[GRASS-SVN] r36093 - in grass/branches/releasebranch_6_4:
general/g.gui gui/scripts gui/tcltk/d.m gui/tcltk/gis.m
gui/wxpython/xml
svn_grass at osgeo.org
Wed Feb 25 07:28:06 EST 2009
Author: hamish
Date: 2009-02-25 07:28:06 -0500 (Wed, 25 Feb 2009)
New Revision: 36093
Added:
grass/branches/releasebranch_6_4/gui/scripts/g.change.gui.py
grass/branches/releasebranch_6_4/gui/scripts/g.change.gui.sh
grass/branches/releasebranch_6_4/general/g.gui/main.c
grass/branches/releasebranch_6_4/gui/tcltk/d.m/menu.tcl
grass/branches/releasebranch_6_4/gui/tcltk/gis.m/gmmenu.tcl
grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml
backport GUI changing tools from devbr6 r35972, r36027, r36030. works from gis.m, untested for wxPy, non-functional from d.m/CLI --ui (??)
Modified: grass/branches/releasebranch_6_4/general/g.gui/main.c
--- grass/branches/releasebranch_6_4/general/g.gui/main.c 2009-02-25 11:09:47 UTC (rev 36092)
+++ grass/branches/releasebranch_6_4/general/g.gui/main.c 2009-02-25 12:28:06 UTC (rev 36093)
@@ -25,7 +25,7 @@
int main(int argc, char *argv[])
struct Option *type, *rc_file;
- struct Flag *oneoff;
+ struct Flag *update, *nolaunch;
struct GModule *module;
char *gui_type_env;
char progname[GPATH_MAX];
@@ -44,23 +44,37 @@
type->description = _("Default value: GRASS_GUI if defined otherwise tcltk");
type->descriptions = _("tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);"
"oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);"
- "wxpython;wxPython based next generation GUI");
- type->options = "tcltk,oldtcltk,wxpython";
+ "wxpython;wxPython based next generation GUI;"
+ "text;command line interface only");
+ type->options = "tcltk,oldtcltk,wxpython,text";
rc_file = G_define_standard_option(G_OPT_F_INPUT);
rc_file->key = "workspace";
rc_file->required = NO;
rc_file->description = _("Name of workspace file");
- oneoff = G_define_flag();
- oneoff->key = 'u';
- oneoff->description = _("Update default GUI setting");
+ update = G_define_flag();
+ update->key = 'u';
+ update->description = _("Update default GUI setting");
+ nolaunch = G_define_flag();
+ nolaunch->key = 'n';
+ nolaunch->description =
+ _("Do not launch GUI after updating the default GUI setting");
if (argc > 1 && G_parser(argc, argv))
exit(EXIT_FAILURE);
+ if( type->answer && strcmp(type->answer, "text") == 0
+ && !nolaunch->answer)
+ nolaunch->answer = TRUE;
+ if(nolaunch->answer && !update->answer)
+ update->answer = TRUE;
gui_type_env = G__getenv("GRASS_GUI");
if (!type->answer) {
if (gui_type_env && strcmp(gui_type_env, "text")) {
type->answer = G_store(gui_type_env);
@@ -70,13 +84,17 @@
- if (((gui_type_env && oneoff->answer) &&
+ if (((gui_type_env && update->answer) &&
strcmp(gui_type_env, type->answer) != 0) || !gui_type_env) {
G_message(_("<%s> is now the default GUI"), type->answer);
G_setenv("GRASS_GUI", type->answer);
+ if(nolaunch->answer)
+ exit(EXIT_SUCCESS);
if (strcmp(type->answer, "oldtcltk") == 0) {
sprintf(progname, "%s/etc/dm/d.m.tcl", G_gisbase());
if (rc_file->answer) {
Copied: grass/branches/releasebranch_6_4/gui/scripts/g.change.gui.py (from rev 36092, grass/branches/develbranch_6/gui/scripts/g.change.gui.py)
--- grass/branches/releasebranch_6_4/gui/scripts/g.change.gui.py (rev 0)
+++ grass/branches/releasebranch_6_4/gui/scripts/g.change.gui.py 2009-02-25 12:28:06 UTC (rev 36093)
@@ -0,0 +1,47 @@
+#!/usr/bin/env python
+# MODULE: g.change.gui
+# AUTHOR(S): Hamish Bowman
+# PURPOSE:
+# COPYRIGHT: (C) 2009 GRASS Development Team
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2 of the License, or
+# (at your option) any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+#%Module
+#% description: Changes the default GRASS graphical user interface (GUI) setting.
