[GRASS-SVN] r35987 - in
grass/branches/releasebranch_6_4/gui/wxpython: . gui_modules
svn_grass at osgeo.org
Fri Feb 20 12:48:14 EST 2009
Author: martinl
Date: 2009-02-20 12:48:13 -0500 (Fri, 20 Feb 2009)
New Revision: 35987
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/georect.py
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/location_wizard.py
grass/branches/releasebranch_6_4/gui/wxpython/wxgui.py
More wxGUI MS Windows-related issues fixed
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/georect.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/georect.py 2009-02-20 15:20:47 UTC (rev 35986)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/georect.py 2009-02-20 17:48:13 UTC (rev 35987)
@@ -90,10 +90,12 @@
try:
f = open(self.orig_gisrc, 'r')
for line in f.readlines():
- if line != '':
- line = line.replace('\n', '').strip()
- key, value = line.split(':')
- self.gisrc_dict[key.strip()] = value.strip()
+ line = line.replace('\n', '').strip()
+ if len(line) < 1:
+ continue
+ print line
+ key, value = line.split(':', 1)
+ self.gisrc_dict[key.strip()] = value.strip()
finally:
f.close()
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/location_wizard.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/location_wizard.py 2009-02-20 15:20:47 UTC (rev 35986)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/location_wizard.py 2009-02-20 17:48:13 UTC (rev 35987)
@@ -1,35 +1,35 @@
-MODULE: location_wizard.py
+ at package location_wizard.py
-CLASSES:
- * BaseClass
- * TitledPage
- * DatabasePage
- * CoordinateSystemPage
- * ProjectionsPage
- * ItemList
- * ProjTypePage
- * DatumPage
- * EllipsePage
- * GeoreferencedFilePage
- * EPSGPage
- * CustomPage
- * SummaryPage
- * RegionDef
- * LocationWizard
- * SelectDatumDialog
+ at brief Location wizard - creates a new GRASS Location. User can choose
+from multiple methods.
-PURPOSE: Create a new GRASS Location. User can choose from multiple methods.
+Classes:
+ - BaseClass
+ - TitledPage
+ - DatabasePage
+ - CoordinateSystemPage
+ - ProjectionsPage
+ - ItemList
+ - ProjTypePage
+ - DatumPage
+ - EllipsePage
+ - GeoreferencedFilePage
+ - EPSGPage
+ - CustomPage
+ - SummaryPage
+ - RegionDef
+ - LocationWizard
+ - SelectDatumDialog
-AUTHORS: The GRASS Development Team
- Michael Barton
- Jachym Cepicky
- Martin Landa <landa.martin gmail.com>
-COPYRIGHT: (C) 2006-2007 by the GRASS Development Team
+COPYRIGHT: (C) 2007-2009 by the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
for details.
+ at author Michael Barton
+ at author Jachym Cepicky
+ at author Martin Landa <landa.martin gmail.com>
import os
import shutil
@@ -73,19 +73,25 @@
def __init__(self):
pass
- def MakeLabel(self, text="", style=wx.ALIGN_LEFT):
+ def MakeLabel(self, text="", style=wx.ALIGN_LEFT, parent=None):
"""Make aligned label"""
- return wx.StaticText(parent=self, id=wx.ID_ANY, label=text,
+ if not parent:
+ parent = self
+ return wx.StaticText(parent=parent, id=wx.ID_ANY, label=text,
style=style)
- def MakeTextCtrl(self, text='', size=(100,-1), style=0):
+ def MakeTextCtrl(self, text='', size=(100,-1), style=0, parent=None):
"""Generic text control"""
- return wx.TextCtrl(parent=self, id=wx.ID_ANY, value=text,
+ if not parent:
+ parent = self
+ return wx.TextCtrl(parent=parent, id=wx.ID_ANY, value=text,
size=size, style=style)
- def MakeButton(self, text, id=wx.ID_ANY, size=(-1,-1)):
+ def MakeButton(self, text, id=wx.ID_ANY, size=(-1,-1), parent=None):
"""Generic button"""
- return wx.Button(parent=self, id=id, label=text,
+ if not parent:
+ parent = self
+ return wx.Button(parent=parent, id=id, label=text,
size=size)
class TitledPage(BaseClass, wiz.WizardPageSimple):
@@ -1392,7 +1398,8 @@
def OnBrowseCodes(self, event, search=None):
"""Browse EPSG codes"""
- try:
+# try:
+ if True:
data = []
self.epsgCodeDict = {}
f = open(self.tfile.GetValue(), "r")
@@ -1417,11 +1424,11 @@
