[GRASS-SVN] r36137 - grass/branches/develbranch_6/lib/vector/diglib
svn_grass at osgeo.org
Sat Feb 28 07:35:57 EST 2009
Author: mmetz
Date: 2009-02-28 07:35:57 -0500 (Sat, 28 Feb 2009)
New Revision: 36137
grass/branches/develbranch_6/lib/vector/diglib/plus_area.c
diglib: small topology building speed up
Modified: grass/branches/develbranch_6/lib/vector/diglib/plus_area.c
--- grass/branches/develbranch_6/lib/vector/diglib/plus_area.c 2009-02-28 12:33:36 UTC (rev 36136)
+++ grass/branches/develbranch_6/lib/vector/diglib/plus_area.c 2009-02-28 12:35:57 UTC (rev 36137)
@@ -57,7 +57,16 @@
int n_lines;
P_LINE *Line;
int node;
+ const char *dstr;
+ int debug_level;
+ dstr = G__getenv("DEBUG");
+ if (dstr != NULL)
+ debug_level = atoi(dstr);
+ else
+ debug_level = 0;
G_debug(3, "dig_build_area_with_line(): first_line = %d, side = %d",
first_line, side);
@@ -106,8 +115,11 @@
/* GOT ONE! fill area struct and return */
G_debug(3, "Got one! :");
- for (i = 0; i < n_lines; i++) {
- G_debug(3, " area line (%d) = %d", i, array[i]);
+ /* avoid loop when not debugging */
+ if (debug_level > 2) {
+ for (i = 0; i < n_lines; i++) {
+ G_debug(3, " area line (%d) = %d", i, array[i]);
*lines = array;
@@ -468,7 +480,16 @@
plus_t node;
P_NODE *Node;
P_LINE *Line;
+ const char *dstr;
+ int debug_level;
+ if (dstr != NULL)
+ else
+ debug_level = 0;
G_debug(3, "dig__angle_next_line: line = %d, side = %d, type = %d",
current_line, side, type);
@@ -482,9 +503,12 @@
Node = plus->Node[node];
G_debug(3, " n_lines = %d", Node->n_lines);
- for (i = 0; i < Node->n_lines; i++) {
- G_debug(3, " i = %d line = %d angle = %f", i, Node->lines[i],
- Node->angles[i]);
+ for (i = 0; i < Node->n_lines; i++) {
+ G_debug(3, " i = %d line = %d angle = %f", i, Node->lines[i],
+ Node->angles[i]);
/* first find index for that line */
