[GRASS-SVN] r36065 - grass-addons/raster/r.univar2.zonal
svn_grass at osgeo.org
Mon Feb 23 07:00:15 EST 2009
Author: mmetz
Date: 2009-02-23 07:00:15 -0500 (Mon, 23 Feb 2009)
New Revision: 36065
grass-addons/raster/r.univar2.zonal/globals.h
grass-addons/raster/r.univar2.zonal/r.univar_main.c
grass-addons/raster/r.univar2.zonal/stats.c
memory corruption bugfix, proper label reporting
Modified: grass-addons/raster/r.univar2.zonal/globals.h
--- grass-addons/raster/r.univar2.zonal/globals.h 2009-02-23 08:05:45 UTC (rev 36064)
+++ grass-addons/raster/r.univar2.zonal/globals.h 2009-02-23 12:00:15 UTC (rev 36065)
@@ -40,6 +40,7 @@
int map_type;
void *nextp;
int n_alloc;
+ int first;
} univar_stat;
typedef struct
Modified: grass-addons/raster/r.univar2.zonal/r.univar_main.c
--- grass-addons/raster/r.univar2.zonal/r.univar_main.c 2009-02-23 08:05:45 UTC (rev 36064)
+++ grass-addons/raster/r.univar2.zonal/r.univar_main.c 2009-02-23 12:00:15 UTC (rev 36065)
@@ -109,7 +109,7 @@
/* TODO: make it an option */
- zone_info.sep = ";";
+ zone_info.sep = "|";
G_get_window(®ion);
rows = region.rows;
@@ -168,10 +168,6 @@
process_raster(stats, fd, fdz, ®ion);
- /* closing raster maps */
- G_close_cell(fd);
- G_close_cell(fdz);
/* create the output */
if (param.table->answer)
print_stats2(stats);
@@ -181,6 +177,10 @@
/* release memory */
free_univar_stat_struct(stats);
+ /* closing raster maps */
+ G_close_cell(fd);
+ G_close_cell(fdz);
exit(EXIT_SUCCESS);
@@ -213,7 +213,7 @@
stats = create_univar_stat_struct(map_type, size, i);
for (i = 0; i < zone_info.n_zones; i++) {
for (j = 0; j < stats[i].n_perc; j++) {
- sscanf(param.percentile->answers[j], "%i", &stats[i].perc[j]);
+ sscanf(param.percentile->answers[j], "%i", &(stats[i].perc[j]));
@@ -227,8 +227,6 @@
/* use G_window_rows(), G_window_cols() here? */
const int rows = region->rows;
const int cols = region->cols;
- const int n_zones = zone_info.n_zones;
- int *first, i;
const RASTER_MAP_TYPE map_type = G_get_raster_map_type(fd);
const size_t value_sz = G_raster_size(map_type);
@@ -236,42 +234,7 @@
void *raster_row;
CELL *zoneraster_row;
- switch (map_type) {
- case CELL_TYPE:
- for (i = 0; i < n_zones; i++) {
- stats[i].nextp
- = ((!param.extended->answer) ? 0 : (void *)stats[i].cell_array);
- break;
- case FCELL_TYPE:
- stats[i].nextp
- = ((!param.extended->answer) ? 0 : (void *)stats[i].fcell_array);
- break;
- case DCELL_TYPE:
- stats[i].nextp
- = ((!param.extended->answer) ? 0 : (void *)stats[i].dcell_array);
- break;
- default:
- G_fatal_error("input raster has unknown type");
- break;
- first = (int *) G_malloc((n_zones - 1) * sizeof(int));
- int i;
- first[i] = (stats[i].n < 1);
- raster_row = G_calloc(cols, value_sz);
+ raster_row = G_allocate_raster_buf(map_type);
zoneraster_row = G_allocate_c_raster_buf();
for (row = 0; row < rows; row++) {
@@ -289,18 +252,20 @@
zptr = zoneraster_row;
for (col = 0; col < cols; col++) {
+ double val;
- /* skip NULL cells in zone map altogether */
+ /* skip NULL cells in zone map */
if (G_is_c_null_value(zptr)) {
ptr = G_incr_void_ptr(ptr, value_sz);
zptr++;
continue;
- /* also count NULL cell in input map */
+ /* count NULL cells in input map */
zone = *zptr - zone_info.min;
stats[zone].size++;
+ /* can't do stats with NULL cells in input map */
if (G_is_null_value(ptr, map_type)) {
zptr++;
@@ -312,50 +277,52 @@
if (stats[zone].n >= stats[zone].n_alloc) {
stats[zone].n_alloc += 1000;
size_t msize;
- if (map_type == DCELL_TYPE) {
- msize = stats[zone].n_alloc * sizeof(DCELL);
- stats[zone].dcell_array =
- (DCELL *)G_realloc((void *)stats[zone].dcell_array, msize);
- stats[zone].nextp = (void *)&(stats[zone].dcell_array[stats[zone].n]);
+ switch (map_type) {
+ case DCELL_TYPE:
+ msize = stats[zone].n_alloc * sizeof(DCELL);
+ stats[zone].dcell_array =
+ (DCELL *)G_realloc((void *)stats[zone].dcell_array, msize);
+ stats[zone].nextp = (void *)&(stats[zone].dcell_array[stats[zone].n]);
