad = G_define_option();
@@ -430,7 +446,8 @@
     parm.step->type = TYPE_DOUBLE;
     parm.step->answer = STEP;
     parm.step->required = NO;
-    parm.step->description = _("Time step when computing all-day radiation sums [decimal hours]");
+    parm.step->description =
+	_("Time step when computing all-day radiation sums [decimal hours]");
     parm.declin = G_define_option();
     parm.declin->key = "declin";
@@ -444,7 +461,8 @@
     parm.ltime->type = TYPE_DOUBLE;
     /*          parm.ltime->answer = TIME; */
     parm.ltime->required = NO;
-    parm.ltime->description = _("Local (solar) time (to be set for mode 1 only) [decimal hours]");
+    parm.ltime->description =
+	_("Local (solar) time (to be set for mode 1 only) [decimal hours]");
      * parm.startTime = G_define_option();
@@ -465,7 +483,8 @@
     parm.dist->type = TYPE_DOUBLE;
     parm.dist->answer = DIST;
     parm.dist->required = NO;
-    parm.dist->description = _("Sampling distance step coefficient (0.5-1.5)");
+    parm.dist->description =
+	_("Sampling distance step coefficient (0.5-1.5)");
     parm.numPartitions = G_define_option();
     parm.numPartitions->key = "numpartitions";
@@ -582,14 +601,14 @@
     if (parm.horizonstep->answer != NULL) {
 	if (sscanf(parm.horizonstep->answer, "%lf", &horizonStep) != 1)
 	    G_fatal_error(_("Error reading horizon step size"));
-	if(horizonStep > 0.)
+	if (horizonStep > 0.)
 	    setHorizonInterval(deg2rad * horizonStep);
 	else
 	    G_fatal_error(_("The horizon step size must be greater than 0."));
-    else if(useHorizonData()) {
-		G_fatal_error(_("If you use the horizon option you must also set the 'horizonstep' parameter."));
+    else if (useHorizonData()) {
+	G_fatal_error(_("If you use the horizon option you must also set the 'horizonstep' parameter."));
     tt = parm.ltime->answer;
@@ -632,10 +651,10 @@
      * if (parm.lat->answer != NULL)
      * sscanf(parm.lat->answer, "%lf", &latitude);
-/* HB 6/2008: why is the above commented out? instead of sscanf, maybe nicer to use:
-    G_scan_lat(parm.lat->answer, &latitude);
-   MN 2/2009: latitude doesn't exist! also G_scan_lat() does not exist in GRASS
+    /* HB 6/2008: why is the above commented out? instead of sscanf, maybe nicer to use:
+       G_scan_lat(parm.lat->answer, &latitude);
+       MN 2/2009: latitude doesn't exist! also G_scan_lat() does not exist in GRASS
     if (parm.slopein->answer == NULL)
 	sscanf(parm.slope->answer, "%lf", &singleSlope);
@@ -713,27 +732,27 @@
     /* Set up parameters for projection to lat/long if necessary */
     if (latin == NULL && lt == NULL && (G_projection() != PROJECTION_LL)) {
-    struct Key_Value *in_proj_info, *in_unit_info;
+	struct Key_Value *in_proj_info, *in_unit_info;
-    if ((in_proj_info = G_get_projinfo()) == NULL)
-	G_fatal_error
-	    (_("Can't get projection info of current location: please set latitude via 'lat' or 'latin' option!"));
+	if ((in_proj_info = G_get_projinfo()) == NULL)
+	    G_fatal_error
+		(_("Can't get projection info of current location: please set latitude via 'lat' or 'latin' option!"));
-    if ((in_unit_info = G_get_projunits()) == NULL)
-	G_fatal_error(_("Can't get projection units of current location"));
+	if ((in_unit_info = G_get_projunits()) == NULL)
+	    G_fatal_error(_("Can't get projection units of current location"));
-    if (pj_get_kv(&iproj, in_proj_info, in_unit_info) < 0)
-	G_fatal_error(_("Can't get projection key values of current location"));
+	if (pj_get_kv(&iproj, in_proj_info, in_unit_info) < 0)
+	    G_fatal_error(_("Can't get projection key values of current location"));
-    G_free_key_value(in_proj_info);
-    G_free_key_value(in_unit_info);
+	G_free_key_value(in_proj_info);
+	G_free_key_value(in_unit_info);
-    /* Set output projection to latlong w/ same ellipsoid */
-    oproj.zone = 0;
-    oproj.meters = 1.;
-    sprintf(oproj.proj, "ll");
-    if ((oproj.pj = pj_latlong_from_proj(iproj.pj)) == NULL)
-	G_fatal_error(_("Unable to set up lat/long projection parameters"));
+	/* Set output projection to latlong w/ same ellipsoid */
+	oproj.zone = 0;
+	oproj.meters = 1.;
+	sprintf(oproj.proj, "ll");
+	if ((oproj.pj = pj_latlong_from_proj(iproj.pj)) == NULL)
+	    G_fatal_error(_("Unable to set up lat/long projection parameters"));
 /**********end of parser - ******************************/
@@ -790,7 +809,7 @@
     if ((mapset = G_find_cell2(elevin, "")) == NULL)
-	G_fatal_error(_("Raster map <%s> not found"),elevin);
+	G_fatal_error(_("Raster map <%s> not found"), elevin);
     fd1 = G_open_cell_old(elevin, mapset);
@@ -805,7 +824,7 @@
 	if ((mapset = G_find_cell2(slopein, "")) == NULL)
-	       G_fatal_error(_("Raster map <%s> not found"),slopein);
+	    G_fatal_error(_("Raster map <%s> not found"), slopein);
