[GRASS-SVN] r35180 - grass/trunk/general/g.mapsets
svn_grass at osgeo.org
Sat Jan 3 06:08:19 EST 2009
Author: martinl
Date: 2009-01-03 06:08:18 -0500 (Sat, 03 Jan 2009)
New Revision: 35180
Added:
grass/trunk/general/g.mapsets/g.mapsets.py
Removed:
grass/trunk/general/g.mapsets/g.mapsets.tcl
grass/trunk/general/g.mapsets/Makefile
grass/trunk/general/g.mapsets/dsply_maps.c
grass/trunk/general/g.mapsets/dsply_path.c
grass/trunk/general/g.mapsets/local_proto.h
grass/trunk/general/g.mapsets/main.c
g.mapsets: new parameter: field separator
g.mapsets.tcl -> g.mapsets.py
Modified: grass/trunk/general/g.mapsets/Makefile
--- grass/trunk/general/g.mapsets/Makefile 2009-01-02 23:49:02 UTC (rev 35179)
+++ grass/trunk/general/g.mapsets/Makefile 2009-01-03 11:08:18 UTC (rev 35180)
@@ -2,7 +2,7 @@
MODULE_TOPDIR = ../..
PGM = g.mapsets
-GUI = $(ETC)/g.mapsets.tcl
+GUI = $(ETC)/gui/g.mapsets.py
LIBES = $(GISLIB)
DEPENDENCIES= $(GISDEP)
@@ -11,6 +11,6 @@
default: cmd $(GUI)
-$(ETC)/%: %
+$(ETC)/gui/%: %
if [ ! -d $(ETC) ]; then $(MKDIR) $(ETC); fi
$(INSTALL) $< $@
Modified: grass/trunk/general/g.mapsets/dsply_maps.c
--- grass/trunk/general/g.mapsets/dsply_maps.c 2009-01-02 23:49:02 UTC (rev 35179)
+++ grass/trunk/general/g.mapsets/dsply_maps.c 2009-01-03 11:08:18 UTC (rev 35180)
@@ -1,16 +1,19 @@
#include <string.h>
#include <stdio.h>
+#include <grass/glocale.h>
#include "externs.h"
static int display1(void);
-static int display2(void);
+static int display2(const char *fs);
-int display_available_mapsets(int verbose)
+int display_available_mapsets(const char* fs)
- if (verbose)
+ if (!fs)
display1();
else
- display2();
+ display2(fs);
return 0;
@@ -19,7 +22,7 @@
int n;
- fprintf(stdout, "Available mapsets:");
+ fprintf(stdout, _("Available mapsets:"));
for (n = 0; n < nmapsets; n++) {
if (n % 4)
fprintf(stdout, " ");
@@ -29,13 +32,13 @@
fprintf(stdout, "\n");
if (nmapsets == 0)
- fprintf(stdout, "** no mapsets **\n");
+ fprintf(stdout, _("** no mapsets **\n"));
return 0;
int nleft, len, n;
char *name;
@@ -47,7 +50,9 @@
nleft = 78;
- fprintf(stdout, "%s ", name);
+ fprintf(stdout, "%s", name);
+ if (n < nmapsets-1)
+ fprintf(stdout, "%s", fs);
nleft -= (len + 1);
Modified: grass/trunk/general/g.mapsets/dsply_path.c
--- grass/trunk/general/g.mapsets/dsply_path.c 2009-01-02 23:49:02 UTC (rev 35179)
+++ grass/trunk/general/g.mapsets/dsply_path.c 2009-01-03 11:08:18 UTC (rev 35180)
@@ -1,8 +1,9 @@
#include <string.h>
+#include <grass/gis.h>
-#include <grass/gis.h>
-int display_mapset_path(int verbose)
+int display_mapset_path(const char *fs)
int n;
int map; /* pointer into list of available mapsets */
@@ -11,22 +12,22 @@
int len;
int nleft;
- if (verbose) {
+ if (!fs) {
/* account for largest mapset number in offset value */
for (n = nmapsets; n /= 10; offset++) ;
- fprintf(stdout, "Your mapset search list:\n");
+ fprintf(stdout, _("Your mapset search list:\n"));
ncurr_mapsets = 0;
nleft = 78;
- for (n = 0; name = G__mapset_name(n); n++) {
+ for (n = 0; (name = G__mapset_name(n)); n++) {
/* match each mapset to its numeric equivalent */
