[GRASS-SVN] r36042 - grass/trunk/locale/po
svn_grass at osgeo.org
Sun Feb 22 07:59:50 EST 2009
Author: neteler
Date: 2009-02-22 07:59:50 -0500 (Sun, 22 Feb 2009)
New Revision: 36042
grass/trunk/locale/po/grasswxpy_de.po
Entry screen translated; cruft removed
Modified: grass/trunk/locale/po/grasswxpy_de.po
--- grass/trunk/locale/po/grasswxpy_de.po 2009-02-22 12:41:02 UTC (rev 36041)
+++ grass/trunk/locale/po/grasswxpy_de.po 2009-02-22 12:59:50 UTC (rev 36042)
@@ -1,4 +1,4 @@
-# translation of grasswxpy_de.po to Deutsch
+# translation of grasswxpy_de.po to deutsch
# This file is distributed under the same license as the GRASS package.
# Copyright (C) 2008, GRASS Development Team
@@ -12,9 +12,9 @@
"Project-Id-Version: grasswxpy_de\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2009-01-09 23:29+0100\n"
-"PO-Revision-Date: 2009-02-19 18:05+0100\n"
-"Last-Translator: Robert Nuske <rnuske at gwdg.de>\n"
-"Language-Team: Deutsch <grass-translations at lists.osgeo.org>\n"
+"PO-Revision-Date: 2009-02-22 13:21+0100\n"
+"Last-Translator: Markus Neteler <neteler osgeo.org>\n"
+"Language-Team: deutsch <grass-translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=ISO-8859-15\n"
"Content-Transfer-Encoding: 8bit\n"
@@ -1191,7 +1191,7 @@
"No attribute table linked to vector map <%(vector)s> found. %(msg)s\n"
"You can disable this message from digitization settings. Or you can create "
"and link attribute table to the vector map using Attribute Table Manager."
-msgstr "Vektor Vektor Vektor."
+msgstr ""
#: ../gui/wxpython/gui_modules/dbm.py:2927
msgid "Close dialog on submit"
@@ -2137,7 +2137,7 @@
#: ../gui/wxpython/gui_modules/toolbars.py:1078
#, fuzzy, python-format
msgid "Please wait, opening vector map <%s> for editing..."
-msgstr "Vektor."
+msgstr ""
#: ../gui/wxpython/gui_modules/toolbars.py:1138
@@ -2152,7 +2152,7 @@
#: ../gui/wxpython/gui_modules/toolbars.py:1147
msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
-msgstr "Vektor."
+msgstr ""
#: ../gui/wxpython/gui_modules/toolbars.py:1211
#: ../gui/wxpython/gui_modules/toolbars.py:1216
@@ -3481,7 +3481,7 @@
#: ../gui/wxpython/gui_modules/vdigit.py:1571
msgid "Vector digitizer settings saved to file <%s>."
-msgstr "Vektor."
+msgstr ""
#: ../gui/wxpython/gui_modules/vdigit.py:1730
#, fuzzy
@@ -3524,7 +3524,7 @@
#: ../gui/wxpython/gui_modules/vdigit.py:2075
#, fuzzy
msgid "Unable to update vector map."
-msgstr "Vektor."
+msgstr ""
#: ../gui/wxpython/gui_modules/vdigit.py:2237
@@ -4118,7 +4118,7 @@
#: ../gui/wxpython/gis_set.py:84
msgid "Choose project location and mapset"
-msgstr ""
+msgstr "Wählen Sie eine existierende Location mit Mapset"
#: ../gui/wxpython/gis_set.py:87
msgid "Manage"
@@ -4130,41 +4130,52 @@
"Welcome to GRASS GIS %s\n"
"The world's leading open source GIS"
msgstr ""
+"Willkommen in GRASS GIS %s\n"
+"Das weltweit führende quelloffene GIS"
#: ../gui/wxpython/gis_set.py:95
msgid ""
"Select an existing project location and mapset\n"
"or define a new location"
msgstr ""
+"Wählen Sie eine existierende Location mit Mapset\n"
+"oder definieren Sie eine neue Location"
#: ../gui/wxpython/gis_set.py:101
msgid ""
"Project location\n"
"(projection/coordinate system)"
msgstr ""
+"Projekt Location\n"
+"(Projektion/Koordinatensystem)"
#: ../gui/wxpython/gis_set.py:104
msgid ""
"Accessible mapsets\n"
"(directories of GIS files)"
msgstr ""
+"Verfügbare Mapsets\n"
+"(Ordner mit GIS-Daten)"
#: ../gui/wxpython/gis_set.py:107
msgid ""
"Create new mapset\n"
"in selected location"
msgstr ""
+"Neues Mapset in der ausge-\n"
+"wählten Location erstellen"
#: ../gui/wxpython/gis_set.py:110
msgid "Define new location"
-msgstr ""
+msgstr "Neue Location definieren"
#: ../gui/wxpython/gis_set.py:113
-#, fuzzy
msgid ""
"Rename/delete selected\n"
"mapset or location"
-msgstr "Nenne Karten um"
+msgstr ""
+"Benenne um/Lösche selektierte\n"
+"Mapset oder Location"
#: ../gui/wxpython/gis_set.py:118
msgid "Start GRASS"
@@ -4487,7 +4498,7 @@
#: ../gui/wxpython/menustrings.py:49
#, fuzzy
msgid "Converts selected OGR layers to GRASS vector maps using v.in.ogr."
-msgstr "Vektor."
+msgstr ""
#: ../gui/wxpython/menustrings.py:50
msgid "ASCII points/GRASS ASCII vector import"
@@ -4520,7 +4531,7 @@
#: ../gui/wxpython/menustrings.py:57
#, fuzzy
msgid "Converts selected DXF layers to GRASS vector maps (using v.in.dxf)."
-msgstr "Vektor."
+msgstr ""
#: ../gui/wxpython/menustrings.py:58
msgid "ESRI e00 import"
@@ -7081,7 +7092,7 @@
#: ../gui/wxpython/menustrings.py:577
#, fuzzy
msgid "Outputs basic information about a user-specified vector map layer."
-msgstr "Vektor."
+msgstr ""
#: ../gui/wxpython/menustrings.py:578
#, fuzzy
@@ -7101,7 +7112,7 @@
#: ../gui/wxpython/menustrings.py:581
#, fuzzy
msgid "Populate database values from vector features."
-msgstr "Vektor."
+msgstr ""
#: ../gui/wxpython/menustrings.py:582
#, fuzzy
