[GRASS-SVN] r35146 - grass/trunk/visualization/nviz/scripts
svn_grass at osgeo.org
Thu Jan 1 12:45:43 EST 2009
Author: cmbarton
Date: 2009-01-01 12:45:42 -0500 (Thu, 01 Jan 2009)
New Revision: 35146
grass/trunk/visualization/nviz/scripts/widgets.tcl
Fix to permit 3D points to be loaded from the command line without first loading a surface.
Modified: grass/trunk/visualization/nviz/scripts/widgets.tcl
--- grass/trunk/visualization/nviz/scripts/widgets.tcl 2009-01-01 17:44:32 UTC (rev 35145)
+++ grass/trunk/visualization/nviz/scripts/widgets.tcl 2009-01-01 17:45:42 UTC (rev 35146)
@@ -324,6 +324,19 @@
set text_side left
set orient h
+ # permits loading of 3D points without surface
+ if {$name == "height" && $curr == inf} {
+ set from 10000
+ set to 0
+ set curr 5000
+ if {$name == "z-exag" && $from == 0.0 && $to == 0.0 && $curr == 0.0 } {
+ set from 10.0
+ set to 0.0
+ set curr 1.000000
#calculate number length for digits var
set num [llength [split [expr int($curr * 1)] ""]]
if {$num == 1} {
