[GRASS-SVN] r35185 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun Jan 4 01:19:00 EST 2009
Author: cmbarton
Date: 2009-01-04 01:18:59 -0500 (Sun, 04 Jan 2009)
New Revision: 35185
grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
Fix bug in TableSelect.InsertTables that caused v.db.connect to crash. Also fixed bogus error message when selecting items.
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2009-01-03 17:28:53 UTC (rev 35184)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2009-01-04 06:18:59 UTC (rev 35185)
@@ -125,8 +125,11 @@
if not root:
return
item = self.FindItem(root, self.value[0])
- self.seltree.EnsureVisible(item)
- self.seltree.SelectItem(item)
+ try:
+ self.seltree.SelectItem(item)
+ self.seltree.EnsureVisible(item)
+ except:
+ pass
def SetStringValue(self, value):
# this assumes that item strings are unique...
@@ -483,18 +486,16 @@
def InsertTables(self, driver=None, database=None):
"""Insert attribute tables into combobox"""
items = []
- ret = gcmd.RunCommand('db.tables',
- flag = 'p',
- parent = self,
- driver = driver,
- database = database)
+ tableCmd = None
+ ret = grass.read_command('db.tables',
+ flags = 'p',
+ driver = driver,
+ database = database)
- if ret != 0:
+ if ret == None:
tableCmd = None
- if tableCmd and \
- tableCmd.returncode == 0:
- for table in tableCmd.ReadStdOutput():
+ else:
+ for table in ret.split('\n'):
items.append(table)
self.SetItems(items)