- if (verbose) {
+ if (!fs) {
for (map = 0; map < nmapsets && strcmp(mapset_name[map], name);
map++) ;
if (map == nmapsets)
- G_fatal_error("%s not found in mapset list: call greg",
+ G_fatal_error(_("<%s> not found in mapset list"),
name);
@@ -36,7 +37,7 @@
nleft = 78;
- if (verbose) {
+ if (!fs) {
if (n)
fprintf(stdout, ", ");
fprintf(stdout, "%s <%d>", name, map + 1);
@@ -45,12 +46,14 @@
++ncurr_mapsets;
else {
+ if (G__mapset_name(n+1))
nleft -= (len + 1);
- if (verbose)
+ if (!fs)
return 0;
Added: grass/trunk/general/g.mapsets/g.mapsets.py
--- grass/trunk/general/g.mapsets/g.mapsets.py (rev 0)
+++ grass/trunk/general/g.mapsets/g.mapsets.py 2009-01-03 11:08:18 UTC (rev 35180)
@@ -0,0 +1,160 @@
+#!/usr/bin/env python
+import os
+import sys
+import pwd
+import grass
+import wx
+import wx.lib.mixins.listctrl as listmix
+class MapsetsFrame(wx.Frame):
+ def __init__(self):
+ wx.Frame.__init__(self, parent = None, id = wx.ID_ANY,
+ title = "Check mapsets to access")
+ self.SetMinSize((350, 400))
+ sizer = wx.BoxSizer(wx.VERTICAL)
+ # list of mapsets
+ self.mapsetlb = CheckListMapset(parent=self)
+ self.mapsetlb.LoadData()
+ sizer.Add(item=self.mapsetlb, proportion=1,
+ flag=wx.ALL | wx.EXPAND, border=5)
+ # dialog buttons
+ line = wx.StaticLine(parent=self, id=wx.ID_ANY,
+ style=wx.LI_HORIZONTAL)
+ sizer.Add(item=line, proportion=0,
+ flag=wx.EXPAND | wx.ALIGN_CENTRE | wx.ALL, border=5)
+ btnsizer = wx.StdDialogButtonSizer()
+ btnOK = wx.Button(self, wx.ID_OK)
+ btnOK.Bind(wx.EVT_BUTTON, self.OnOK)
+ btnOK.SetToolTipString("Close dialog and apply changes")
+ btnOK.SetDefault()
+ btnsizer.AddButton(btnOK)
+ btnCancel = wx.Button(self, wx.ID_CANCEL)
+ btnCancel.Bind(wx.EVT_BUTTON, self.OnCancel)
+ btnCancel.SetToolTipString("Close dialog and ignore changes")
+ btnsizer.AddButton(btnCancel)
+ btnsizer.Realize()
+ sizer.Add(item=btnsizer, proportion=0,
+ flag=wx.EXPAND | wx.ALIGN_RIGHT | wx.ALL, border=5)
+ # do layout
+ self.Layout()
+ self.SetSizer(sizer)
+ sizer.Fit(self)
+ def GetMapsets(self):
+ """Get list of checked mapsets"""
+ ms = []
+ i = 0
+ for mset in self.mapsetlb.mapsets:
+ if self.mapsetlb.IsChecked(i):
+ ms.append(mset)
+ i += 1
+ return ms
+ def OnCancel(self, event):
+ """Button 'Cancel' pressed"""
+ self.Close()
+ def OnOK(self, event):
+ """Button 'OK' pressed"""
+ mapsets = ','.join(self.GetMapsets())
+ grass.run_command('g.mapsets',
+ quiet = True,
+ mapset = mapsets)
+ self.Close()
+class CheckListMapset(wx.ListCtrl, listmix.ListCtrlAutoWidthMixin, listmix.CheckListCtrlMixin):
+ """List of mapset/owner/group"""
+ def __init__(self, parent, pos=wx.DefaultPosition,
+ log=None):
+ self.parent = parent
+ wx.ListCtrl.__init__(self, parent, wx.ID_ANY,
+ style=wx.LC_REPORT)
+ listmix.CheckListCtrlMixin.__init__(self)
+ self.log = log
+ # setup mixins
+ listmix.ListCtrlAutoWidthMixin.__init__(self)
+ def LoadData(self):
+ """Load data into list"""
+ self.InsertColumn(0, 'Mapset')
+ self.InsertColumn(1, 'Owner')
+ self.InsertColumn(2, 'Group')
+ gisenv = grass.gisenv()
+ locationPath = os.path.join(gisenv['GISDBASE'], gisenv['LOCATION_NAME'])
