[GRASS-SVN] r35175 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Fri Jan 2 16:56:15 EST 2009
Author: martinl
Date: 2009-01-02 16:56:15 -0500 (Fri, 02 Jan 2009)
New Revision: 35175
Removed:
grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbox.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/__init__.py
wxGUI: remove unused 'toolbox'
(merge from trunk, r35174)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/__init__.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/__init__.py 2009-01-02 21:55:08 UTC (rev 35174)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/__init__.py 2009-01-02 21:56:15 UTC (rev 35175)
@@ -1,28 +1,31 @@
-all = [ "dbm",
- "debug",
- "disp_print",
- "gcmd",
- "georect",
- "globalvar",
- "grassenv",
- "gselect",
- "goutput",
- "histogram",
- "location_wizard",
- "mapdisp",
- "menudata",
- "menuform",
- "nviz",
- "preferences",
- "profile",
- "psmap",
- "render",
- "rules",
- "sqlbuilder",
- "toolbars",
- "toolbox",
- "track",
- "utils",
- "vdigit",
- "workspace",
- "wxgui_utils" ]
+all = [
+ "colorrules.py",
+ "dbm.py",
+ "debug.py",
+ "disp_print.py",
+ "gcmd.py",
+ "gdialogs.py",
+ "georect.py",
+ "globalvar.py",
+ "goutput.py",
+ "gselect.py",
+ "histogram.py",
+ "location_wizard.py",
+ "mapdisp.py",
+ "mcalc_builder.py",
+ "menudata.py",
+ "menuform.py",
+ "nviz_mapdisp.py",
+ "nviz.py",
+ "nviz_tools.py",
+ "preferences.py",
+ "profile.py",
+ "render.py",
+ "rules.py",
+ "sqlbuilder.py",
+ "toolbars.py",
+ "utils.py",
+ "vdigit.py",
+ "workspace.py",
+ "wxgui_utils.py",
Deleted: grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbox.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbox.py 2009-01-02 21:55:08 UTC (rev 35174)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbox.py 2009-01-02 21:56:15 UTC (rev 35175)
@@ -1,209 +0,0 @@
-test_config = """
-<qgisgrass name="Test config">
-<modules>
- <section label="First Section">
- <grass name="g.gisenv"/>
- <grass name="d.vect"/>
- </section>
- <section label="Second Section">
- <grass name="r.to.vect.line"/>
- <grass name="r.to.vect.area"/>
- </section>
- <grass name="v.buffer"/>
-</modules>
-</qgisgrass>
-test_modules = {"g.gisenv":"""
-<qgisgrassmodule label="GRASS environment variables" module="g.gisenv">
-</qgisgrassmodule>
-""","r.to.vect.area":"""
-<qgisgrassmodule label="Convert a raster to vector areas" module="r.to.vect">
- <option key="input" />
- <option key="output" />
- <option key="feature" answer="area" hidden="yes" />
- <flag key="s" answer="on" hidden="yes" />
-</qgisgrassmodule>
-""","r.to.vect.line":"""
- <option key="feature" answer="line" hidden="yes" />
-</qgisgrassmodule>
-""","v.surf.idw":"""
-<qgisgrassmodule label="Interpolate attribute values (IDW)" module="v.surf.idw">
- <option key="input" layeroption="layer" typemask="point,line" id="input" />
- <field key="column" layerid="input" type="integer,double" label="Attribute field (interpolated values)" />
- <option key="npoints" />
-</qgisgrassmodule>
-import xml.dom.minidom
-import menuform
-class handleQgisGrass:
- def __init__(self, qgisgrass):
- modules = qgisgrass.childNodes[0].GetElementsByTagName('modules')[0]
- for child in modules.childNodes:
- if child.localName == 'grass':
- self.handleGrass( child )
- elif child.localName == 'section':
- self.handleSection( child )
- def handleSection( self,section ):
- for child in section.GetElementsByTagName('grass'):
- def handleGrass( self, grass ):
- raise NotImplementedError
-class printQgisGrass( handleQgisGrass ):
- print "in qgisgrass"
- handleQgisGrass.__init__( self, qgisgrass )
- print "Section:",section.getAttribute('label')
- handleQgisGrass.handleSection( self, section )
- print "Command:",grass.getAttribute('name')
-class wxQgisGrass( handleQgisGrass ):
- pass
