[GRASS-SVN] r35274 - in grass/trunk: imagery/i.gensigset
imagery/i.smap include lib/gmath lib/rst/interp_float
raster/r.param.scale raster/r.resamp.rst
vector/lidar/lidarlib vector/v.surf.rst
svn_grass at osgeo.org
Wed Jan 7 14:27:37 EST 2009
Author: glynn
Date: 2009-01-07 14:27:36 -0500 (Wed, 07 Jan 2009)
New Revision: 35274
Removed:
grass/trunk/imagery/i.smap/eigen.c
grass/trunk/imagery/i.gensigset/invert.c
grass/trunk/imagery/i.gensigset/subcluster.c
grass/trunk/imagery/i.smap/bouman.h
grass/trunk/imagery/i.smap/invert.c
grass/trunk/imagery/i.smap/model.c
grass/trunk/include/gisdefs.h
grass/trunk/include/gmath.h
grass/trunk/lib/gmath/eigen.c
grass/trunk/lib/gmath/lu.c
grass/trunk/lib/gmath/svd.c
grass/trunk/lib/rst/interp_float/matrix.c
grass/trunk/lib/rst/interp_float/ressegm2d.c
grass/trunk/lib/rst/interp_float/segmen2d.c
grass/trunk/raster/r.param.scale/process.c
grass/trunk/raster/r.resamp.rst/main.c
grass/trunk/vector/lidar/lidarlib/PolimiFunct.h
grass/trunk/vector/v.surf.rst/main.c
Various files have moved from lib/gis to lib/gmath:
Update gisdefs.h and gmath.h accordingly
Update clients accordingly
Generalise eigen(), remove local version from i.smap
Modified: grass/trunk/imagery/i.gensigset/invert.c
--- grass/trunk/imagery/i.gensigset/invert.c 2009-01-07 19:27:30 UTC (rev 35273)
+++ grass/trunk/imagery/i.gensigset/invert.c 2009-01-07 19:27:36 UTC (rev 35274)
@@ -1,4 +1,5 @@
#include <grass/gis.h>
+#include <grass/gmath.h>
int invert(
/* inverts a matrix of arbitrary size input as a 2D array. */
Modified: grass/trunk/imagery/i.gensigset/subcluster.c
--- grass/trunk/imagery/i.gensigset/subcluster.c 2009-01-07 19:27:30 UTC (rev 35273)
+++ grass/trunk/imagery/i.gensigset/subcluster.c 2009-01-07 19:27:36 UTC (rev 35274)
@@ -3,6 +3,7 @@
#include <grass/imagery.h>
#include <grass/glocale.h>
#include "local_proto.h"
#define ZERO 1e-10
Modified: grass/trunk/imagery/i.smap/bouman.h
--- grass/trunk/imagery/i.smap/bouman.h 2009-01-07 19:27:30 UTC (rev 35273)
+++ grass/trunk/imagery/i.smap/bouman.h 2009-01-07 19:27:36 UTC (rev 35274)
@@ -53,9 +53,6 @@
/* Subroutine in solve.c */
double solve(double (*)(double), double, double, double, int *);
-/* Subroutine in eigen.c */
-int eigen(double **, double *, int);
/* Subroutine in invert.c */
int invert(double **, int);
Deleted: grass/trunk/imagery/i.smap/eigen.c
--- grass/trunk/imagery/i.smap/eigen.c 2009-01-07 19:27:30 UTC (rev 35273)
+++ grass/trunk/imagery/i.smap/eigen.c 2009-01-07 19:27:36 UTC (rev 35274)
@@ -1,33 +0,0 @@
-#include <grass/gis.h>
-int eigen(
- /* Computes eigenvalues (and eigen vectors if desired) for *
- * symmetric matices. */
- double **M, /* Input matrix */
- double *lambda, /* Output eigenvalues */
- int n /* Input matrix dimension */
- int i, j;
- double **a, *e;
- a = G_alloc_matrix(n, n);
- e = G_alloc_vector(n);
- for (i = 0; i < n; i++)
- for (j = 0; j < n; j++)
- a[i][j] = M[i][j];
- G_tred2(a, n, lambda, e);
- G_tqli(lambda, e, n, a);
- /* Returns eigenvectors */
- /* for(i=0; i<n; i++)
- for(j=0; j<n; j++)
- M[i][j] = a[i][j]; */
- G_free_matrix(a);
- G_free_vector(e);
- return 0;
Modified: grass/trunk/imagery/i.smap/invert.c
--- grass/trunk/imagery/i.smap/invert.c 2009-01-07 19:27:30 UTC (rev 35273)
+++ grass/trunk/imagery/i.smap/invert.c 2009-01-07 19:27:36 UTC (rev 35274)
@@ -1,5 +1,6 @@