 	fd3 = G_open_cell_old(slopein, mapset);
@@ -822,7 +841,7 @@
 	if ((mapset = G_find_cell2(aspin, "")) == NULL)
-	    G_fatal_error(_("Raster map <%s> not found"),aspin);
+	    G_fatal_error(_("Raster map <%s> not found"), aspin);
 	fd2 = G_open_cell_old(aspin, mapset);
@@ -836,7 +855,7 @@
 	if ((mapset = G_find_cell2(linkein, "")) == NULL)
-	    G_fatal_error(_("Raster map <%s> not found"),linkein);
+	    G_fatal_error(_("Raster map <%s> not found"), linkein);
 	fd4 = G_open_cell_old(linkein, mapset);
@@ -848,7 +867,7 @@
 		a[l] = (float *)G_malloc(sizeof(float) * (n));
 	if ((mapset = G_find_cell2(albedo, "")) == NULL)
-	    G_fatal_error(_("Raster map <%s> not found"),albedo);
+	    G_fatal_error(_("Raster map <%s> not found"), albedo);
 	fd5 = G_open_cell_old(albedo, mapset);
@@ -860,7 +879,7 @@
 		la[l] = (float *)G_malloc(sizeof(float) * (n));
 	if ((mapset = G_find_cell2(latin, "")) == NULL)
-	    G_fatal_error(_("Raster map <%s> not found"),latin);
+	    G_fatal_error(_("Raster map <%s> not found"), latin);
 	fd6 = G_open_cell_old(latin, mapset);
@@ -871,7 +890,7 @@
 	    longitArray[l] = (float *)G_malloc(sizeof(float) * (n));
 	if ((mapset = G_find_cell2(longin, "")) == NULL)
-	    G_fatal_error(_("Raster map <%s> not found"),longin);
+	    G_fatal_error(_("Raster map <%s> not found"), longin);
 	fd7 = G_open_cell_old(longin, mapset);
@@ -883,7 +902,7 @@
 		cbhr[l] = (float *)G_malloc(sizeof(float) * (n));
 	if ((mapset = G_find_cell2(coefbh, "")) == NULL)
-	    G_fatal_error(_("Raster map <%s> not found"),coefbh);
+	    G_fatal_error(_("Raster map <%s> not found"), coefbh);
 	fr1 = G_open_cell_old(coefbh, mapset);
@@ -895,15 +914,15 @@
 		cdhr[l] = (float *)G_malloc(sizeof(float) * (n));
 	if ((mapset = G_find_cell2(coefdh, "")) == NULL)
-	    G_fatal_error(_("Raster map <%s> not found"),coefdh);
+	    G_fatal_error(_("Raster map <%s> not found"), coefdh);
 	fr2 = G_open_cell_old(coefdh, mapset);
 	if (horizonarray == NULL) {
 	    horizonarray =
-		(unsigned char *)G_malloc(sizeof(char) * arrayNumInt * numRows *
-					n);
+		(unsigned char *)G_malloc(sizeof(char) * arrayNumInt *
+					  numRows * n);
 	    horizonbuf = (FCELL **) G_malloc(sizeof(FCELL *) * arrayNumInt);
 	    fd_shad = (int *)G_malloc(sizeof(int) * arrayNumInt);
@@ -925,10 +944,11 @@
 	numDigits = (int)(log10(1. * arrayNumInt)) + 1;
 	sprintf(formatString, "%%s_%%0%dd", numDigits);
 	for (i = 0; i < arrayNumInt; i++) {
-		horizonbuf[i] = G_allocate_f_raster_buf();
+	    horizonbuf[i] = G_allocate_f_raster_buf();
 	    sprintf(shad_filename, formatString, horizon, i);
 	    if ((mapset = G_find_cell2(shad_filename, "")) == NULL)
-		G_fatal_error(_("Horizon file no. %d <%s> not found"), i, shad_filename);
+		G_fatal_error(_("Horizon file no. %d <%s> not found"), i,
+			      shad_filename);
 	    fd_shad[i] = G_open_cell_old(shad_filename, mapset);
@@ -944,7 +964,8 @@
 		row_rev = m - row - 1;
 		rowrevoffset = row_rev - offset;
 		G_get_f_raster_row(fd_shad[i], horizonbuf[i], row);
-		horizonpointer = horizonarray + (ssize_t) arrayNumInt * n * rowrevoffset;
+		horizonpointer =
+		    horizonarray + (ssize_t) arrayNumInt *n * rowrevoffset;
 		for (j = 0; j < n; j++) {
 		    horizonpointer[i] = (char)(rint(SCALING_FACTOR *
@@ -1132,8 +1153,8 @@
 int OUTGR(void)
-    FCELL *cell7 = NULL, *cell8 = NULL, *cell9 = NULL, *cell10 = NULL, *cell11 =
-	NULL, *cell12 = NULL;
+    FCELL *cell7 = NULL, *cell8 = NULL, *cell9 = NULL, *cell10 =
+	NULL, *cell11 = NULL, *cell12 = NULL;
     int fd7 = -1, fd8 = -1, fd9 = -1, fd10 = -1, fd11 = -1, fd12 = -1;
     int i, iarc, j;
@@ -1379,13 +1400,15 @@
 		if ((diff_rad != NULL) || (glob_rad != NULL)) {
 		    dra =
-			drad(s0, bh, &rr, sunVarGeom, sunSlopeGeom, sunRadVar);
+			drad(s0, bh, &rr, sunVarGeom, sunSlopeGeom,
+			     sunRadVar);
 		    diff_e += dfr * dra;
 		    dra = 0.;
 		if ((refl_rad != NULL) || (glob_rad != NULL)) {
 		    if ((diff_rad == NULL) && (glob_rad == NULL)) {
+			     sunRadVar);
 		    refl_e += dfr * rr;
 		    rr = 0.;
@@ -1458,6 +1481,7 @@
     double sx, sy;
     double dx, dy;
     /*              double adx, ady; */
     int i, j;
@@ -1637,6 +1661,7 @@
 	       double singleLinke, struct GridGeometry gridGeom)
     int i, j, l;
     /*                      double energy; */
     int someRadiation;
     int numRows;
@@ -1754,7 +1779,8 @@
 	 * "local clock time". */
 	dayRad = 2. * M_PI * day / 365.25;
 	locTimeOffset =
-	    -0.128 * sin(dayRad - 0.04887) - 0.165 * sin(2 * dayRad + 0.34383);
+	    -0.128 * sin(dayRad - 0.04887) - 0.165 * sin(2 * dayRad +
+							 0.34383);
 	/* Time offset due to timezone as input by user */
@@ -1826,29 +1852,29 @@
 		    latitude *= deg2rad;
 		/* MN 2/2009: should it be??
