[GRASS-SVN] r36126 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Fri Feb 27 10:54:46 EST 2009
Author: martinl
Date: 2009-02-27 10:54:46 -0500 (Fri, 27 Feb 2009)
New Revision: 36126
grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
wxGUI: load map layers dialog -> invert selection
(merge from trunk, r36125)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py 2009-02-27 15:44:50 UTC (rev 36125)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py 2009-02-27 15:54:46 UTC (rev 36126)
@@ -13,7 +13,7 @@
- LayersList (used by MultiImport)
- SetOpacityDialog
-(C) 2008 by the GRASS Development Team
+(C) 2008-2009 by the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
@@ -733,14 +733,17 @@
if not hasattr(self, "popupID1"):
self.popupDataID1 = wx.NewId()
self.popupDataID2 = wx.NewId()
+ self.popupDataID3 = wx.NewId()
- self.Bind(wx.EVT_MENU, self.OnSelectAll, id=self.popupDataID1)
- self.Bind(wx.EVT_MENU, self.OnDeselectAll, id=self.popupDataID2)
+ self.Bind(wx.EVT_MENU, self.OnSelectAll, id=self.popupDataID1)
+ self.Bind(wx.EVT_MENU, self.OnSelectInvert, id=self.popupDataID2)
+ self.Bind(wx.EVT_MENU, self.OnDeselectAll, id=self.popupDataID3)
# generate popup-menu
menu = wx.Menu()
menu.Append(self.popupDataID1, _("Select all"))
- menu.Append(self.popupDataID2, _("Deselect all"))
+ menu.Append(self.popupDataID2, _("Invert selection"))
+ menu.Append(self.popupDataID3, _("Deselect all"))
self.PopupMenu(menu)
menu.Destroy()
@@ -750,6 +753,14 @@
for item in range(self.layers.GetCount()):
self.layers.Check(item, True)
+ def OnSelectInvert(self, event):
+ """Invert current selection"""
+ for item in range(self.layers.GetCount()):
+ if self.layers.IsChecked(item):
+ self.layers.Check(item, False)
+ else:
+ self.layers.Check(item, True)
def OnDeselectAll(self, event):
"""Select all map layer from list"""