f.close()
self.epsglist.Populate(data, update=True)
- except StandardError, e:
- wx.MessageBox(parent=self,
- message=_("Unable to read EPGS codes: %s") % e,
- caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
- self.epsglist.Populate([], update=True)
+# except StandardError, e:
+# wx.MessageBox(parent=self,
+# message=_("Unable to read EPGS codes: %s") % e,
+# caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+# self.epsglist.Populate([], update=True)
class CustomPage(TitledPage):
@@ -1731,7 +1738,7 @@
if dlg.ShowModal() == wx.ID_YES:
dlg.Destroy()
defineRegion = RegionDef(self.parent, location=self.location)
- defineRegion.Centre()
+ defineRegion.CenterOnScreen()
defineRegion.Show()
else:
dlg.Destroy()
@@ -2147,16 +2154,18 @@
Page for setting default region extents and resolution
def __init__(self, parent, id=wx.ID_ANY,
title=_("Set default region extent and resolution"), location=None):
wx.Frame.__init__(self, parent, id, title, size=(650,300))
+ panel = wx.Panel(self, id=wx.ID_ANY)
+ self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
self.parent = parent
self.location = location
- # values
+ # default values
# 2D
self.north = 1.0
@@ -2171,38 +2180,38 @@
# self.nsres3 = 1.0
# self.ewres3 = 1.0
self.tbres = 1.0
# inputs
# 2D
- self.tnorth = self.MakeTextCtrl(str(self.north), size=(150, -1))
- self.tsouth = self.MakeTextCtrl(str(self.south), size=(150, -1))
- self.twest = self.MakeTextCtrl(str(self.west), size=(150, -1))
- self.teast = self.MakeTextCtrl(str(self.east), size=(150, -1))
- self.tnsres = self.MakeTextCtrl(str(self.nsres), size=(150, -1))
- self.tewres = self.MakeTextCtrl(str(self.ewres), size=(150, -1))
+ self.tnorth = self.MakeTextCtrl(text=str(self.north), size=(150, -1), parent=panel)
+ self.tsouth = self.MakeTextCtrl(str(self.south), size=(150, -1), parent=panel)
+ self.twest = self.MakeTextCtrl(str(self.west), size=(150, -1), parent=panel)
+ self.teast = self.MakeTextCtrl(str(self.east), size=(150, -1), parent=panel)
+ self.tnsres = self.MakeTextCtrl(str(self.nsres), size=(150, -1), parent=panel)
+ self.tewres = self.MakeTextCtrl(str(self.ewres), size=(150, -1), parent=panel)
# labels
- self.lrows = self.MakeLabel("")
- self.lcols = self.MakeLabel("")
- self.lcells = self.MakeLabel("")
+ self.lrows = self.MakeLabel(parent=panel)
+ self.lcols = self.MakeLabel(parent=panel)
+ self.lcells = self.MakeLabel(parent=panel)
# buttons
- self.bset = self.MakeButton(_("&Set region"), id=wx.ID_OK)
- self.bcancel = wx.Button(self, id=wx.ID_CANCEL)
+ self.bset = self.MakeButton(text=_("&Set region"), id=wx.ID_OK, parent=panel)
+ self.bcancel = wx.Button(panel, id=wx.ID_CANCEL)
self.bset.SetDefault()
# image
self.img = wx.Image(os.path.join(globalvar.ETCWXDIR, "images",
"qgis_world.png"), wx.BITMAP_TYPE_PNG).ConvertToBitmap()
# set current working environment to PERMANENT mapset
# in selected location in order to set default region (WIND)
@@ -2220,19 +2229,17 @@
self.currlocation = envval['LOCATION_NAME'].strip("';")
self.currmapset = envval['MAPSET'].strip("';")
if self.currlocation != self.location or self.currmapset != 'PERMANENT':
- # cmdlist = ['g.mapset', 'location=%s' % self.location, 'mapset=PERMANENT']
- # gcmd.Command(cmdlist
gcmd.Command(["g.gisenv",
"set=LOCATION_NAME=%s" % self.location])
"set=MAPSET=PERMANENT"])
else:
dlg = wx.MessageBox(parent=self,
message=_('Invalid location selected.'),
caption=_("Error"), style=wx.ID_OK | wx.ICON_ERROR)
return
# get current region settings
@@ -2253,7 +2260,7 @@
dlg.ShowModal()
dlg.Destroy()
return
# update values
# 2D
@@ -2274,20 +2281,20 @@
self.tbres = float(region['tbres'])
self.depth = int(region['depths'])
self.cells3 = int(region['3dcells'])
# 3D box collapsable
self.infoCollapseLabelExp = _("Click here to show 3D settings")
self.infoCollapseLabelCol = _("Click here to hide 3D settings")
- self.settings3D = wx.CollapsiblePane(parent=self,