-		  if (latin == NULL && lt == NULL && (G_projection() != PROJECTION_LL)) {
+		   if (latin == NULL && lt == NULL && (G_projection() != PROJECTION_LL)) {
 		if ((G_projection() != PROJECTION_LL)) {
-			longitude = gridGeom.xp;
-			latitude = gridGeom.yp;
+		    longitude = gridGeom.xp;
+		    latitude = gridGeom.yp;
-			if (pj_do_proj(&longitude, &latitude, &iproj, &oproj) < 0) {
-			    G_fatal_error("Error in pj_do_proj");
+		    if (pj_do_proj(&longitude, &latitude, &iproj, &oproj) < 0) {
+			G_fatal_error("Error in pj_do_proj");
-			la_max = AMAX1(la_max, latitude);
-			la_min = AMIN1(la_min, latitude);
-			latitude *= deg2rad;
-			longitude *= deg2rad;
+		    la_max = AMAX1(la_max, latitude);
+		    la_min = AMIN1(la_min, latitude);
+		    latitude *= deg2rad;
+		    longitude *= deg2rad;
-		else {	/* ll projection */
+		else {		/* ll projection */
 		if (coefbh != NULL) {
@@ -1869,10 +1895,12 @@
 		gridGeom.coslat = cos(-latitude);
 		sin_phi_l =
-		    -gridGeom.coslat * cos_u * sin_v + gridGeom.sinlat * sin_u;
+		    -gridGeom.coslat * cos_u * sin_v +
 		latid_l = asin(sin_phi_l);
-		q1 = gridGeom.sinlat * cos_u * sin_v + gridGeom.coslat * sin_u;
+		q1 = gridGeom.sinlat * cos_u * sin_v +
 		tan_lam_l = -cos_u * cos_v / q1;
 		sunSlopeGeom.longit_l = atan(tan_lam_l);
 		sunSlopeGeom.lum_C31_l = cos(latid_l) * sunGeom.cosdecl;
@@ -1941,7 +1969,8 @@
 	G_short_history(glob_rad, "raster", &hist);
     else
-	G_fatal_error("Failed to init map history: no output maps requested!");
+	G_fatal_error
+	    ("Failed to init map history: no output maps requested!");
     sprintf(hist.edhist[0],
@@ -2013,8 +2042,8 @@
 		sunRadVar.linke);
     else
 	sprintf(hist.edhist[hist.edlinecnt],
-		" Linke turbidity factor min-max:           %.1f-%.1f", li_min,
-		li_max);
+		" Linke turbidity factor min-max:           %.1f-%.1f",
+		li_min, li_max);
     hist.edlinecnt++;
     if (albedo == NULL)
@@ -2023,8 +2052,8 @@
 		sunRadVar.alb);
     else
-		" Ground albedo min-max:                    %.3f-%.3f", al_min,
-		al_max);
+		" Ground albedo min-max:                    %.3f-%.3f",
+		al_min, al_max);
     hist.edlinecnt++;
Modified: grass/trunk/raster/r.sun2/rsunglobals.h
--- grass/trunk/raster/r.sun2/rsunglobals.h	2009-02-20 00:04:28 UTC (rev 35964)
+++ grass/trunk/raster/r.sun2/rsunglobals.h	2009-02-20 00:07:47 UTC (rev 35965)
@@ -1,3 +1,4 @@
 r.sun: rsunglobals.h. This program was writen by Jaro Hofierka in Summer 1993 and re-engineered
@@ -30,9 +31,9 @@
 #define EARTHRADIUS 6371000.
 /* undefined value for terrain aspect */
-#define UNDEF    0.
+#define UNDEF    0.
 /* internal undefined value for NULL */
-#define UNDEFZ   -9999.
+#define UNDEFZ   -9999.
 /* Constant for calculating angular loss */
 #define a_r 0.155
@@ -42,9 +43,9 @@
 extern int arrayNumInt;
-extern double xp;
-extern double yp;
+   extern double xp;
+   extern double yp;
 extern double angular_loss_denom;
@@ -59,4 +60,3 @@
 extern void (*func) (int, int);
Modified: grass/trunk/raster/r.sun2/rsunlib.c
--- grass/trunk/raster/r.sun2/rsunlib.c	2009-02-20 00:04:28 UTC (rev 35964)
+++ grass/trunk/raster/r.sun2/rsunlib.c	2009-02-20 00:07:47 UTC (rev 35965)
@@ -1,3 +1,4 @@
 r.sun: rsunlib.c. This program was writen by Jaro Hofierka in Summer 1993 and re-engineered
@@ -40,122 +41,121 @@
 int civilTimeFlag;
 int useCivilTime()
-	return civilTimeFlag;
+    return civilTimeFlag;
-	civilTimeFlag=val;
+    civilTimeFlag = val;
 void setAngularLossDenominator()
-	angular_loss_denom=1./(1-exp(-1./a_r));
+    angular_loss_denom = 1. / (1 - exp(-1. / a_r));
 int useShadowFlag;
 int useShadow()
-	return useShadowFlag;
+    return useShadowFlag;
 void setUseShadow(int val)
-	useShadowFlag=val;
+    useShadowFlag = val;
 int useHorizonDataFlag;
 int useHorizonData()
-	return useHorizonDataFlag;
+    return useHorizonDataFlag;
 void setUseHorizonData(int val)
-	useHorizonDataFlag=val;
+    useHorizonDataFlag = val;
 double timeOffset;
 double getTimeOffset()
-	return timeOffset;
+    return timeOffset;
 void setTimeOffset(double val)
-	timeOffset=val;
+    timeOffset = val;
 double horizonInterval;
 double getHorizonInterval()
-	return horizonInterval;
+    return horizonInterval;
 void setHorizonInterval(double val)
-	horizonInterval=val;
+    horizonInterval = val;
 double com_sol_const(int no_of_day)
-		double I0, d1;
+    double I0, d1;
-		/*  v W/(m*m) */
-		d1 = pi2 * no_of_day / 365.25;
-		I0 = 1367. * (1 + 0.03344 * cos(d1 - 0.048869));
+    /*  v W/(m*m) */
+    d1 = pi2 * no_of_day / 365.25;
+    I0 = 1367. * (1 + 0.03344 * cos(d1 - 0.048869));
-		return I0;
+    return I0;
-	double pom;
-	double totOffsetTime;
+    double pom;
+    double totOffsetTime;
-	sungeom->lum_C11 = gridGeom->sinlat * sungeom->cosdecl;
-	sungeom->lum_C13 = -gridGeom->coslat * sungeom->sindecl;
-	sungeom->lum_C22 = sungeom->cosdecl;
-	sungeom->lum_C31 = gridGeom->coslat * sungeom->cosdecl;
-	sungeom->lum_C33 = gridGeom->sinlat * sungeom->sindecl;
+    sungeom->lum_C11 = gridGeom->sinlat * sungeom->cosdecl;
+    sungeom->lum_C13 = -gridGeom->coslat * sungeom->sindecl;
+    sungeom->lum_C22 = sungeom->cosdecl;
+    sungeom->lum_C31 = gridGeom->coslat * sungeom->cosdecl;