+#% keywords: general, gui
+#%End
+#%Option
+#% key: gui
+#% type: string
+#% required: yes
+#% multiple: no
+#% options: tcltk,oldtcltk,wxpython,text
+#% label: GUI type
+#% description: Default value: GRASS_GUI if defined otherwise tcltk
+#% descriptions: tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);wxpython;wxPython based next generation GUI;text;command line interface only
+#%End
+# simple front end to g.gui to be used from within the GUI.
+import grass
+import sys
+def main():
+ grass.exec_command("g.gui", flags = 'nu', gui = options['gui'])
+ sys.exit(ret)
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ sys.exit(main())
Copied: grass/branches/releasebranch_6_4/gui/scripts/g.change.gui.sh (from rev 36092, grass/branches/develbranch_6/gui/scripts/g.change.gui.sh)
--- grass/branches/releasebranch_6_4/gui/scripts/g.change.gui.sh (rev 0)
+++ grass/branches/releasebranch_6_4/gui/scripts/g.change.gui.sh 2009-02-25 12:28:06 UTC (rev 36093)
@@ -0,0 +1,49 @@
+#!/bin/sh
+# PURPOSE:
+#%Module
+#%End
+#%Option
+#% key: gui
+#% type: string
+#% required: yes
+#% multiple: no
+#% label: GUI type
+#%End
+if [ -z "$GISBASE" ] ; then
+ echo "You must be in GRASS GIS to run this program." 1>&2
+ exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+ exec g.parser "$0" "$@"
+fi
+g.gui -nu gui="$GIS_OPT_GUI"
Modified: grass/branches/releasebranch_6_4/gui/tcltk/d.m/menu.tcl
--- grass/branches/releasebranch_6_4/gui/tcltk/d.m/menu.tcl 2009-02-25 11:09:47 UTC (rev 36092)
+++ grass/branches/releasebranch_6_4/gui/tcltk/d.m/menu.tcl 2009-02-25 12:28:06 UTC (rev 36093)
@@ -197,6 +197,7 @@
{command {[G_msg "Modify access by other users to current mapset"]} {} "g.access" {} -command {execute g.access }}
{command {[G_msg "Show current GRASS environment settings"]} {} "g.gisenv" {} -command {run_panel g.gisenv }}
{command {[G_msg "Set GRASS environment settings"]} {} "g.gisenv" {} -command {execute g.gisenv }}
+ {command {[G_msg "Change default GUI"]} {} "g.change.gui" {} -command {execute "$env(GISBASE)/etc/gui/scripts/g.change.gui.sh" }}
{command {[G_msg "Show current GRASS version"]} {} "g.version -c" {} -command {run_panel "g.version -c" }}
{cascad {[G_msg "Manage projections"]} {} "" $tmenu {
Modified: grass/branches/releasebranch_6_4/gui/tcltk/gis.m/gmmenu.tcl
--- grass/branches/releasebranch_6_4/gui/tcltk/gis.m/gmmenu.tcl 2009-02-25 11:09:47 UTC (rev 36092)
+++ grass/branches/releasebranch_6_4/gui/tcltk/gis.m/gmmenu.tcl 2009-02-25 12:28:06 UTC (rev 36093)
@@ -214,6 +214,7 @@
{command {[G_msg "User access"]} {} "g.access: Modify access by other users to current mapset" {} -command {execute g.access }}
{command {[G_msg "Show settings"]} {} "g.gisenv: Show current GRASS environment settings" {} -command {run_panel g.gisenv }}
{command {[G_msg "Change settings"]} {} "g.gisenv: Set GRASS environment settings" {} -command {execute g.gisenv }}
+ {command {[G_msg "Change default GUI"]} {} "g.change.gui: Change the default GUI setting" {} -command {execute "$env(GISBASE)/etc/gui/scripts/g.change.gui.sh" }}
{command {[G_msg "Show current GRASS version"]} {} "g.version -c: Show current GRASS version" {} -command {run_panel "g.version -c" }}
Modified: grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml
--- grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml 2009-02-25 11:09:47 UTC (rev 36092)
+++ grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml 2009-02-25 12:28:06 UTC (rev 36093)
@@ -607,6 +607,12 @@
<command>g.gisenv</command>
</menuitem>
<menuitem>
+ <label>Change default GUI</label>
+ <help>Changes the default GRASS graphical user interface (GUI) setting.</help>
+ <handler>self.OnMenuCmd</handler>
+ <command>g.change.gui.py</command>
+ </menuitem>
+ <menuitem>
<label>Version</label>
<help>Displays version and copyright information.</help>
<handler>self.RunMenuCmd</handler>
