[GRASS-SVN] r36139 - grass/branches/develbranch_6/lib/vector/Vlib
svn_grass at osgeo.org
Sat Feb 28 07:38:49 EST 2009
Author: mmetz
Date: 2009-02-28 07:38:49 -0500 (Sat, 28 Feb 2009)
New Revision: 36139
grass/branches/develbranch_6/lib/vector/Vlib/select.c
Vlib: small topology building speed up
Modified: grass/branches/develbranch_6/lib/vector/Vlib/select.c
--- grass/branches/develbranch_6/lib/vector/Vlib/select.c 2009-02-28 12:36:48 UTC (rev 36138)
+++ grass/branches/develbranch_6/lib/vector/Vlib/select.c 2009-02-28 12:38:49 UTC (rev 36139)
@@ -93,7 +93,16 @@
struct ilist *list)
int i;
+ const char *dstr;
+ int debug_level;
+ dstr = G__getenv("DEBUG");
+ if (dstr != NULL)
+ debug_level = atoi(dstr);
+ else
+ debug_level = 0;
G_debug(3, "Vect_select_areas_by_box()");
G_debug(3, "Box(N,S,E,W,T,B): %e, %e, %e, %e, %e, %e", Box->N, Box->S,
Box->E, Box->W, Box->T, Box->B);
@@ -105,12 +114,15 @@
dig_select_areas(&(Map->plus), Box, list);
G_debug(3, " %d areas selected", list->n_values);
- for (i = 0; i < list->n_values; i++) {
- G_debug(3, " area = %d pointer to area structure = %lx",
- list->value[i],
- (unsigned long)Map->plus.Area[list->value[i]]);
+ /* avoid loop when not debugging */
+ if (debug_level > 2) {
+ for (i = 0; i < list->n_values; i++) {
+ G_debug(3, " area = %d pointer to area structure = %lx",
+ list->value[i],
+ (unsigned long)Map->plus.Area[list->value[i]]);
return list->n_values;