-class handleQgisGrassModule:
- def __init__( self, qgisgrassmodule):
- qgisgrassm = qgisgrassmodule.GetElementsByTagName( "qgisgrassmodule" )[0]
- self.handleAttributes( qgisgrassm )
- for inner in qgisgrassm.childNodes:
- it = inner.localName
- if it == 'option':
- self.handleOption( inner )
- elif it == 'flag':
- self.handleFlag( inner )
- elif it is not None:
- self.handleOther( inner )
- def handleAttributes( self, node ):
- for (l,a) in node.attributes.items():
- self.handleAttribute( l, a, node )
- def handleAttribute( self, label, value, parent ):
- def handleOption( self, option ):
- self.handleAttributes( option )
- def handleFlag( self, flag ):
- self.handleAttributes( flag )
- def handleOther( self, other ):
- self.handleAttributes( other )
-class printQgisGrassModule( handleQgisGrassModule ):
- self.handleOption = self.printHandler
- self.handleFlag = self.printHandler
- self.handleOther = self.printHandler
- print "in qgisgrassmodule"
- handleQgisGrassModule.__init__( self, qgisgrassmodule )
- def printHandler( self, opt ):
- print opt.localName
- handleQgisGrassModule.handleOther( self, opt )
- print
- def handleAttribute( self, label, value, option ):
- print "%s:%s" % (label, value)
-class wxQgisGrassModule( handleQgisGrassModule ):
- def __init__(self, qgisgrassmodule, label='' ):
- """qgisGrassModule is a string containing the .qgm xml file"""
- self.task = None
- self.label = label
- self.description = ''
- self.task.description = self.description
- menuform.GrassGUIApp( self.task ).MainLoop()
- def handleOption( self, opt, getit = menuform.grassTask.get_param, **other ):
- a = dict(opt.attributes.items())
- p = getit( self.task, a['key'] )
- # visibility:
- p['guisection'] = _( 'Main' ) # this should be the only tab present
- p['hidden'] = 'no' # unhide params ...
- if a.get('hidden','no') == 'yes': p['hidden'] = 'yes' # ...except when explicitly hidden
- # overrides:
- if a.has_key( 'answer' ): p['value'] = a['answer']
- if a.has_key( 'label' ): p['description'] = a['label']
- for (k,i) in other.items():
- p[k] = i
- # exclusions:
- if a.has_key('exclude'):
- vals = p['value'].split(',')
- exclusions = a['exclude'].split( ',' )
- for excluded in exclusions:
- if excluded in vals:
- idx = vals.index(excluded)
- vals[ idx:idx+1 ] = []
- p['value'] = ','.join( vals )
- if p.get('default','') in exclusions: p['default'] = ''
- def handleOther( self, opt ):
- tag = opt.localName
- att = dict( opt.attributes.items() )
- if tag == 'field':
- pass
- elif tag == 'file':
- filters = dict(opt.attributes.items()).get('filters','(*.*)')
- try:
- glob = re.match(r'\((.+)\)').groups(0)
- except KeyError:
- glob = '*.*'
- self.handleOption( opt, gisprompt=True, element='file', filemask=glob )
- elif tag == 'selection':
- pass
- self.handleOption( flag, getit = menuform.grassTask.get_flag )
- if option.localName == 'qgisgrassmodule':
- if label=='module':
- self.task = menuform.grassTask( grassModule = value )
- for pf in self.task.params + self.task.flags:
- pf['hidden'] = 'yes' # hide eveything initially
- if label=='label':
- self.description = value
-from sys import argv
-if __name__ == '__main__':
- if len( argv ) != 2:
- print "Usage: %s <toolbox command>" % sys.argv[0]
- else:
- the_module = argv[1]
- if the_module != 'test':
- qgm = open( the_module ).read()
- x = wxQgisGrassModule( xml.dom.minidom.parseString( qgm ), label = the_module )
- else:
- # self test
- config = xml.dom.minidom.parseString( test_config )
- printQgisGrass( config )
- print
- for m in test_modules.keys():
- print m
- module = xml.dom.minidom.parseString( test_modules[m] )
- printQgisGrassModule( module )
- print "----------------"
- m = "r.to.vect.area"
- x = wxQgisGrassModule( xml.dom.minidom.parseString( test_modules[ m ] ), label = m )
