[GRASS-SVN] r35992 - grass/branches/releasebranch_6_4/lib/python
svn_grass at osgeo.org
Fri Feb 20 14:44:04 EST 2009
Author: martinl
Date: 2009-02-20 14:44:03 -0500 (Fri, 20 Feb 2009)
New Revision: 35992
grass/branches/releasebranch_6_4/lib/python/grass.py
use ';' as separator (to avoid problems on MS Windows)
Modified: grass/branches/releasebranch_6_4/lib/python/grass.py
--- grass/branches/releasebranch_6_4/lib/python/grass.py 2009-02-20 19:34:03 UTC (rev 35991)
+++ grass/branches/releasebranch_6_4/lib/python/grass.py 2009-02-20 19:44:03 UTC (rev 35992)
@@ -449,10 +449,11 @@
@return dictionary { layer : { 'layer', 'table, 'database', 'driver', 'key' }
- s = read_command('v.db.connect', flags = 'g', map = map, fs = '|', **args)
+ s = read_command('v.db.connect', flags = 'g', map = map, fs = ';', **args)
result = {}
for l in s.splitlines():
- f = l.split('|')
+ f = l.split(';')
if len(f) != 5:
continue
if '/' in f[0]:
