[GRASS-SVN] r35267 - in grass-addons/vector: . v.db.calc
svn_grass at osgeo.org
Wed Jan 7 10:53:20 EST 2009
Author: maxi
Date: 2009-01-07 10:53:20 -0500 (Wed, 07 Jan 2009)
New Revision: 35267
Added:
grass-addons/vector/v.db.calc/
grass-addons/vector/v.db.calc/description.html
grass-addons/vector/v.db.calc/v.db.calc
field calculator script
Added: grass-addons/vector/v.db.calc/description.html
--- grass-addons/vector/v.db.calc/description.html (rev 0)
+++ grass-addons/vector/v.db.calc/description.html 2009-01-07 15:53:20 UTC (rev 35267)
@@ -0,0 +1,49 @@
+<H2>DESCRIPTION</H2>
+<EM>v.db.calc</EM> executes a python expression using column values and
+update the target column values: it allows complex calculation also with DBF attribute table.
+<H2>NOTES</H2>
+The v.db.calc must be run with a valid <a href="http://www.python.org/">Python</a> installed.<br>
+The columns within expression should be referred between square brackets <em> [ ] </em>.<br>
+Python functions should be referred with their full name.
+<H2>EXAMPLE</H2>
+Add a new column named EXP and populate it with the values of column "VAL" elevated at 0.25:
+<div class="code"><pre>
+v.db.addcol map=build columns="EXP double"
+v.db.calc input=myvector field=EXP exp="math.pow([VAL], 0.25)"
+</pre></div>
+only where column HEIGHT is bigger then 100:
+v.db.calc input=myvector field=EXP exp="math.pow([VAL], 0.25)" where="HEIGHT>100"
+</pre></div>
+<p>
+Add a new text column named TXT and populte it concatenating <em> Dr. </em> and the text values of the column NAME:
+v.db.addcol map=build columns="TXT varchar(25)"
+v.db.calc input=edifici field=EXP2 exp="'Dr. '+'[NAME]'"
+</pre></div>
+<H2>REFERENCES</H2>
+<a href="http://docs.python.org">Python</a>
+<p>
+<a href="http://docs.python.org/library/cmath.html">Python math library</a>
+<H2>SEE ALSO</H2>
+<EM><A HREF="v.db.update.html">v.db.update</A></EM>
+<H2>AUTHOR</H2>
+Massimiliano Cannata <br>
+<p><i>Last changed: $Date: 2009-01-07 17:45:44 +0100 (Wed, 07 Jan 2009) $</i>
\ No newline at end of file
Added: grass-addons/vector/v.db.calc/v.db.calc
--- grass-addons/vector/v.db.calc/v.db.calc (rev 0)
+++ grass-addons/vector/v.db.calc/v.db.calc 2009-01-07 15:53:20 UTC (rev 35267)
@@ -0,0 +1,154 @@
+#!/usr/bin/python
+# -*- coding:utf-8 -*-
+# MODULE: v.sample.class.py
+# AUTHOR(S): M. Cannata, M. Molinari (IST-SUPSI www.istgis.ist.supsi.ch:8001/GEOMATICA)
+# PURPOSE: Field values calculator
+# COPYRIGHT: (c) 2007 The GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%Module
+#% description: Field values calculator
+#% keywords: vector, field, calculator
+#%end
+#%option
+#% key: input
+#% type: string
+#% gisprompt: old,vector,vector
+#% key_desc : name
+#% description: input
+#% required : yes
+#%end
+#%option
+#% key: field
+#% type: string
+#% key_desc : name
+#% description: field to store results
+#% required : yes
+#%end
+#%option
+#% key: exp
+#% type: string
+#% key_desc : operation
+#% description: expression to execute
+#% required : yes
+#%end
+#%option
+#% key: where
+#% type: string
+#% key_desc : expression
+#% description: where condition to execute
+#% required : no
+#%end
+import os,sys,subprocess,string,random,math,tempfile,time,re
+def main():
+ table = os.getenv('GIS_OPT_input').split('@')[0]
+ field = os.getenv('GIS_OPT_field')
+ exp = os.getenv('GIS_OPT_exp')
+ wherest = os.getenv('GIS_OPT_where')
+ #Get vector fields name
+ cmdargs0=["db.columns","table=%s" %table, "--q"]
+ proc0 = subprocess.Popen(cmdargs0, stdout=subprocess.PIPE,stderr=subprocess.PIPE)
+ colnames = proc0.communicate()[0].split("\n")
+ #print "cols:\n"
+ #for item in colnames: # print each item
+ # print item + "\n"
+ #Parse operation expression
+ spe = re.split("([\[\]])", exp)
+ #Check exp field names validity and get required field list
+ expfields = []
+ for i in range(len(spe)):
+ if(spe[i]=="["):
+ if spe[i+1] not in colnames:
+ print "FATAL ERROR: field " + spe[i+1] + " not found in table " + table + "\n"
+ print "tried SQL: " + spe[i+1] + " not found in table " + table + "\n"
+ return -1
+ else:
+ expfields.append(spe[i+1])
+ #Get unique list of required fields
+ uf = list(set(expfields))
+ #Prepare query statement
+ lf = ", ".join(uf)
+ sel = "SELECT cat"
+ if len(uf)>0:
+ sel = sel + "," + lf
+ sel = sel + " from " + table
+ if wherest:
+ sel = sel + " WHERE " + wherest
+ #Execute query
+ cmdargs1=["db.select","sql=%s" %sel, "--q", "-c"]
+ proc1 = subprocess.Popen(cmdargs1, stdout=subprocess.PIPE,stderr=subprocess.PIPE)
+ lines = proc1.communicate()[0].split("\n")
+ #print "query: " + sel
+ #print "unique list:\n"
+ #for item in uf: # print each item
+ #print "selection:\n"
+ #for item in lines: # print each item
+ #Check query results
+ if len(lines) == 1:
+ print "WARNING: no record selected\n"
+ print "executed query: " + sel + "\n"
+ return -1
+ #Process and UPDATE
+ else:
+ #process lines
+ for l in range(0,len(lines)-1):
+ if l%10==0:
+ print "."
+ cols = lines[l].split("|")
+ evalexp = exp
+ for i in range(len(uf)):
+ evalexp = evalexp.replace("["+uf[i]+"]",cols[i+1])
+ try:
+ #print evalexp + "\n"
+ value = eval(str(evalexp))
+ #except ArithmeticError, e:
+ except StandardError, e:
+ print "\n%s\nIn command: %s" % (repr(e), str(evalexp))
+ return -1
+ #print value
+ updst = "UPDATE " + table + " SET " + field + "=" + str(value) + " WHERE cat=" + cols[0]
+ #print updst
+ cmdargs2=["map=%s"%table,"col=%s"%field,"val=%s"%str(value),"where=cat=%s"%cols[0],"--q"]
+ os.spawnvp(os.P_WAIT,"v.db.update", ["v.db.update"] + cmdargs2)
+ return
+if __name__ == "__main__":
+ if ( len(sys.argv) <= 1 or sys.argv[1] != "@ARGS_PARSED@" ):
+ os.execvp("g.parser", [sys.argv[0]] + sys.argv)
+ else:
+ main();
Property changes on: grass-addons/vector/v.db.calc/v.db.calc
___________________________________________________________________