+ self.curr_mapset = gisenv['MAPSET']
+ ret = grass.read_command('g.mapsets',
+ flags = 'l',
+ fs = ';')
+ self.mapsets = []
+ if ret:
+ self.mapsets = ret.replace('\n', '').split(';')
+ flags = 'p',
+ fs = ';')
+ mapsets_access = []
+ if ret:
+ mapsets_access = ret.replace('\n', '').split(';')
+ for mapset in self.mapsets:
+ index = self.InsertStringItem(sys.maxint, mapset)
+ mapsetPath = os.path.join(locationPath,
+ mapset)
+ stat_info = os.stat(mapsetPath)
+ if os.name in ('posix', 'mac'):
+ self.SetStringItem(index, 1, "%s" % pwd.getpwuid(stat_info.st_uid)[0])
+ # FIXME: get group name
+ self.SetStringItem(index, 2, "%-8s" % stat_info.st_gid)
+ else:
+ # FIXME: no pwd under MS Windows (owner: 0, group: 0)
+ self.SetStringItem(index, 1, "%-8s" % stat_info.st_uid)
+ if mapset in mapsets_access:
+ self.CheckItem(self.mapsets.index(mapset), True)
+ self.SetColumnWidth(col=0, width=wx.LIST_AUTOSIZE)
+ self.SetColumnWidth(col=1, width=wx.LIST_AUTOSIZE)
+ def OnCheckItem(self, index, flag):
+ """Mapset checked/unchecked"""
+ mapset = self.mapsets[index]
+ if mapset == 'PERMANENT' or mapset == self.curr_mapset:
+ self.CheckItem(index, True)
+class MyApp(wx.App):
+ def OnInit(self):
+ frame = MapsetsFrame()
+ frame.CentreOnScreen()
+ frame.Show()
+ self.SetTopWindow(frame)
+ return True
+if __name__ == "__main__":
+ app = MyApp(0)
+ app.MainLoop()
Property changes on: grass/trunk/general/g.mapsets/g.mapsets.py
___________________________________________________________________
+ text/x-python
+ Author Date Id
+ native
Deleted: grass/trunk/general/g.mapsets/g.mapsets.tcl
--- grass/trunk/general/g.mapsets/g.mapsets.tcl 2009-01-02 23:49:02 UTC (rev 35179)
+++ grass/trunk/general/g.mapsets/g.mapsets.tcl 2009-01-03 11:08:18 UTC (rev 35180)
@@ -1,94 +0,0 @@
-#!/bin/sh
-# the next line restarts using wish \
-exec $GRASS_WISH "$0" "$@"
-# Put current mapset and PERMANENT at the top of the list, mapsets are later written to SEARCH_PATH
-# and searched in this order
-lappend auto_path $env(GISBASE)/bwidget
-package require -exact BWidget 1.2.1
-set env(GISDBASE) [exec g.gisenv get=GISDBASE]
-set env(LOCATION_NAME) [exec g.gisenv get=LOCATION_NAME]
-set env(MAPSET) [exec g.gisenv get=MAPSET]
-# Include the select dialog code because it defines scroll bindings
-source $env(GISBASE)/etc/gtcltk/select.tcl
-proc set_mapsets { } {
- global ms_ch ms_name nms
- set first 1
- set arg "mapset="
- for {set i 0} {$i < $nms} {incr i 1} {
- set ms $ms_name($i)
- if { $ms_ch($ms) } {
- if { !$first } { append arg "," }
- append arg "$ms"
- set first 0
- exec g.mapsets $arg
-set mainw [TitleFrame .mainw -relief sunken -borderwidth 1 \
- -text "Check mapsets to access" -fg mediumblue -side center -baseline top]
-set mainfr [$mainw getframe]
-pack $mainw -fill both -expand yes
-set sw [ScrolledWindow $mainfr.sw -relief flat -borderwidth 2]
-set sf [ScrollableFrame $mainfr.sf -width 175 -height 200]
-$sw setwidget $sf
-bind_scroll $sf
-pack $sw -fill both -expand yes
-set sframe [$sf getframe]
-# Add current mapset and PERMANENT