+    sungeom->lum_C33 = gridGeom->sinlat * sungeom->sindecl;
     if (fabs(sungeom->lum_C31) >= EPS) {
-        totOffsetTime = timeOffset + longitTime;
-        if(useCivilTime())
-            sungeom->timeAngle -= totOffsetTime*HOURANGLE;
-    	pom = -sungeom->lum_C33 / sungeom->lum_C31;
-    	if (fabs(pom) <= 1) {
-        	pom = acos(pom);
-        	pom = (pom * 180) / M_PI;
-        	sungeom->sunrise_time = (90 - pom) / 15 + 6;
-        	sungeom->sunset_time = (pom - 90) / 15 + 18;
-        else {
-            if (pom < 0) {
-                /*        G_debug(3,"\n Sun is ABOVE the surface during the whole day"); */
-                sungeom->sunrise_time = 0;
-                sungeom->sunset_time = 24;
-            else {
-            /*                G_debug(3,"\n The sun is BELOW the surface during the whole day"); */
-                if (fabs(pom) - 1 <= EPS) {
-                    sungeom->sunrise_time = 12;
-                    sungeom->sunset_time = 12;
+	totOffsetTime = timeOffset + longitTime;
+	if (useCivilTime()) {
+	    sungeom->timeAngle -= totOffsetTime * HOURANGLE;
+	pom = -sungeom->lum_C33 / sungeom->lum_C31;
+	if (fabs(pom) <= 1) {
+	    pom = acos(pom);
+	    pom = (pom * 180) / M_PI;
+	    sungeom->sunrise_time = (90 - pom) / 15 + 6;
+	    sungeom->sunset_time = (pom - 90) / 15 + 18;
+	else {
+	    if (pom < 0) {
+		/*        G_debug(3,"\n Sun is ABOVE the surface during the whole day"); */
+		sungeom->sunrise_time = 0;
+		sungeom->sunset_time = 24;
+	    else {
+		/*                G_debug(3,"\n The sun is BELOW the surface during the whole day"); */
+		if (fabs(pom) - 1 <= EPS) {
+		    sungeom->sunrise_time = 12;
+		    sungeom->sunset_time = 12;
@@ -164,536 +164,539 @@
-	      struct SunGeometryVarDay *sunVarGeom, struct GridGeometry *gridGeom,
+	     struct GridGeometry *gridGeom, double latitude, double longitude)
-	double pom, xpom, ypom;
+    double pom, xpom, ypom;
-	double costimeAngle;
-	double lum_Lx, lum_Ly;
+    double costimeAngle;
+    double lum_Lx, lum_Ly;
-	double newLatitude, newLongitude;
-	double inputAngle;
-   	double delt_lat, delt_lon;
-   	double delt_east, delt_nor;
-	double delt_dist;
+    double newLatitude, newLongitude;
+    double inputAngle;
+    double delt_lat, delt_lon;
+    double delt_east, delt_nor;
+    double delt_dist;
-	costimeAngle = cos(sungeom->timeAngle);
+    costimeAngle = cos(sungeom->timeAngle);
-	lum_Lx = -sungeom->lum_C22 * sin(sungeom->timeAngle);
-	lum_Ly = sungeom->lum_C11 * costimeAngle + sungeom->lum_C13;
-	sunVarGeom->sinSolarAltitude = sungeom->lum_C31 * costimeAngle + sungeom->lum_C33;
+    lum_Lx = -sungeom->lum_C22 * sin(sungeom->timeAngle);
+    lum_Ly = sungeom->lum_C11 * costimeAngle + sungeom->lum_C13;
+    sunVarGeom->sinSolarAltitude =
+	sungeom->lum_C31 * costimeAngle + sungeom->lum_C33;
-	if (fabs(sungeom->lum_C31) < EPS)
-		if (fabs(sunVarGeom->sinSolarAltitude) >= EPS)
-			if (sunVarGeom->sinSolarAltitude > 0)
-        		/*                        G_debug(3,"\tSun is ABOVE area during the whole day"); */
-            		else
-        			sunVarGeom->solarAltitude = 0.;
-        			sunVarGeom->solarAzimuth = UNDEF;
-        			return;
-        	else
-            /*                      G_debug(3,"\tThe Sun is ON HORIZON during the whole day"); */
+    if (fabs(sungeom->lum_C31) < EPS) {
+	if (fabs(sunVarGeom->sinSolarAltitude) >= EPS) {
+	    if (sunVarGeom->sinSolarAltitude > 0) {
+		/*                        G_debug(3,"\tSun is ABOVE area during the whole day"); */
+	    else {
+		sunVarGeom->solarAltitude = 0.;
+		sunVarGeom->solarAzimuth = UNDEF;
+		return;
+	else {
+	    /*                      G_debug(3,"\tThe Sun is ON HORIZON during the whole day"); */
-	sunVarGeom->solarAltitude = asin(sunVarGeom->sinSolarAltitude);        /* vertical angle of the sun */
-	/* sinSolarAltitude is sin(solarAltitude) */
+    sunVarGeom->solarAltitude = asin(sunVarGeom->sinSolarAltitude);	/* vertical angle of the sun */
+    /* sinSolarAltitude is sin(solarAltitude) */
-	xpom = lum_Lx * lum_Lx;
-	ypom = lum_Ly * lum_Ly;
-	pom = sqrt(xpom + ypom);
+    xpom = lum_Lx * lum_Lx;
+    ypom = lum_Ly * lum_Ly;
+    pom = sqrt(xpom + ypom);
-	if (fabs(pom) > EPS)
-        	sunVarGeom->solarAzimuth = lum_Ly / pom;
-        	sunVarGeom->solarAzimuth = acos(sunVarGeom->solarAzimuth);        /* horiz. angle of the Sun */
-        /*                      solarAzimuth *= RAD; */
-        	if (lum_Lx < 0)
-            		sunVarGeom->solarAzimuth = pi2 - sunVarGeom->solarAzimuth;
-    	else
+    if (fabs(pom) > EPS) {
+	sunVarGeom->solarAzimuth = lum_Ly / pom;
+	sunVarGeom->solarAzimuth = acos(sunVarGeom->solarAzimuth);	/* horiz. angle of the Sun */
+	/*                      solarAzimuth *= RAD; */
+	if (lum_Lx < 0)
+	    sunVarGeom->solarAzimuth = pi2 - sunVarGeom->solarAzimuth;
+    else {
-    	if (sunVarGeom->solarAzimuth < 0.5 * M_PI)
-        	sunVarGeom->sunAzimuthAngle = 0.5 * M_PI - sunVarGeom->solarAzimuth;
-    	else
-        	sunVarGeom->sunAzimuthAngle = 2.5 * M_PI - sunVarGeom->solarAzimuth;
+    if (sunVarGeom->solarAzimuth < 0.5 * M_PI)
+	sunVarGeom->sunAzimuthAngle = 0.5 * M_PI - sunVarGeom->solarAzimuth;
