[GRASS-SVN] r36024 - in grass/branches/develbranch_6: include lib/gis
Sun Feb 22 03:54:28 EST 2009
Author: hamish
Date: 2009-02-22 03:54:28 -0500 (Sun, 22 Feb 2009)
New Revision: 36024
   grass/branches/develbranch_6/include/gisdefs.h
   grass/branches/develbranch_6/lib/gis/gisinit.c
   grass/branches/develbranch_6/lib/gis/null_val.c
backport faster null check for G_is_c_null_value() (trac #392)
Modified: grass/branches/develbranch_6/include/gisdefs.h
--- grass/branches/develbranch_6/include/gisdefs.h	2009-02-22 06:20:49 UTC (rev 36023)
+++ grass/branches/develbranch_6/include/gisdefs.h	2009-02-22 08:54:28 UTC (rev 36024)
@@ -837,7 +837,6 @@
 char *G_fully_qualified_name(const char *, const char *);
 /* null_val.c */
-void G__init_null_patterns(void);
 void G__set_null_value(void *, int, int, RASTER_MAP_TYPE);
 void G_set_null_value(void *, int, RASTER_MAP_TYPE);
 void G_set_c_null_value(CELL *, int);
Modified: grass/branches/develbranch_6/lib/gis/gisinit.c
--- grass/branches/develbranch_6/lib/gis/gisinit.c	2009-02-22 06:20:49 UTC (rev 36023)
+++ grass/branches/develbranch_6/lib/gis/gisinit.c	2009-02-22 08:54:28 UTC (rev 36024)
@@ -135,9 +135,6 @@
     /* Set masking flag unknown */
     G__.auto_mask = -1;
-    /* set architecture dependent bit patterns for embeded null vals */
-    G__init_null_patterns();
     initialized = 1;
     setlocale(LC_NUMERIC, "C");
Modified: grass/branches/develbranch_6/lib/gis/null_val.c
--- grass/branches/develbranch_6/lib/gis/null_val.c	2009-02-22 06:20:49 UTC (rev 36023)
+++ grass/branches/develbranch_6/lib/gis/null_val.c	2009-02-22 08:54:28 UTC (rev 36024)
@@ -24,31 +24,8 @@
 #include <grass/gis.h>
 #include <grass/glocale.h>
-/*======================= Internal Constants/Defines =======================*/
-/* none */
-/*========================== Internal Typedefs =============================*/
-/* none */
-/*====================== Static Variable Declaration =======================*/
-/* Null pattern variables */
-static CELL cellNullPattern;
-static FCELL fcellNullPattern;
-static DCELL dcellNullPattern;
-/* Flag to indicate null patterns are initialized */
-static int initialized = FALSE;
-/*============================== Prototypes ================================*/
 static int EmbedGivenNulls(void *, char *, RASTER_MAP_TYPE, int);
-static void InitError(void);
-/*======================= Internal Static Functions ========================*/
 * int EmbedGivenNulls (void *cell, char *nulls, RASTER_MAP_TYPE map_type,
 *   int ncols)
@@ -96,81 +73,9 @@
     return 1;
-* void InitError (void)
-* PURPOSE: 	To print an error message and exit the program. This function
-*   	    	is called if something tries to access a null pattern before
-*   	    	it is initialized.
-* INPUT VARS:	none
-* RETURN VAL:	none
-    char errMsg[512];		/* array to hold error message */
-    strcpy(errMsg, _("Null values have not been initialized. "));
-    strcat(errMsg, _("G_gisinit() must be called first. "));
-    strcat(errMsg, _("Please advise GRASS developers of this error.\n"));
-    G_fatal_error(errMsg);
-    return;
 /*========================== Library Functions =============================*/
-* void G__init_null_patterns (void)
-* PURPOSE: 	To initialize the three null patterns for CELL, FCELL, and
-*   	    	DCELL data types. It also sets the initialized flag to TRUE.