+ self.settings3D = wx.CollapsiblePane(parent=panel,
label=self.infoCollapseLabelExp,
style=wx.CP_DEFAULT_STYLE |
wx.CP_NO_TLW_RESIZE | wx.EXPAND)
self.MakeSettings3DPaneContent(self.settings3D.GetPane())
self.settings3D.Collapse(False) # FIXME
self.Bind(wx.EVT_COLLAPSIBLEPANE_CHANGED, self.OnSettings3DPaneChanged, self.settings3D)
# set current region settings
@@ -2305,7 +2312,7 @@
self.lrows.SetLabel(_("Rows: %d" % self.rows))
self.lcols.SetLabel(_("Cols: %d" % self.cols))
self.lcells.SetLabel(_("Cells: %d" % self.cells))
# bindings
@@ -2322,11 +2329,11 @@
# self.tnsres3.Bind(wx.EVT_TEXT, self.OnValue)
# self.tewres3.Bind(wx.EVT_TEXT, self.OnValue)
self.ttbres.Bind(wx.EVT_TEXT, self.OnValue)
- self.__DoLayout()
+ self.__DoLayout(panel)
self.SetMinSize(self.GetBestSize())
self.minWindowSize = self.GetMinSize()
def MakeSettings3DPaneContent(self, pane):
"""Create 3D region settings pane"""
border = wx.BoxSizer(wx.VERTICAL)
@@ -2420,7 +2427,7 @@
self.SendSizeEvent()
- def __DoLayout(self):
+ def __DoLayout(self, panel):
"""Window layout"""
frameSizer = wx.BoxSizer(wx.VERTICAL)
gridSizer = wx.GridBagSizer(vgap=0, hgap=0)
@@ -2428,7 +2435,7 @@
buttonSizer = wx.BoxSizer(wx.HORIZONTAL)
# north
- gridSizer.Add(item=self.MakeLabel(_("North")),
+ gridSizer.Add(item=self.MakeLabel(text=_("North"), parent=panel),
flag=wx.ALIGN_BOTTOM | wx.ALIGN_CENTER_HORIZONTAL |
wx.TOP | wx.LEFT | wx.RIGHT, border=5, pos=(0, 2))
gridSizer.Add(item=self.tnorth,
@@ -2436,7 +2443,7 @@
wx.ALIGN_CENTER_VERTICAL |
wx.ALL, border=5, pos=(1, 2))
# west
- gridSizer.Add(item=self.MakeLabel(_("West")),
+ gridSizer.Add(item=self.MakeLabel(text=_("West"), parent=panel),
flag=wx.ALIGN_RIGHT |
wx.LEFT | wx.TOP | wx.BOTTOM, border=5, pos=(2, 0))
@@ -2445,7 +2452,7 @@
wx.ALL, border=5, pos=(2, 1))
- gridSizer.Add(item=wx.StaticBitmap(self, wx.ID_ANY, self.img, (-1, -1),
+ gridSizer.Add(item=wx.StaticBitmap(panel, wx.ID_ANY, self.img, (-1, -1),
(self.img.GetWidth(), self.img.GetHeight())),
flag=wx.ALIGN_CENTER |
@@ -2456,7 +2463,7 @@
flag=wx.ALIGN_CENTER_HORIZONTAL |
wx.ALL, border=5, pos=(2, 3))
- gridSizer.Add(item=self.MakeLabel(_("East")),
+ gridSizer.Add(item=self.MakeLabel(text=_("East"), parent=panel),
flag=wx.ALIGN_LEFT |
wx.RIGHT | wx.TOP | wx.BOTTOM, border=5, pos=(2, 4))
@@ -2465,11 +2472,11 @@
wx.ALL, border=5, pos=(3, 2))
- gridSizer.Add(item=self.MakeLabel(_("South")),
+ gridSizer.Add(item=self.MakeLabel(text=_("South"), parent=panel),
flag=wx.ALIGN_TOP | wx.ALIGN_CENTER_HORIZONTAL |
wx.LEFT | wx.RIGHT | wx.BOTTOM, border=5, pos=(4, 2))
# ns-res
- gridSizer.Add(item=self.MakeLabel(_("N-S resolution")),
+ gridSizer.Add(item=self.MakeLabel(text=_("N-S resolution"), parent=panel),
flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_CENTER |
wx.TOP | wx.LEFT | wx.RIGHT, border=5, pos=(5, 1))
gridSizer.Add(item=self.tnsres,
@@ -2477,7 +2484,7 @@
wx.ALL, border=5, pos=(6, 1))
# ew-res
- gridSizer.Add(item=self.MakeLabel(_("E-W resolution")),
+ gridSizer.Add(item=self.MakeLabel(text=_("E-W resolution"), parent=panel),
wx.TOP | wx.LEFT | wx.RIGHT, border=5, pos=(5, 3))
gridSizer.Add(item=self.tewres,
@@ -2520,8 +2527,8 @@
flag=wx.ALL | wx.ALIGN_RIGHT, border=5)
self.SetAutoLayout(True)
- self.SetSizer(frameSizer)
- frameSizer.Fit(self)
+ panel.SetSizer(frameSizer)
+ frameSizer.Fit(panel)
self.Layout()
def OnValue(self, event):
Modified: grass/branches/releasebranch_6_4/gui/wxpython/wxgui.py
--- grass/branches/releasebranch_6_4/gui/wxpython/wxgui.py 2009-02-20 15:20:47 UTC (rev 35986)
+++ grass/branches/releasebranch_6_4/gui/wxpython/wxgui.py 2009-02-20 17:48:13 UTC (rev 35987)
@@ -506,7 +506,7 @@
def RunMenuCmd(self, event):
"""Run command selected from menu"""
cmd = self.GetMenuCmd(event)
- self.goutput.RunCmd(cmd)
+ self.goutput.RunCmd(cmd, switchPage=True)
def OnMenuCmd(self, event):
"""Parse command selected from menu"""