+    else
+	sunVarGeom->sunAzimuthAngle = 2.5 * M_PI - sunVarGeom->solarAzimuth;
-	inputAngle=sunVarGeom->sunAzimuthAngle+pihalf;
-	inputAngle=(inputAngle>=pi2)?inputAngle-pi2:inputAngle;
+    inputAngle = sunVarGeom->sunAzimuthAngle + pihalf;
+    inputAngle = (inputAngle >= pi2) ? inputAngle - pi2 : inputAngle;
-	delt_lat = -0.0001*cos(inputAngle); /* Arbitrary small distance in latitude */
-	delt_lon = 0.0001*sin(inputAngle)/cos(latitude);
+    delt_lat = -0.0001 * cos(inputAngle);	/* Arbitrary small distance in latitude */
+    delt_lon = 0.0001 * sin(inputAngle) / cos(latitude);
-	newLatitude = (latitude+delt_lat)*rad2deg;
-	newLongitude = (longitude+delt_lon)*rad2deg;
+    newLatitude = (latitude + delt_lat) * rad2deg;
+    newLongitude = (longitude + delt_lon) * rad2deg;
-	if ((G_projection() != PROJECTION_LL))
-	        if (pj_do_proj(&newLongitude, &newLatitude, &oproj, &iproj) <0)
+    if ((G_projection() != PROJECTION_LL)) {
+	if (pj_do_proj(&newLongitude, &newLatitude, &oproj, &iproj) < 0) {
-	delt_east=newLongitude-gridGeom->xp;
-	delt_nor=newLatitude-gridGeom->yp;
+    delt_east = newLongitude - gridGeom->xp;
+    delt_nor = newLatitude - gridGeom->yp;
-	delt_dist=sqrt(delt_east*delt_east+delt_nor*delt_nor);
+    delt_dist = sqrt(delt_east * delt_east + delt_nor * delt_nor);
-	sunVarGeom->stepsinangle = gridGeom->stepxy*delt_nor/delt_dist;
-	sunVarGeom->stepcosangle = gridGeom->stepxy*delt_east/delt_dist;
+    sunVarGeom->stepsinangle = gridGeom->stepxy * delt_nor / delt_dist;
+    sunVarGeom->stepcosangle = gridGeom->stepxy * delt_east / delt_dist;
-	sunVarGeom->stepsinangle = stepxy * sin(sunVarGeom->sunAzimuthAngle);
-	sunVarGeom->stepcosangle = stepxy * cos(sunVarGeom->sunAzimuthAngle);
-	sunVarGeom->tanSolarAltitude = tan(sunVarGeom->solarAltitude);
+       sunVarGeom->stepsinangle = stepxy * sin(sunVarGeom->sunAzimuthAngle);
+       sunVarGeom->stepcosangle = stepxy * cos(sunVarGeom->sunAzimuthAngle);
+    sunVarGeom->tanSolarAltitude = tan(sunVarGeom->solarAltitude);
-	return;
+    return;
-	double z2;
-	double curvature_diff;
-	int succes = 0;
+    double z2;
+    double curvature_diff;
+    int succes = 0;
-	if (sunVarGeom->zp == UNDEFZ)
-		return 0;
+    if (sunVarGeom->zp == UNDEFZ)
+	return 0;
-	gridGeom->yy0 += sunVarGeom->stepsinangle;
-	gridGeom->xx0 += sunVarGeom->stepcosangle;
-	if (((gridGeom->xx0+(0.5*gridGeom->stepx)) < 0)
-		|| ((gridGeom->xx0+(0.5*gridGeom->stepx)) > gridGeom->deltx)
-		|| ((gridGeom->yy0+(0.5*gridGeom->stepy)) < 0)
-		|| ((gridGeom->yy0+(0.5*gridGeom->stepy)) > gridGeom->delty))
-		succes=3;
-	else
-		succes=1;
+    gridGeom->yy0 += sunVarGeom->stepsinangle;
+    gridGeom->xx0 += sunVarGeom->stepcosangle;
+    if (((gridGeom->xx0 + (0.5 * gridGeom->stepx)) < 0)
+	|| ((gridGeom->xx0 + (0.5 * gridGeom->stepx)) > gridGeom->deltx)
+	|| ((gridGeom->yy0 + (0.5 * gridGeom->stepy)) < 0)
+	|| ((gridGeom->yy0 + (0.5 * gridGeom->stepy)) > gridGeom->delty))
+	succes = 3;
+    else
+	succes = 1;
-	if (succes == 1)
-		where_is_point(length, sunVarGeom,gridGeom);
-		if (func == NULL)
-			gridGeom->xx0 = gridGeom->xg0;
-			gridGeom->yy0 = gridGeom->yg0;
-			return (3);
-		curvature_diff = EARTHRADIUS*(1.-cos(*length/EARTHRADIUS));
-		z2 = sunVarGeom->z_orig + curvature_diff + *length * sunVarGeom->tanSolarAltitude;
-		if (z2 < sunVarGeom->zp)
-			succes = 2;        /* shadow */
-		if (z2 > sunVarGeom->zmax)
-			succes = 3;        /* no test needed all visible */
+    if (succes == 1) {
+	where_is_point(length, sunVarGeom, gridGeom);
+	if (func == NULL) {
+	    gridGeom->xx0 = gridGeom->xg0;
+	    gridGeom->yy0 = gridGeom->yg0;
+	    return (3);
+	curvature_diff = EARTHRADIUS * (1. - cos(*length / EARTHRADIUS));
-	if(succes!=1)
-	return (succes);
+	z2 = sunVarGeom->z_orig + curvature_diff +
+	if (z2 < sunVarGeom->zp)
+	    succes = 2;		/* shadow */
+	if (z2 > sunVarGeom->zmax)
+	    succes = 3;		/* no test needed all visible */
+    if (succes != 1) {
+    return (succes);
-double lumcline2(
-	struct SunGeometryConstDay *sungeom,
-	double s = 0;
-	double length;
-	int r = 0;
+double lumcline2(struct SunGeometryConstDay *sungeom,
+		 struct GridGeometry *gridGeom, unsigned char *horizonpointer)
+    double s = 0;
+    double length;
+    int r = 0;
-	int lowPos, highPos;
-	double timeoffset, horizPos;
-	double horizonHeight;
+    int lowPos, highPos;
+    double timeoffset, horizPos;
+    double horizonHeight;
-	func = cube;
-	sunVarGeom->isShadow = 0;
+    func = cube;
+    sunVarGeom->isShadow = 0;
-	if (useShadow())
-        	length = 0;
-		if(useHorizonData())
-			/* Start is due east, sungeom->timeangle = -pi/2 */
-		timeoffset = sungeom->timeAngle+pihalf;
-		timeoffset = sunVarGeom->sunAzimuthAngle;
+    if (useShadow()) {
+	length = 0;
-		if(timeoffset<0.)
-			timeoffset+=pi2;
-		else if(timeoffset>pi2)
-			timeoffset-=pi2;
-		horizPos = arrayNumInt - timeoffset/horizonInterval;
-			horizPos = timeoffset/getHorizonInterval();
+	if (useHorizonData()) {
+	    /* Start is due east, sungeom->timeangle = -pi/2 */
+	       timeoffset = sungeom->timeAngle+pihalf;
+	    timeoffset = sunVarGeom->sunAzimuthAngle;
+	       if(timeoffset<0.)