-*   	    	This function is called by G_gisinit()
-* INPUT VARS:	none
-* RETURN VAL:	none
-    unsigned char *bytePtr;	/* pointer to traverse FCELL and DCELL */
-    int numBits;		/* number of bits for CELL type */
-    int i;			/* counter */
-    if (!initialized) {
-	/* Create the null pattern for the CELL data type - set the left */
-	/* most bit to 1 and the rest to 0, basically INT_MIN. Since CELL is */
-	/* some type of integer the bytes are not split into exponent and */
-	/* mantissa. Thus a simple left shift can be used */
-	numBits = sizeof(CELL) * 8;
-	cellNullPattern = 1 << (numBits - 1);
-	/* Create the null pattern for the FCELL data type - set all bits */
-	/* to 1, basically NaN. Need to use a byte pointer since bytes */
-	/* represent the exponent and mantissa */
-	bytePtr = (unsigned char *)&fcellNullPattern;
-	for (i = 0; i < sizeof(FCELL); i++) {
-	    *bytePtr = (unsigned char)255;
-	    bytePtr++;
-	/* Create the null pattern for the DCELL data type - set all bits */
-	bytePtr = (unsigned char *)&dcellNullPattern;
-	for (i = 0; i < sizeof(DCELL); i++) {
-	    bytePtr++;
-	/* Set the initialized flag to TRUE */
-	initialized = TRUE;
-    return;
 * void G__set_null_value (void *rast, int numVals, int null_is_zero,
 *   RASTER_MAP_TYPE data_type)
@@ -234,25 +139,12 @@
 *   	    	numVals     =>	number of values to set to null
 * RETURN VAL:	none
-void G_set_c_null_value(CELL * cellVals, int numVals)
+void G_set_c_null_value(CELL *cellVals, int numVals)
-    CELL *cellPtr;		/* pointer to CELL array to set to null */
-    /* Check if the null patterns have been initialized */
-	InitError();
-    /* Set numVals consecutive CELL values to null */
-    cellPtr = cellVals;
-    for (i = 0; i < numVals; i++) {
-	*cellPtr = cellNullPattern;
-	cellPtr++;
-    return;
+    for (i = 0; i < numVals; i++)
+	cellVals[i] = (int) 0x80000000;
@@ -263,25 +155,14 @@
 * RETURN VAL:	none
-void G_set_f_null_value(FCELL * fcellVals, int numVals)
+void G_set_f_null_value(FCELL *fcellVals, int numVals)
-    FCELL *fcellPtr;		/* pointer to FCELL array to set to null */
+    static const unsigned char null_bits[4] = {
+	0xFF, 0xFF, 0xFF, 0xFF};
+    int i;
-	InitError();
-    /* Set numVals consecutive FCELL values to null */
-    fcellPtr = fcellVals;
-	*fcellPtr = fcellNullPattern;
-	fcellPtr++;
-    return;
+	memcpy(&fcellVals[i], null_bits, sizeof(null_bits));
@@ -292,25 +173,14 @@
 * RETURN VAL:	none
-void G_set_d_null_value(DCELL * dcellVals, int numVals)
+void G_set_d_null_value(DCELL *dcellVals, int numVals)
-    DCELL *dcellPtr;		/* pointer to DCELL array to set to null */
+    static const unsigned char null_bits[8] = {
+	0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
+    int i;
-	InitError();
-    /* Set numVals consecutive DCELL values to null */
-    dcellPtr = dcellVals;
-	*dcellPtr = dcellNullPattern;
-	dcellPtr++;
-    return;
+	memcpy(&dcellVals[i], null_bits, sizeof(null_bits));
@@ -373,22 +243,8 @@
 int G_is_c_null_value(const CELL * cellVal)
-	InitError();
     /* Check if the CELL value matches the null pattern */
-    for (i = 0; i < sizeof(CELL); i++) {
-	if (((unsigned char *)cellVal)[i] !=
-	    ((unsigned char *)&cellNullPattern)[i]) {
-	    return FALSE;
-    return TRUE;
+    return *cellVal == (CELL) 0x80000000;