-set current [exec g.gisenv get=MAPSET]
-if { $current == "PERMANENT" } {
- set msts $current
-} else {
- set msts [list $current PERMANENT]
-set tmp_msts [ lsort [split [exec g.mapsets -l] " \n"] ]
-foreach ms $tmp_msts {
- if { $ms == $current || $ms == "PERMANENT" } { continue }
- lappend msts $ms
-set nms 0
-foreach ms $msts {
- if { [string length $ms] == 0 } { continue }
- set fr [frame $sframe.f$nms]
- pack $fr -side top -anchor w
- set cb [checkbutton $fr.cb -text "$ms" -variable ms_ch($ms) -command set_mapsets]
- if { $ms == $current } {
- $cb configure -state disabled
- pack $cb -side left
- set ms_name($nms) $ms
- incr nms
-# check in selected
-set msts [split [exec g.mapsets -p] " \n"]
-foreach ms $msts {
- set ms_ch($ms) 1
- continue
- set ms_ch($ms) 1
-set close [button $mainw.close -text "OK" -command { exit } ]
-#pack $mainw
-pack $close -side bottom
Modified: grass/trunk/general/g.mapsets/local_proto.h
--- grass/trunk/general/g.mapsets/local_proto.h 2009-01-02 23:49:02 UTC (rev 35179)
+++ grass/trunk/general/g.mapsets/local_proto.h 2009-01-03 11:08:18 UTC (rev 35180)
@@ -1,8 +1,8 @@
/* dsply_maps.c */
-int display_available_mapsets(int);
+int display_available_mapsets(const char *);
/* dsply_path.c */
-int display_mapset_path(int);
+int display_mapset_path(const char *);
/* get_maps.c */
int get_available_mapsets(void);
Modified: grass/trunk/general/g.mapsets/main.c
--- grass/trunk/general/g.mapsets/main.c 2009-01-02 23:49:02 UTC (rev 35179)
+++ grass/trunk/general/g.mapsets/main.c 2009-01-03 11:08:18 UTC (rev 35180)
@@ -8,8 +8,9 @@
* Hamish Bowman <hamish_nospam yahoo.com>,
* Markus Neteler <neteler itc.it>,
* Moritz Lennert <mlennert club.worldonline.be>
+ * Martin Landa <landa.martin gmail.com>
* PURPOSE: set current mapset path
- * COPYRIGHT: (C) 1994-2008 by the GRASS Development Team
+ * COPYRIGHT: (C) 1994-2009 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -46,12 +47,16 @@
int no_tokens;
FILE *fp;
char path[GPATH_MAX];
- struct GModule *module;
- struct Option *opt1, *opt2, *opt3;
- struct Flag *print;
- struct Flag *list;
- struct Flag *tcl;
+ struct GModule *module;
+ struct _opt {
+ struct Option *mapset, *add, *remove;
+ struct Option *fs;
+ struct Flag *print;
+ struct Flag *list;
+ struct Flag *dialog;
+ } opt;
G_gisinit(argv[0]);
module = G_define_module();
@@ -61,59 +66,62 @@
"search path, affecting the user's access to data existing "
"under the other GRASS mapsets in the current location.");
- opt1 = G_define_option();
- opt1->key = "mapset";
- opt1->type = TYPE_STRING;
- opt1->required = NO;
- opt1->multiple = YES;
- opt1->description = _("Name(s) of existing mapset(s)");
+ opt.mapset = G_define_option();
+ opt.mapset->key = "mapset";
+ opt.mapset->type = TYPE_STRING;
+ opt.mapset->required = NO;
+ opt.mapset->multiple = YES;
+ opt.mapset->description = _("Name(s) of existing mapset(s)");
- opt2 = G_define_option();
- opt2->key = "addmapset";
- opt2->type = TYPE_STRING;
- opt2->required = NO;
- opt2->multiple = YES;
- opt2->description =
+ opt.add = G_define_option();
