[GRASS-SVN] r36132 - grass/branches/develbranch_6/lib/vector/Vlib
svn_grass at osgeo.org
Sat Feb 28 06:26:22 EST 2009
Author: mmetz
Date: 2009-02-28 06:26:22 -0500 (Sat, 28 Feb 2009)
New Revision: 36132
grass/branches/develbranch_6/lib/vector/Vlib/break_polygons.c
reduced memory consumption
Modified: grass/branches/develbranch_6/lib/vector/Vlib/break_polygons.c
--- grass/branches/develbranch_6/lib/vector/Vlib/break_polygons.c 2009-02-28 11:22:55 UTC (rev 36131)
+++ grass/branches/develbranch_6/lib/vector/Vlib/break_polygons.c 2009-02-28 11:26:22 UTC (rev 36132)
@@ -23,14 +23,37 @@
#include <grass/Vect.h>
#include <grass/glocale.h>
+/* TODO: 3D support
+ * atan2() gives angle from x-axis
+ * this is unambiguous only in 2D, not in 3D
+ * one possibility would be to store unit vectors of length 1
+ * in struct XPNT
+ * double a1[3], a2[3];
+ * length = sqrt(dx * dx + dy * dy + dz * dz);
+ * dx /= length; dy /= length; dz /=length;
+ * a1[0] = dx; a1[1] = dy; a1[2] = dz;
+ * get second dx, dy, dz
+ * a2[0] = dx; a2[1] = dy; a2[2] = dz;
+ * equal angles
+ * if (a1[0] == a2[0] && a1[1] == a2[1] && a1[2] == a2[2])
+ * disadvantage: increased memory consumption
+ * new function Vect_break_faces() ?
typedef struct
- double x, y;
double a1, a2; /* angles */
char cross; /* 0 - do not break, 1 - break */
- char used; /* 0 - was not used to break line, 1 - was used to break line
- * this is stored because points are automaticaly marked as cross, even if not used
- * later to break lines */
} XPNT;
static int fpoint;
@@ -62,7 +85,7 @@
Vect_break_polygons(struct Map_info *Map, int type, struct Map_info *Err)
struct line_pnts *BPoints, *Points;
- struct line_cats *Cats;
+ struct line_cats *Cats, *ErrCats;
int i, j, k, ret, ltype, broken, last, nlines;
int nbreaks;
struct Node *RTree;
@@ -77,6 +100,7 @@
BPoints = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
+ ErrCats = Vect_new_cats_struct();
nlines = Vect_get_num_lines(Map);
@@ -187,9 +211,6 @@
(XPNT *) G_realloc(XPnts,
(apoints + 1) * sizeof(XPNT));
- XPnts[npoints].x = Points->x[j];
- XPnts[npoints].y = Points->y[j];
- XPnts[npoints].used = 0;
if (j == 0 || j == (Points->n_points - 1) ||
Points->n_points < 3) {
XPnts[npoints].a1 = 0;
@@ -255,10 +276,6 @@
RTreeSearch(RTree, &rect, (void *)srch, 0);
G_debug(3, "fpoint = %d", fpoint);
- if (XPnts[fpoint].cross) { /* realy use to break line */
- XPnts[fpoint].used = 1;
/* break or write last segment of broken line */
if ((j == (Points->n_points - 1) && broken) ||
@@ -280,6 +297,15 @@
if (!broken)
Vect_delete_line(Map, i); /* not yet deleted */
+ /* Write points on breaks */
+ if (Err) {
+ if (j < (Points->n_points - 1)) {
+ Vect_reset_line(BPoints);
+ Vect_append_point(BPoints, Points->x[j], Points->y[j], 0);
+ Vect_write_line(Err, GV_POINT, BPoints, ErrCats);
last = j;
broken = 1;
nbreaks++;
@@ -301,18 +327,6 @@
- /* Write points on breaks */
- if (Err) {
- Vect_reset_cats(Cats);
- for (i = 1; i < npoints; i++) {
- if (XPnts[i].used) {
- Vect_reset_line(Points);
- Vect_append_point(Points, XPnts[i].x, XPnts[i].y, 0);
- Vect_write_line(Err, GV_POINT, Points, Cats);
G_free(XPnts);
RTreeDestroyNode(RTree);