#include <math.h>
int invert(
Modified: grass/trunk/imagery/i.smap/model.c
--- grass/trunk/imagery/i.smap/model.c 2009-01-07 19:27:30 UTC (rev 35273)
+++ grass/trunk/imagery/i.smap/model.c 2009-01-07 19:27:36 UTC (rev 35274)
@@ -1,6 +1,7 @@
#include "bouman.h"
#include "region.h"
@@ -42,7 +43,7 @@
/* Test for positive definite matrix */
- eigen(SubS->Rinv, lambda, nbands);
+ eigen(SubS->Rinv, NULL, lambda, nbands);
for (b1 = 0; b1 < nbands; b1++) {
if (lambda[b1] <= 0.0)
G_warning(_("Nonpositive eigenvalues for class %d subclass %d"),
Modified: grass/trunk/include/gisdefs.h
--- grass/trunk/include/gisdefs.h 2009-01-07 19:27:30 UTC (rev 35273)
+++ grass/trunk/include/gisdefs.h 2009-01-07 19:27:36 UTC (rev 35274)
@@ -393,16 +393,6 @@
void G_init_counter(struct Counter *, int);
int G_counter_next(struct Counter *);
-/* dalloc.c */
-double *G_alloc_vector(size_t);
-double **G_alloc_matrix(int, int);
-float *G_alloc_fvector(size_t);
-float **G_alloc_fmatrix(int, int);
-void G_free_vector(double *);
-void G_free_matrix(double **);
-void G_free_fvector(float *);
-void G_free_fmatrix(float **);
/* date.c */
const char *G_date(void);
@@ -430,10 +420,6 @@
/* done_msg.c */
void G_done_msg(const char *, ...) __attribute__ ((format(printf, 1, 2)));
-/* eigen_tools.c */
-int G_tqli(double[], double[], int, double **);
-void G_tred2(double **, int, double[], double[]);
/* endian.c */
int G_is_little_endian(void);
@@ -651,12 +637,6 @@
const char *G_home(void);
const char *G__home(void);
-/* ialloc.c */
-int *G_alloc_ivector(size_t);
-int **G_alloc_imatrix(int, int);
-void G_free_ivector(int *);
-void G_free_imatrix(int **);
/* index.c */
char *G_index(const char *, int);
char *G_rindex(const char *, int);
@@ -740,10 +720,6 @@
void G_ls(const char *, FILE *);
void G_ls_format(char **, int, int, FILE *);
-/* lu.c */
-int G_ludcmp(double **, int, int *, double *);
-void G_lubksb(double **, int, int *, double[]);
/* mach_name.c */
const char *G__machine_name(void);
@@ -1097,11 +1073,6 @@
int G_str_to_sql(char *);
char *G_squeeze(char *);
-/* svd.c */
-int G_svdcmp(double **, int, int, double *, double **);
-int G_svbksb(double **, double[], double **, int, int, double[], double[]);
-int G_svelim(double *, int);
/* system.c */
int G_system(const char *);
Modified: grass/trunk/include/gmath.h
--- grass/trunk/include/gmath.h 2009-01-07 19:27:30 UTC (rev 35273)
+++ grass/trunk/include/gmath.h 2009-01-07 19:27:36 UTC (rev 35274)
@@ -68,4 +68,33 @@
int mult(double *v1[2], int size1, double *v2[2], int size2, double *v3[2],
int size3);
+/* dalloc.c */
+double *G_alloc_vector(size_t);
+double **G_alloc_matrix(int, int);
+float *G_alloc_fvector(size_t);
+float **G_alloc_fmatrix(int, int);
+void G_free_vector(double *);
+void G_free_matrix(double **);
+void G_free_fvector(float *);
+void G_free_fmatrix(float **);
+/* eigen_tools.c */
+int G_tqli(double[], double[], int, double **);
+void G_tred2(double **, int, double[], double[]);
+/* ialloc.c */
+int *G_alloc_ivector(size_t);
+int **G_alloc_imatrix(int, int);
+void G_free_ivector(int *);
+void G_free_imatrix(int **);
+/* lu.c */
+int G_ludcmp(double **, int, int *, double *);
+void G_lubksb(double **, int, int *, double[]);
+/* svd.c */
+int G_svdcmp(double **, int, int, double *, double **);
+int G_svbksb(double **, double[], double **, int, int, double[], double[]);
