[GRASS-SVN] r36077 - grass-addons/raster/r.univar2.zonal
svn_grass at osgeo.org
Tue Feb 24 04:30:04 EST 2009
Author: mmetz
Date: 2009-02-24 04:30:03 -0500 (Tue, 24 Feb 2009)
New Revision: 36077
grass-addons/raster/r.univar2.zonal/r.univar.html
grass-addons/raster/r.univar2.zonal/r.univar_main.c
manual updated
Modified: grass-addons/raster/r.univar2.zonal/r.univar.html
--- grass-addons/raster/r.univar2.zonal/r.univar.html 2009-02-24 08:01:43 UTC (rev 36076)
+++ grass-addons/raster/r.univar2.zonal/r.univar.html 2009-02-24 09:30:03 UTC (rev 36077)
@@ -10,13 +10,13 @@
If the <b>-g</b> flag is given the results are presented in a format suitable
for use in a shell script.
If the <b>-t</b> flag is given the results are presented in tabular format
-with ";" as field separator. The table can immediately be converted to a
+with "|" as field separator. The table can immediately be converted to a
proper attribute table which can then be linked to a vector, e.g. the vector
that was rasterized to create the <b>zones</b> input raster.
<h2>NOTES</h2>
-As with most GRASS raster modules, <em>r.univar</em> operates on the cell
+As with most GRASS raster modules, <em>r.univar.zonal</em> operates on the cell
array defined by the current region settings, not the original extent and
resolution of the input map. See <em><a href="g.region.html">g.region</a></em>.
<p>
@@ -28,7 +28,7 @@
<h2>EXAMPLE</h2>
Calculate the raster statistics for zones within a vector map coverage
-and upload the results back to the vector map.
+and upload the results for mean, min and max back to the vector map.
<div class="code"><pre>
#### set the raster region to match the map
@@ -101,6 +101,8 @@
<h2>TODO</h2>
<i>mode, skewness, kurtosis</i>
+<br>
+<i>3D zonal statistics</i>
<h2>SEE ALSO</h2>
Modified: grass-addons/raster/r.univar2.zonal/r.univar_main.c
--- grass-addons/raster/r.univar2.zonal/r.univar_main.c 2009-02-24 08:01:43 UTC (rev 36076)
+++ grass-addons/raster/r.univar2.zonal/r.univar_main.c 2009-02-24 09:30:03 UTC (rev 36077)
@@ -27,7 +27,7 @@
void set_params()
- param.inputfile = G_define_standard_option(G_OPT_R_INPUT);
+ param.inputfile = G_define_standard_option(G_OPT_R_MAP);
param.zonefile = G_define_standard_option(G_OPT_R_MAP);
param.zonefile->key = "zones";