+	       timeoffset+=pi2;
+	       else if(timeoffset>pi2)
+	       timeoffset-=pi2;
+	       horizPos = arrayNumInt - timeoffset/horizonInterval;
-			lowPos = (int)horizPos;
-			highPos=lowPos+1;
-			if(highPos==arrayNumInt)
-				highPos=0;
-			horizonHeight = invScale*(
-				(1.-(horizPos-lowPos))*horizonpointer[lowPos]
-				+(horizPos-lowPos)
-				*horizonpointer[highPos]);
-			sunVarGeom->isShadow = (horizonHeight>sunVarGeom->solarAltitude);
+	    horizPos = timeoffset / getHorizonInterval();
-              		if (!sunVarGeom->isShadow)
-                		if (z_orig != UNDEFZ)
-  		                	s = sunSlopeGeom->lum_C31_l * cos(-sungeom->timeAngle - sunSlopeGeom->longit_l) + sunSlopeGeom->lum_C33_l;
-                		else
-		                	s = sunVarGeom->sinSolarAltitude;
-	                	s = sunSlopeGeom->lum_C31_l * cos(-sungeom->timeAngle - sunSlopeGeom->longit_l) + sunSlopeGeom->lum_C33_l; /* Jenco */
+	    lowPos = (int)horizPos;
+	    highPos = lowPos + 1;
+	    if (highPos == arrayNumInt) {
+		highPos = 0;
+	    horizonHeight = invScale * ((1. -
+					 (horizPos -
+					  lowPos)) * horizonpointer[lowPos]
+					+ (horizPos - lowPos)
+					* horizonpointer[highPos]);
+		(horizonHeight > sunVarGeom->solarAltitude);
+	    if (!sunVarGeom->isShadow) {
+		   if (z_orig != UNDEFZ)
+		   s = sunSlopeGeom->lum_C31_l * cos(-sungeom->timeAngle - sunSlopeGeom->longit_l) + sunSlopeGeom->lum_C33_l;
-			}  /*  End if useHorizonData() */
-	        else
-	       		while ((r = searching(&length, sunVarGeom, gridGeom)) == 1)
-				if (r == 3)
-            				break;        /* no test is needed */
+		   else
+		   s = sunVarGeom->sinSolarAltitude;
+		s = sunSlopeGeom->lum_C31_l * cos(-sungeom->timeAngle - sunSlopeGeom->longit_l) + sunSlopeGeom->lum_C33_l;	/* Jenco */
+	}			/*  End if useHorizonData() */
+	else {
+	    while ((r = searching(&length, sunVarGeom, gridGeom)) == 1) {
+		if (r == 3)
+		    break;	/* no test is needed */
-	                  if (r == 2)
-				sunVarGeom->isShadow = 1; /* shadow */
-			   else
-		                else
-        else
+	    if (r == 2) {
+		sunVarGeom->isShadow = 1;	/* shadow */
+	    else {
-            	else
-      	if (s < 0) return 0.;
-      	return (s);
+		   else
+    else {
+	   else
+    if (s < 0)
+	return 0.;
+    return (s);
 double brad(double sh, double *bh, struct SunGeometryVarDay *sunVarGeom,
-	double opticalAirMass, airMass2Linke, rayl, br;
-	double drefract, temp1, temp2, h0refract;
-	double elevationCorr;
+    double opticalAirMass, airMass2Linke, rayl, br;
+    double drefract, temp1, temp2, h0refract;
+    double elevationCorr;
-	double locSolarAltitude;
-	locSolarAltitude=sunVarGeom->solarAltitude;
+    double locSolarAltitude;
+    locSolarAltitude = sunVarGeom->solarAltitude;
-	elevationCorr = exp(-sunVarGeom->z_orig / 8434.5);
-	temp1 = 0.1594 + locSolarAltitude * (1.123 + 0.065656 * locSolarAltitude);
-	temp2 = 1. + locSolarAltitude * (28.9344 + 277.3971 * locSolarAltitude);
-	drefract = 0.061359 * temp1 / temp2;    /* in radians */
-	h0refract = locSolarAltitude + drefract;
-	opticalAirMass = elevationCorr / (sin(h0refract) +
-	  0.50572 * pow(h0refract * rad2deg + 6.07995, -1.6364));
-	airMass2Linke = 0.8662 * sunRadVar->linke;
-	if (opticalAirMass <= 20.)
-		rayl = 1. / (6.6296 +
-	  		opticalAirMass * (1.7513 +
-	    		opticalAirMass * (-0.1202 + opticalAirMass * (0.0065 - opticalAirMass * 0.00013))));
-	else
-		rayl = 1. / (10.4 + 0.718 * opticalAirMass);
-	*bh = sunRadVar->cbh * sunRadVar->G_norm_extra * sunVarGeom->sinSolarAltitude * exp(-rayl * opticalAirMass * airMass2Linke);
-	if (sunSlopeGeom->aspect != UNDEF && sunSlopeGeom->slope != 0.)
-		br = *bh * sh / sunVarGeom->sinSolarAltitude;
-	else
-		br = *bh;
-	return (br);
+    elevationCorr = exp(-sunVarGeom->z_orig / 8434.5);
+    temp1 = 0.1594 + locSolarAltitude * (1.123 + 0.065656 * locSolarAltitude);
+    temp2 = 1. + locSolarAltitude * (28.9344 + 277.3971 * locSolarAltitude);
+    drefract = 0.061359 * temp1 / temp2;	/* in radians */
+    h0refract = locSolarAltitude + drefract;
+    opticalAirMass = elevationCorr / (sin(h0refract) +
+				      0.50572 * pow(h0refract * rad2deg +
+    airMass2Linke = 0.8662 * sunRadVar->linke;
+    if (opticalAirMass <= 20.) {
+	rayl = 1. / (6.6296 +
+		     opticalAirMass * (1.7513 +
+				       opticalAirMass * (-0.1202 +
+							 opticalAirMass *
+							 (0.0065 -
+							  opticalAirMass *
+							  0.00013))));
+    else {
+	rayl = 1. / (10.4 + 0.718 * opticalAirMass);
+    *bh =
+	sunRadVar->cbh * sunRadVar->G_norm_extra *
+	sunVarGeom->sinSolarAltitude * exp(-rayl * opticalAirMass *
+					   airMass2Linke);
+    if (sunSlopeGeom->aspect != UNDEF && sunSlopeGeom->slope != 0.)
