[GRASS-SVN] r35216 - grass/trunk/raster/r.sun2
    svn_grass at osgeo.org
    Mon Jan  5 03:00:11 EST 2009
Author: neteler
Date: 2009-01-05 03:00:10 -0500 (Mon, 05 Jan 2009)
New Revision: 35216
   grass/trunk/raster/r.sun2/r.sun.html
formula to calculate memory consumption
Modified: grass/trunk/raster/r.sun2/r.sun.html
--- grass/trunk/raster/r.sun2/r.sun.html	2009-01-04 19:34:04 UTC (rev 35215)
+++ grass/trunk/raster/r.sun2/r.sun.html	2009-01-05 08:00:10 UTC (rev 35216)
@@ -184,10 +184,29 @@
 <h3>Large maps and out of memory problems</h3>
+With a large number or columns and rows, <b>r.sun</b> can consume
+significant amount of memory. While output raster maps are not
+partitionable, the input raster maps are using the <em>numpartitions</em>
+parameter.
 In case of out of memory error (<tt>ERROR: G_malloc: out of memory</tt>), the
 <em>numpartitions</em> parameter can be used to run a segmented calculation
 which consumes less memory during the computations.
+The amount of memory by <b>r.sun</b> is estimated as follows:
+<div class="code"><pre>
+# without input raster map partitioning:
+#  memory requirements: 4 bytes per raster cell
+#  rows,cols: rows and columns of current region (find out with g.region)
+#  IR: number of input raster maps without horizon maps
+#  OR: number of output raster maps
+memory_bytes = rows*cols*(IR*4 + horizonsteps + OR*4)
+# with input raster map partitioning:
+memory_bytes = rows*cols*((IR*4+horizonsteps)/numpartitions  + OR*4)
+</pre></div>
 <h3>Example</h3>
 Spearfish example (considering also cast shadows):