+ opt.add->key = "addmapset";
+ opt.add->type = TYPE_STRING;
+ opt.add->required = NO;
+ opt.add->multiple = YES;
+ opt.add->description =
_("Name(s) of existing mapset(s) to add to search list");
- opt3 = G_define_option();
- opt3->key = "removemapset";
- opt3->type = TYPE_STRING;
- opt3->required = NO;
- opt3->multiple = YES;
- opt3->description =
+ opt.remove = G_define_option();
+ opt.remove->key = "removemapset";
+ opt.remove->type = TYPE_STRING;
+ opt.remove->required = NO;
+ opt.remove->multiple = YES;
+ opt.remove->description =
_("Name(s) of existing mapset(s) to remove from search list");
+ opt.fs = G_define_standard_option(G_OPT_F_SEP);
+ opt.fs->answer = " ";
+ opt.list = G_define_flag();
+ opt.list->key = 'l';
+ opt.list->description = _("List all available mapsets");
- list = G_define_flag();
- list->key = 'l';
- list->description = _("List all available mapsets");
+ opt.print = G_define_flag();
+ opt.print->key = 'p';
+ opt.print->description = _("Print current mapset search path");
- print = G_define_flag();
- print->key = 'p';
- print->description = _("Print current mapset search path");
+ opt.dialog = G_define_flag();
+ opt.dialog->key = 's';
+ opt.dialog->description = _("Show mapset selection dialog");
- tcl = G_define_flag();
- tcl->key = 's';
- tcl->description = _("Show mapset selection dialog");
Path[0] = '\0';
nchoices = 0;
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- if (list->answer) {
+ if (opt.list->answer) {
get_available_mapsets();
- display_available_mapsets(0);
+ display_available_mapsets(opt.fs->answer);
- if (tcl->answer) {
- sprintf(path, "%s/etc/g.mapsets.tcl", G_gisbase());
- G_spawn(path, "g.mapsets.tcl", NULL);
+ if (opt.dialog->answer) {
+ sprintf(path, "%s/etc/gui/g.mapsets.py", G_gisbase());
+ G_spawn("python", "g.mapsets.py", path, NULL);
- if (opt1->answer) {
- for (ptr = opt1->answers; *ptr != NULL; ptr++) {
+ if (opt.mapset->answer) {
+ for (ptr = opt.mapset->answers; *ptr != NULL; ptr++) {
const char *mapset;
mapset = *ptr;
@@ -126,7 +134,7 @@
/* add to existing search path */
- if (opt2->answer) {
+ if (opt.add->answer) {
const char *oldname;
Path[0] = '\0';
@@ -138,7 +146,7 @@
/* fetch and add new mapsets from param list */
- for (ptr = opt2->answers; *ptr != NULL; ptr++) {
+ for (ptr = opt.add->answers; *ptr != NULL; ptr++) {
char *mapset;
mapset = *ptr;
@@ -155,7 +163,7 @@
/* remove from existing search path */
- if (opt3->answer) {
+ if (opt.remove->answer) {
Path[0] = '\0';
@@ -164,7 +172,7 @@
for (n = 0; (oldname = G__mapset_name(n)); n++) {
int found = 0;
- for (ptr = opt3->answers; *ptr; ptr++)
+ for (ptr = opt.remove->answers; *ptr; ptr++)
if (strcmp(oldname, *ptr) == 0)
found = 1;
@@ -183,7 +191,10 @@
/* stuffem sets nchoices */
if (nchoices == 0) {
- goto DISPLAY;
+ if (opt.print->answer)
+ display_mapset_path(opt.fs->answer);
+ exit(EXIT_SUCCESS);
/* note I'm assuming that mapsets cannot have ' 's in them */
@@ -232,9 +243,5 @@
fclose(fp);
G_free_tokens(tokens);
- DISPLAY:
- if (print->answer)
- display_mapset_path(0);
exit(EXIT_SUCCESS);