+	br = *bh * sh / sunVarGeom->sinSolarAltitude;
+    else
+	br = *bh;
+    return (br);
-double brad_angle_loss(double sh, double *bh, struct SunGeometryVarDay *sunVarGeom,
+double brad_angle_loss(double sh, double *bh,
-	double p, opticalAirMass, airMass2Linke, rayl, br;
+    double p, opticalAirMass, airMass2Linke, rayl, br;
-	p = exp(-sunVarGeom->z_orig / 8434.5);
-	opticalAirMass = p / (sin(h0refract) +
-		rayl =
-				1. / (6.6296 +
-	else
-	else
-		br = *bh;
-	br *= (1-exp(-sh/a_r))*angular_loss_denom;
-	return (br);
+    p = exp(-sunVarGeom->z_orig / 8434.5);
+    opticalAirMass = p / (sin(h0refract) +
+			  0.50572 * pow(h0refract * rad2deg + 6.07995,
+					-1.6364));
+	rayl =
+	    1. / (6.6296 +
+						      opticalAirMass *
+						      (0.0065 -
+						       opticalAirMass *
+						       0.00013))));
+    else
+    *bh =
+					   airMass2Linke);
+    else
+	br = *bh;
+    br *= (1 - exp(-sh / a_r)) * angular_loss_denom;
+    return (br);
-double drad(double sh, double bh, double *rr, struct SunGeometryVarDay *sunVarGeom,
+double drad(double sh, double bh, double *rr,
     double tn, fd, fx = 0., A1, A2, A3, A1b;
     double r_sky, kb, dr, gh, a_ln, ln, fg;
     double dh;
     double cosslope, sinslope;
-	double locSinSolarAltitude;
-	double locLinke;
-	locLinke = sunRadVar->linke;
-	locSinSolarAltitude=sunVarGeom->sinSolarAltitude;
+    double locSinSolarAltitude;
+    double locLinke;
+    locLinke = sunRadVar->linke;
+    locSinSolarAltitude = sunVarGeom->sinSolarAltitude;
     cosslope = cos(sunSlopeGeom->slope);
     sinslope = sin(sunSlopeGeom->slope);
     tn = -0.015843 + locLinke * (0.030543 + 0.0003797 * locLinke);
     A1b = 0.26463 + locLinke * (-0.061581 + 0.0031408 * locLinke);
     if (A1b * tn < 0.0022)
-        A1 = 0.0022 / tn;
+	A1 = 0.0022 / tn;
     else
-        A1 = A1b;
+	A1 = A1b;
     A2 = 2.04020 + locLinke * (0.018945 - 0.011161 * locLinke);
     A3 = -1.3025 + locLinke * (0.039231 + 0.0085079 * locLinke);
-    fd = A1 + A2 * locSinSolarAltitude + A3 * locSinSolarAltitude * locSinSolarAltitude;
+    fd = A1 + A2 * locSinSolarAltitude +
     dh = sunRadVar->cdh * sunRadVar->G_norm_extra * fd * tn;
     gh = bh + dh;
     if (sunSlopeGeom->aspect != UNDEF && sunSlopeGeom->slope != 0.) {
-        kb = bh / (sunRadVar->G_norm_extra * locSinSolarAltitude);
-    	r_sky = (1. + cosslope) / 2.;
-    	a_ln = sunVarGeom->solarAzimuth - sunSlopeGeom->aspect;
-    	ln = a_ln;
-    	if (a_ln > M_PI)
-        	ln = a_ln - pi2;
-    	else if (a_ln < -M_PI)
-        	ln = a_ln + pi2;
-    	a_ln = ln;
-    	fg = sinslope - sunSlopeGeom->slope * cosslope -
-        	M_PI * sin(0.5*sunSlopeGeom->slope) * sin(0.5*sunSlopeGeom->slope);
-    	if ((sunVarGeom->isShadow == 1) || sh <= 0.)
-        	fx = r_sky + fg * 0.252271;
-    	else if (sunVarGeom->solarAltitude >= 0.1) {
-        	fx = ((0.00263 - kb * (0.712 + 0.6883 * kb)) * fg + r_sky) * (1. -
-                                    	  kb) +
-        	kb * sh / locSinSolarAltitude;
-    	else if (sunVarGeom->solarAltitude < 0.1)
-        	fx = ((0.00263 - 0.712 * kb - 0.6883 * kb * kb) * fg +
-        	  r_sky) * (1. - kb) + kb * sinslope * cos(a_ln) / (0.1 -
-                                    	  0.008 *
-                                    	  sunVarGeom->solarAltitude);
-    	dr = dh * fx;
-    	/* refl. rad */
-    	*rr = sunRadVar->alb * gh * (1 - cosslope) / 2.;
+	kb = bh / (sunRadVar->G_norm_extra * locSinSolarAltitude);
+	r_sky = (1. + cosslope) / 2.;
+	a_ln = sunVarGeom->solarAzimuth - sunSlopeGeom->aspect;
+	ln = a_ln;
+	if (a_ln > M_PI)
+	    ln = a_ln - pi2;
+	else if (a_ln < -M_PI)
+	    ln = a_ln + pi2;
+	a_ln = ln;
+	fg = sinslope - sunSlopeGeom->slope * cosslope -
+	    M_PI * sin(0.5 * sunSlopeGeom->slope) * sin(0.5 *
+							sunSlopeGeom->slope);
+	if ((sunVarGeom->isShadow == 1) || sh <= 0.)
+	    fx = r_sky + fg * 0.252271;
+	else if (sunVarGeom->solarAltitude >= 0.1) {
+	    fx = ((0.00263 - kb * (0.712 + 0.6883 * kb)) * fg + r_sky) * (1. -
+									  kb)
+		+ kb * sh / locSinSolarAltitude;
+	else if (sunVarGeom->solarAltitude < 0.1)
+	    fx = ((0.00263 - 0.712 * kb - 0.6883 * kb * kb) * fg +
+		  r_sky) * (1. - kb) + kb * sinslope * cos(a_ln) / (0.1 -
+								    0.008 *
+								    sunVarGeom->
+								    solarAltitude);
+	dr = dh * fx;
+	/* refl. rad */
+	*rr = sunRadVar->alb * gh * (1 - cosslope) / 2.;
-    else {            /* plane */
-        dr = dh;
-        *rr = 0.;
+    else {			/* plane */
+	dr = dh;
+	*rr = 0.;
     return (dr);
 #define c2 -0.074
-double drad_angle_loss(double sh, double bh, double *rr, struct SunGeometryVarDay *sunVarGeom,
+double drad_angle_loss(double sh, double bh, double *rr,
-	double dh;
-	double tn, fd, fx = 0., A1, A2, A3, A1b;
-	double r_sky, kb, dr, gh, a_ln, ln, fg;
-	double cosslope, sinslope;
+    double dh;
+    double tn, fd, fx = 0., A1, A2, A3, A1b;
+    double r_sky, kb, dr, gh, a_ln, ln, fg;
+    double cosslope, sinslope;
-	double diff_coeff_angleloss;
-	double refl_coeff_angleloss;
-	double c1;
-	double diff_loss_factor, refl_loss_factor;
-	double locLinke;
-	cosslope = cos(sunSlopeGeom->slope);
-	sinslope = sin(sunSlopeGeom->slope);
+    double diff_coeff_angleloss;
+    double refl_coeff_angleloss;
+    double c1;
+    double diff_loss_factor, refl_loss_factor;
+    double locLinke;
+    cosslope = cos(sunSlopeGeom->slope);
+    sinslope = sin(sunSlopeGeom->slope);
-	tn = -0.015843 + locLinke * (0.030543 + 0.0003797 * locLinke);
-	A1b = 0.26463 + locLinke * (-0.061581 + 0.0031408 * locLinke);
-	if (A1b * tn < 0.0022)
-		A1 = 0.0022 / tn;
-	else
-		A1 = A1b;
-	A2 = 2.04020 + locLinke * (0.018945 - 0.011161 * locLinke);
-	A3 = -1.3025 + locLinke * (0.039231 + 0.0085079 * locLinke);
-	dh = sunRadVar->cdh * sunRadVar->G_norm_extra * fd * tn;
-	gh = bh + dh;
-	if (sunSlopeGeom->aspect != UNDEF && sunSlopeGeom->slope != 0.) {
-		ln = a_ln;
-		if (a_ln > M_PI)
-			ln = a_ln - pi2;
-			ln = a_ln + pi2;
-		a_ln = ln;
-				M_PI * sin(sunSlopeGeom->slope / 2.) * sin(sunSlopeGeom->slope / 2.);
-		if ((sunVarGeom->isShadow) || (sh <= 0.))
