[GRASS-SVN] r36113 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Thu Feb 26 14:06:02 EST 2009
Author: mmetz
Date: 2009-02-26 14:06:02 -0500 (Thu, 26 Feb 2009)
New Revision: 36113
grass/trunk/lib/vector/Vlib/net.c
dglib cache enabled again
Modified: grass/trunk/lib/vector/Vlib/net.c
--- grass/trunk/lib/vector/Vlib/net.c 2009-02-26 17:00:50 UTC (rev 36112)
+++ grass/trunk/lib/vector/Vlib/net.c 2009-02-26 19:06:02 UTC (rev 36113)
@@ -432,9 +432,8 @@
G_fatal_error(_("GngFlatten error"));
/* init SP cache */
- /* Disabled because of BUG1 in dglib. Without cache it is terribly slow, but with cache there
- * are too many errors. */
- /* dglInitializeSPCache( gr, &(Map->spCache) ); */
+ /* disable to debug dglib cache */
+ dglInitializeSPCache(gr, &(Map->spCache));
G_message(_("Graph was built"));
@@ -487,16 +486,22 @@
pclip = NULL;
if (List != NULL) {
- /*nRet = dglShortestPath ( &(Map->graph), &pSPReport, from, to, clipper, pclip, &(Map->spCache)); */
nRet =
dglShortestPath(&(Map->graph), &pSPReport, (dglInt32_t) from,
- (dglInt32_t) to, clipper, pclip, NULL);
+ (dglInt32_t) to, clipper, pclip, &(Map->spCache));
+ /* comment out above and uncomment below to debug dglib cache */
+ /* nRet =
+ dglShortestPath(&(Map->graph), &pSPReport, (dglInt32_t) from,
+ (dglInt32_t) to, clipper, pclip, NULL); */
else {
- /*nRet = dglShortestDistance ( &(Map->graph), &nDistance, from, to, clipper, pclip, &(Map->spCache)); */
nRet =
dglShortestDistance(&(Map->graph), &nDistance, (dglInt32_t) from,
+ /* nRet =
+ dglShortestDistance(&(Map->graph), &nDistance, (dglInt32_t) from,
if (nRet == 0) {