+ break;
+ case FCELL_TYPE:
+ msize = stats[zone].n_alloc * sizeof(FCELL);
+ stats[zone].fcell_array =
+ (FCELL *)G_realloc((void *)stats[zone].fcell_array, msize);
+ stats[zone].nextp = (void *)&(stats[zone].fcell_array[stats[zone].n]);
+ break;
+ case CELL_TYPE:
+ msize = stats[zone].n_alloc * sizeof(CELL);
+ stats[zone].cell_array =
+ (CELL *)G_realloc((void *)stats[zone].cell_array, msize);
+ stats[zone].nextp = (void *)&(stats[zone].cell_array[stats[zone].n]);
+ break;
+ default:
+ break;
- else if (map_type == FCELL_TYPE) {
- msize = stats[zone].n_alloc * sizeof(FCELL);
- stats[zone].fcell_array =
- (FCELL *)G_realloc((void *)stats[zone].fcell_array, msize);
- stats[zone].nextp = (void *)&(stats[zone].fcell_array[stats[zone].n]);
- else if (map_type == CELL_TYPE) {
- msize = stats[zone].n_alloc * sizeof(CELL);
- stats[zone].cell_array =
- (CELL *)G_realloc((void *)stats[zone].cell_array, msize);
- stats[zone].nextp = (void *)&(stats[zone].cell_array[stats[zone].n]);
/* put the value into stats->XXXcell_array */
memcpy(stats[zone].nextp, ptr, value_sz);
stats[zone].nextp = G_incr_void_ptr(stats[zone].nextp, value_sz);
- double val = ((map_type == DCELL_TYPE) ? *((DCELL *) ptr)
- : (map_type == FCELL_TYPE) ? *((FCELL *) ptr)
- : *((CELL *) ptr));
+ val = ((map_type == DCELL_TYPE) ? *((DCELL *) ptr)
+ : (map_type == FCELL_TYPE) ? *((FCELL *) ptr)
+ : *((CELL *) ptr));
- stats[zone].sum += val;
- stats[zone].sumsq += val * val;
- stats[zone].sum_abs += fabs(val);
+ stats[zone].sum += val;
+ stats[zone].sumsq += val * val;
+ stats[zone].sum_abs += fabs(val);
- if (first[zone]) {
+ if (stats[zone].first) {
+ stats[zone].max = val;
+ stats[zone].min = val;
+ stats[zone].first = FALSE;
+ else {
+ if (val > stats[zone].max)
+ if (val < stats[zone].min)
- first[zone] = FALSE;
- else {
- if (val > stats[zone].max)
- stats[zone].max = val;
- if (val < stats[zone].min)
- stats[zone].min = val;
Modified: grass-addons/raster/r.univar2.zonal/stats.c
--- grass-addons/raster/r.univar2.zonal/stats.c 2009-02-23 08:05:45 UTC (rev 36064)
+++ grass-addons/raster/r.univar2.zonal/stats.c 2009-02-23 12:00:15 UTC (rev 36065)
@@ -44,10 +44,12 @@
stats[i].n_alloc = 0;
+ stats[i].first = TRUE;
/* allocate memory for extended computation */
/* changed to on-demand block allocation */
- if (param.extended->answer) {
+/* if (param.extended->answer) {
stats[i].dcell_array = NULL;
@@ -58,6 +60,7 @@
stats[i].cell_array = NULL;
@@ -122,7 +125,7 @@
sprintf(sum_str, "%.10f", stats[z].sum);
G_trim_decimal(sum_str);
- fprintf(stdout, "\nzone %d %s\n\n", z + zone_info.min, G_get_c_raster_cat(&z + zone_info.min, &(zone_info.cats)));
+ fprintf(stdout, "\nzone %d %s\n\n", z + zone_info.min, G_get_cat(z + zone_info.min, &(zone_info.cats)));
if (!param.shell_style->answer) {
fprintf(stdout, "total null and non-null cells: %d\n", stats[z].size);
@@ -289,12 +292,14 @@
fprintf(stdout, "sum%s", zone_info.sep);
fprintf(stdout, "sum_abs%s", zone_info.sep);
- fprintf(stdout, "first_quart%s", zone_info.sep);
- fprintf(stdout, "median%s", zone_info.sep);
- fprintf(stdout, "third_quart%s", zone_info.sep);
- for (i = 0; i < stats[0].n_perc; i++) {
- fprintf(stdout, "perc_%d%s", stats[0].perc[i],
- zone_info.sep);
+ if (param.extended->answer) {
+ fprintf(stdout, "first_quart%s", zone_info.sep);
+ fprintf(stdout, "median%s", zone_info.sep);
+ fprintf(stdout, "third_quart%s", zone_info.sep);
+ for (i = 0; i < stats[0].n_perc; i++) {
+ fprintf(stdout, "perc_%d%s", stats[0].perc[i],
+ zone_info.sep);
fprintf(stdout, "\n");
@@ -327,7 +332,7 @@
/* zone number */
fprintf(stdout, "%d%s", z + zone_info.min, zone_info.sep);
/* zone label */
- fprintf(stdout,"%s%s", G_get_c_raster_cat(&z + zone_info.min, &(zone_info.cats)), zone_info.sep);
+ fprintf(stdout,"%s%s", G_get_cat(z + zone_info.min, &(zone_info.cats)), zone_info.sep);
/* total cells */
fprintf(stdout, "%d%s", stats[z].n, zone_info.sep);