-					kb) +
-					0.008 *
-		dr = dh * fx;
-		/* refl. rad */
+    tn = -0.015843 + locLinke * (0.030543 + 0.0003797 * locLinke);
+    A1b = 0.26463 + locLinke * (-0.061581 + 0.0031408 * locLinke);
+    if (A1b * tn < 0.0022)
+	A1 = 0.0022 / tn;
+    else
+	A1 = A1b;
+    A2 = 2.04020 + locLinke * (0.018945 - 0.011161 * locLinke);
+    A3 = -1.3025 + locLinke * (0.039231 + 0.0085079 * locLinke);
+    dh = sunRadVar->cdh * sunRadVar->G_norm_extra * fd * tn;
+    gh = bh + dh;
+    if (sunSlopeGeom->aspect != UNDEF && sunSlopeGeom->slope != 0.) {
+	ln = a_ln;
+	if (a_ln > M_PI)
+	    ln = a_ln - pi2;
+	    ln = a_ln + pi2;
+	a_ln = ln;
+	    M_PI * sin(sunSlopeGeom->slope / 2.) * sin(sunSlopeGeom->slope /
+						       2.);
+	if ((sunVarGeom->isShadow) || (sh <= 0.))
+									  kb)
-		dr = dh;
-		*rr = 0.;
+								    0.008 *
+								    sunVarGeom->
+								    solarAltitude);
+	dr = dh * fx;
+	/* refl. rad */
+	dr = dh;
+	*rr = 0.;
-	c1 = 4./(3.*M_PI);
-	diff_coeff_angleloss = sinslope
-			+ (M_PI-sunSlopeGeom->slope-sinslope)/(1+cosslope);
-	refl_coeff_angleloss = sinslope
-			+ (sunSlopeGeom->slope-sinslope)/(1-cosslope);
-	diff_loss_factor
-			= 1. - exp(-(c1*diff_coeff_angleloss
-			+c2*diff_coeff_angleloss*diff_coeff_angleloss)
-			/a_r);
-	refl_loss_factor
-			= 1. - exp(-(c1*refl_coeff_angleloss
-			+c2*refl_coeff_angleloss*refl_coeff_angleloss)
-			/a_r);
-	dr *= diff_loss_factor;
-	*rr *= refl_loss_factor;
+    c1 = 4. / (3. * M_PI);
+    diff_coeff_angleloss = sinslope
+	+ (M_PI - sunSlopeGeom->slope - sinslope) / (1 + cosslope);
+    refl_coeff_angleloss = sinslope
+	+ (sunSlopeGeom->slope - sinslope) / (1 - cosslope);
+    diff_loss_factor
+	= 1. - exp(-(c1 * diff_coeff_angleloss
+		     + c2 * diff_coeff_angleloss * diff_coeff_angleloss)
+		   / a_r);
+    refl_loss_factor
+	= 1. - exp(-(c1 * refl_coeff_angleloss
+		     + c2 * refl_coeff_angleloss * refl_coeff_angleloss)
+		   / a_r);
+    dr *= diff_loss_factor;
+    *rr *= refl_loss_factor;
-	return (dr);
+    return (dr);
Modified: grass/trunk/raster/r.sun2/sunradstruct.h
--- grass/trunk/raster/r.sun2/sunradstruct.h	2009-02-20 00:04:28 UTC (rev 35964)
+++ grass/trunk/raster/r.sun2/sunradstruct.h	2009-02-20 00:07:47 UTC (rev 35965)
@@ -1,3 +1,4 @@
 r.sun: sunradstruct.h. This program was writen by Jaro Hofierka in Summer 1993 and re-engineered
@@ -32,78 +33,78 @@
 #define HOURANGLE M_PI/12.
-struct SunGeometryConstDay
-	double lum_C11;
-	double lum_C13;
-	double lum_C22;
-	double lum_C31;
-	double lum_C33;
-	double sunrise_time;
-	double sunset_time;
-	double timeAngle;
-	double sindecl;
-	double cosdecl;
+struct SunGeometryConstDay
+    double lum_C11;
+    double lum_C13;
+    double lum_C22;
+    double lum_C31;
+    double lum_C33;
+    double sunrise_time;
+    double sunset_time;
+    double timeAngle;
+    double sindecl;
+    double cosdecl;
-struct SunGeometryVarDay
-	int isShadow;
-	double z_orig;
-	double zmax;
-	double zp;
-	double solarAltitude;
-	double sinSolarAltitude;
-	double tanSolarAltitude;
-	double solarAzimuth;
-	double sunAzimuthAngle;
-	double stepsinangle;
-	double stepcosangle;
+struct SunGeometryVarDay
+    int isShadow;
+    double z_orig;
+    double zmax;
+    double zp;
+    double solarAltitude;
+    double sinSolarAltitude;
+    double tanSolarAltitude;
+    double solarAzimuth;
+    double sunAzimuthAngle;
+    double stepsinangle;
+    double stepcosangle;
-struct SunGeometryVarSlope
-	double longit_l; /* The "longitude" difference between the inclined */
-			/* and orientated plane and the instantaneous solar position */
-	double lum_C31_l;
-	double lum_C33_l;
-	double slope;
-	double aspect;
+struct SunGeometryVarSlope
+    double longit_l;		/* The "longitude" difference between the inclined */
+    /* and orientated plane and the instantaneous solar position */
+    double lum_C31_l;
+    double lum_C33_l;
+    double slope;
+    double aspect;
-struct SolarRadVar
-	double cbh;
-	double cdh;
-	double linke;
-	double G_norm_extra;
-	double alb;
+struct SolarRadVar
+    double cbh;
+    double cdh;
+    double linke;
+    double G_norm_extra;
+    double alb;
 struct GridGeometry
-	double xp;
-	double yp;
-	double xx0;
-	double yy0;
-	double xg0;
-	double yg0;
-	double stepx;
-	double stepy;
-	double deltx;
-	double delty;
-	double stepxy;
-	double sinlat;
-	double coslat;
+    double xp;
+    double yp;
+    double xx0;
+    double yy0;
+    double xg0;
+    double yg0;
+    double stepx;
+    double stepy;
+    double deltx;
+    double delty;
+    double stepxy;
+    double sinlat;
+    double coslat;
