[GRASS-SVN] r35232 - in grass/trunk: display/d.font general/g.copy
imagery/i.zc raster/r.circle raster/r.out.gdal
scripts/r.blend scripts/r.out.xyz
svn_grass at osgeo.org
Mon Jan 5 17:11:48 EST 2009
Author: neteler
Date: 2009-01-05 17:11:47 -0500 (Mon, 05 Jan 2009)
New Revision: 35232
grass/trunk/display/d.font/d.font.html
grass/trunk/general/g.copy/g.copy.html
grass/trunk/imagery/i.zc/i.zc.html
grass/trunk/raster/r.circle/r.circle.html
grass/trunk/raster/r.out.gdal/r.out.gdal.html
grass/trunk/scripts/r.blend/r.blend.html
grass/trunk/scripts/r.out.xyz/r.out.xyz.html
urls fixed
Modified: grass/trunk/display/d.font/d.font.html
--- grass/trunk/display/d.font/d.font.html 2009-01-05 22:08:26 UTC (rev 35231)
+++ grass/trunk/display/d.font/d.font.html 2009-01-05 22:11:47 UTC (rev 35232)
@@ -16,8 +16,7 @@
run non-interactively.
Alternately, the user can simply type <B>d.font</B> on the command line;
in this case, the program will prompt the user for a display
-text font type using the standard GRASS interface described in the
-manual entry for <EM><A HREF="parser.html">parser</A></EM>.
+text font type.
<P>
<B>Parameter:</B>
@@ -58,8 +57,7 @@
<H2>SEE ALSO</H2>
<EM><A HREF="d.text.html">d.text</A></EM><br>
-<EM><A HREF="d.title.html">d.title</A></EM><br>
-<EM><A HREF="parser.html">parser</A></EM>
+<EM><A HREF="d.title.html">d.title</A></EM>
<H2>AUTHOR</H2>
Modified: grass/trunk/general/g.copy/g.copy.html
--- grass/trunk/general/g.copy/g.copy.html 2009-01-05 22:08:26 UTC (rev 35231)
+++ grass/trunk/general/g.copy/g.copy.html 2009-01-05 22:11:47 UTC (rev 35232)
@@ -71,8 +71,7 @@
<em><a HREF="g.list.html">g.list</a></em><br>
<em><a HREF="g.mapsets.html">g.mapsets</a></em><br>
<em><a HREF="g.remove.html">g.remove</a></em><br>
-<em><a HREF="g.rename.html">g.rename</a></em><br>
-<em><a HREF="parser.html">parser</a></em>
+<em><a HREF="g.rename.html">g.rename</a></em>
<h2>AUTHOR</h2>
Modified: grass/trunk/imagery/i.zc/i.zc.html
--- grass/trunk/imagery/i.zc/i.zc.html 2009-01-05 22:08:26 UTC (rev 35231)
+++ grass/trunk/imagery/i.zc/i.zc.html 2009-01-05 22:11:47 UTC (rev 35232)
@@ -9,19 +9,6 @@
used for edge detection is one of the "zero-crossing"
algorithms and is discussed briefly below.
-<P>
-This program will be run interactively if the user types
-<B>i.zc</B> without program arguments on the command line.
-In this event, the program will prompt the user for
-parameter values using the standard interface described in
-the manual entry for <EM><A HREF="parser.html">parser</A></EM>.
-Alternately, the
-user can run the program non-interactively by specifying
-program parameter values on the command line.
<H2>OPTIONS</H2>
<H3>Parameters:</H3>
Modified: grass/trunk/raster/r.circle/r.circle.html
--- grass/trunk/raster/r.circle/r.circle.html 2009-01-05 22:08:26 UTC (rev 35231)
+++ grass/trunk/raster/r.circle/r.circle.html 2009-01-05 22:11:47 UTC (rev 35232)
@@ -44,7 +44,7 @@
<a href="g.rename.html">g.rename</a>,
<a href="i.fft.html">i.fft</a>,
<a href="i.ifft.html">i.ifft</a>,
-<a href="r.mask">r.mask</a>
+<a href="r.mask.html">r.mask</a>
</em>
Modified: grass/trunk/raster/r.out.gdal/r.out.gdal.html
--- grass/trunk/raster/r.out.gdal/r.out.gdal.html 2009-01-05 22:08:26 UTC (rev 35231)
+++ grass/trunk/raster/r.out.gdal/r.out.gdal.html 2009-01-05 22:11:47 UTC (rev 35232)
@@ -76,7 +76,7 @@
Please keep in mind that not all CELL rasters will require Int32 - e.g.,
0-255 CELL raster are covered by the Byte <em>type</em> as well.
Moreover, some GDAL-supported formats do not support all the data types
-possible in GDAL and GRASS. Use <em><a href="r.info">r.info</a></em> to
+possible in GDAL and GRASS. Use <em><a href="r.info.html">r.info</a></em> to
check the data type and range for your GRASS raster, refer to specific
format documentation (on the <a href="http://www.gdal.org/">GDAL website</a>),
format vendor's documentation, and e.g. the Wikipedia article
Modified: grass/trunk/scripts/r.blend/r.blend.html
--- grass/trunk/scripts/r.blend/r.blend.html 2009-01-05 22:08:26 UTC (rev 35231)
+++ grass/trunk/scripts/r.blend/r.blend.html 2009-01-05 22:11:47 UTC (rev 35232)
@@ -8,7 +8,7 @@
<EM>
<A HREF="g.region.html">g.region</A>,
<A HREF="r.mapcalc.html">r.mapcalc</A>,
-<A HREF="r.color.html">r.color</A>,
+<A HREF="r.colors.html">r.colors</A>,
<A HREF="r.support.html">r.support</A>,
</EM>
Modified: grass/trunk/scripts/r.out.xyz/r.out.xyz.html
--- grass/trunk/scripts/r.out.xyz/r.out.xyz.html 2009-01-05 22:08:26 UTC (rev 35231)
+++ grass/trunk/scripts/r.out.xyz/r.out.xyz.html 2009-01-05 22:11:47 UTC (rev 35232)
@@ -27,9 +27,9 @@
<EM>
-<A HREF="r.mask">r.mask</A>
+<A HREF="r.mask.html">r.mask</A>
<A HREF="r.out.ascii.html">r.out.ascii</A>,
-<A HREF="r.stats">r.stats</A>
+<A HREF="r.stats.html">r.stats</A>
</EM>
<H2>AUTHOR</H2>
