[GRASS-SVN] r35981 -
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
svn_grass at osgeo.org
Fri Feb 20 07:08:37 EST 2009
Author: martinl
Date: 2009-02-20 07:08:37 -0500 (Fri, 20 Feb 2009)
New Revision: 35981
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/location_wizard.py
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/utils.py
wxGUI: fix MS Windows-related bugs in Location Wizard (osgeo4w #37)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/location_wizard.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/location_wizard.py 2009-02-20 11:20:23 UTC (rev 35980)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/location_wizard.py 2009-02-20 12:08:37 UTC (rev 35981)
@@ -37,6 +37,7 @@
import string
import sys
import locale
+import platform
import wx
import wx.lib.mixins.listctrl as listmix
@@ -261,6 +262,7 @@
"coordinate system (XY)"))
# layout
self.sizer.AddGrowableCol(1)
+ self.sizer.SetVGap(10)
self.sizer.Add(item=self.radio1,
flag=wx.ALIGN_LEFT, pos=(1, 1))
self.sizer.Add(item=self.radio2,
@@ -1238,7 +1240,7 @@
style=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL)
# text input
- epsgdir = os.path.join(os.environ["GRASS_PROJSHARE"], 'epsg')
+ epsgdir = utils.PathJoin(os.environ["GRASS_PROJSHARE"], 'epsg')
self.tfile = self.MakeTextCtrl(text=epsgdir, size=(200,-1))
self.tcode = self.MakeTextCtrl(size=(200,-1))
@@ -1397,9 +1399,10 @@
i = 0
code = None
for line in f.readlines():
line = line.strip()
+ if len(line) < 1:
+ continue
if line[0] == '#':
descr = line[1:].strip()
elif line[0] == '<':
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/utils.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/utils.py 2009-02-20 11:20:23 UTC (rev 35980)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/utils.py 2009-02-20 12:08:37 UTC (rev 35981)
@@ -16,6 +16,7 @@
import os
import sys
+import platform
import globalvar
grassPath = os.path.join(globalvar.ETCDIR, "python")
@@ -50,7 +51,7 @@
# FIXME
# ugly hack for MSYS (MS Windows)
- if subprocess.mswindows:
+ if platform.system() == 'Windows':
tempfile = tempfile.replace("/", "\\")
try:
path, file = os.path.split(tempfile)
@@ -322,6 +323,15 @@
return str(d) + ':' + m + ':' + s
+def PathJoin(*args):
+ """Check path created by os.path.join"""
+ path = os.path.join(*args)
+ if platform.system() == 'Windows' and \
+ '/' in path:
+ return path[1].upper() + ':\\' + path[3:].replace('/', '\\')
+ return path
def reexec_with_pythonw():
"""Re-execute Python on Mac OS"""
if sys.platform == 'darwin' and \
