[GRASS-SVN] r36123 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Fri Feb 27 08:25:53 EST 2009
Author: martinl
Date: 2009-02-27 08:25:53 -0500 (Fri, 27 Feb 2009)
New Revision: 36123
grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
wxGUI: load map layers / select toggle checkbox added
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py 2009-02-27 13:00:06 UTC (rev 36122)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py 2009-02-27 13:25:53 UTC (rev 36123)
@@ -614,14 +614,8 @@
btnCancel = wx.Button(self, wx.ID_CANCEL)
btnOk = wx.Button(self, wx.ID_OK, _("Load") )
btnOk.SetDefault()
- # bindigs
- #btnOk.Bind(wx.EVT_BUTTON, self.OnOK)
- #btnCancel.Bind(wx.EVT_BUTTON, self.OnCancel)
# sizers & do layout
btnSizer = wx.StdDialogButtonSizer()
@@ -656,6 +650,14 @@
self.layerType.SetSelection(0)
bodySizer.Add(item=self.layerType,
pos=(0,1))
+ # select toggle
+ self.toggle = wx.CheckBox(parent=self, id=wx.ID_ANY,
+ label=_("Select toggle"))
+ self.toggle.SetValue(True)
+ bodySizer.Add(item=self.toggle,
+ flag=wx.ALIGN_CENTER_VERTICAL,
+ pos=(0,2))
# mapset filter
bodySizer.Add(item=wx.StaticText(parent=self, label=_("Mapset:")),
@@ -668,7 +670,7 @@
size=(250,-1))
self.mapset.SetStringSelection(grass.gisenv()['MAPSET'])
bodySizer.Add(item=self.mapset,
- pos=(1,1))
+ pos=(1,1), span=(1, 2))
# map name filter
bodySizer.Add(item=wx.StaticText(parent=self, label=_("Filter:")),
@@ -680,7 +682,7 @@
size=(250,-1))
bodySizer.Add(item=self.filter,
flag=wx.EXPAND,
- pos=(2,1))
+ pos=(2,1), span=(1, 2))
# layer list
bodySizer.Add(item=wx.StaticText(parent=self, label=_("List of maps:")),
@@ -691,13 +693,14 @@
choices=[])
bodySizer.Add(item=self.layers,
flag=wx.EXPAND,
- pos=(3,1))
+ pos=(3,1), span=(1, 2))
# bindings
self.layerType.Bind(wx.EVT_CHOICE, self.OnChangeParams)
self.mapset.Bind(wx.EVT_COMBOBOX, self.OnChangeParams)
self.layers.Bind(wx.EVT_RIGHT_DOWN, self.OnMenu)
self.filter.Bind(wx.EVT_TEXT, self.OnFilter)
+ self.toggle.Bind(wx.EVT_CHECKBOX, self.OnToggle)
return bodySizer
def LoadMapLayers(self, type, mapset):
@@ -771,6 +774,14 @@
event.Skip()
+ def OnToggle(self, event):
+ """Select toggle (check or uncheck all layers)"""
+ check = event.Checked()
+ for item in range(self.layers.GetCount()):
+ self.layers.Check(item, check)
+ event.Skip()
def GetMapLayers(self):
"""Return list of checked map layers"""
layerNames = []