+int G_svelim(double *, int);
#endif /* GMATH_H_ */
Modified: grass/trunk/lib/gmath/eigen.c
--- grass/trunk/lib/gmath/eigen.c 2009-01-07 19:27:30 UTC (rev 35273)
+++ grass/trunk/lib/gmath/eigen.c 2009-01-07 19:27:36 UTC (rev 35274)
@@ -43,9 +43,10 @@
- Vectors[i][j] = a[i][j];
+ if (Vectors)
+ for (i = 0; i < n; i++)
+ for (j = 0; j < n; j++)
+ Vectors[i][j] = a[i][j];
G_free_matrix(a);
G_free_vector(e);
Modified: grass/trunk/lib/gmath/lu.c
--- grass/trunk/lib/gmath/lu.c 2009-01-07 19:27:30 UTC (rev 35273)
+++ grass/trunk/lib/gmath/lu.c 2009-01-07 19:27:36 UTC (rev 35274)
@@ -1,5 +1,6 @@
#include <math.h>
#define TINY 1.0e-20;
Modified: grass/trunk/lib/gmath/svd.c
--- grass/trunk/lib/gmath/svd.c 2009-01-07 19:27:30 UTC (rev 35273)
+++ grass/trunk/lib/gmath/svd.c 2009-01-07 19:27:36 UTC (rev 35274)
@@ -1,5 +1,6 @@
+#include <math.h>
-#include <math.h>
static double at, bt, ct;
Modified: grass/trunk/lib/rst/interp_float/matrix.c
--- grass/trunk/lib/rst/interp_float/matrix.c 2009-01-07 19:27:30 UTC (rev 35273)
+++ grass/trunk/lib/rst/interp_float/matrix.c 2009-01-07 19:27:36 UTC (rev 35274)
@@ -25,6 +25,7 @@
#include <unistd.h>
#include <grass/interpf.h>
int IL_matrix_create(struct interp_params *params, struct triple *points, /* points for interpolation */
int n_points, /* number of points */
Modified: grass/trunk/lib/rst/interp_float/ressegm2d.c
--- grass/trunk/lib/rst/interp_float/ressegm2d.c 2009-01-07 19:27:30 UTC (rev 35273)
+++ grass/trunk/lib/rst/interp_float/ressegm2d.c 2009-01-07 19:27:36 UTC (rev 35274)
@@ -23,6 +23,7 @@
#include <math.h>
static int input_data(struct interp_params *,
int, int, struct fcell_triple *, int, int, int, int,
Modified: grass/trunk/lib/rst/interp_float/segmen2d.c
--- grass/trunk/lib/rst/interp_float/segmen2d.c 2009-01-07 19:27:30 UTC (rev 35273)
+++ grass/trunk/lib/rst/interp_float/segmen2d.c 2009-01-07 19:27:36 UTC (rev 35274)
@@ -8,8 +8,8 @@
#include <math.h>
static double smallest_segment(struct multtree *, int);
Modified: grass/trunk/raster/r.param.scale/process.c
--- grass/trunk/raster/r.param.scale/process.c 2009-01-07 19:27:30 UTC (rev 35273)
+++ grass/trunk/raster/r.param.scale/process.c 2009-01-07 19:27:36 UTC (rev 35274)
@@ -16,6 +16,7 @@
#include <stdlib.h>
#include "param.h"
#include "nrutil.h"
Modified: grass/trunk/raster/r.resamp.rst/main.c
--- grass/trunk/raster/r.resamp.rst/main.c 2009-01-07 19:27:30 UTC (rev 35273)
+++ grass/trunk/raster/r.resamp.rst/main.c 2009-01-07 19:27:36 UTC (rev 35274)
@@ -42,6 +42,7 @@
#include "surf.h"
static double /* pargr */ ns_res, ew_res, inp_ew_res, inp_ns_res;
static int inp_rows, inp_cols;
Modified: grass/trunk/vector/lidar/lidarlib/PolimiFunct.h
--- grass/trunk/vector/lidar/lidarlib/PolimiFunct.h 2009-01-07 19:27:30 UTC (rev 35273)
+++ grass/trunk/vector/lidar/lidarlib/PolimiFunct.h 2009-01-07 19:27:36 UTC (rev 35274)
@@ -20,13 +20,13 @@
#ifndef _POLIMIFUNCT_H_
#define _POLIMIFUNCT_H_
+#include <grass/config.h>
#include <grass/Vect.h>
#include <grass/dbmi.h>
-#include <grass/config.h>
/*CONSTANS DECLARATION */
Modified: grass/trunk/vector/v.surf.rst/main.c
--- grass/trunk/vector/v.surf.rst/main.c 2009-01-07 19:27:30 UTC (rev 35273)
+++ grass/trunk/vector/v.surf.rst/main.c 2009-01-07 19:27:36 UTC (rev 35274)
@@ -44,6 +44,7 @@
#include <grass/qtree.h>
#include "surf.h"
#include <grass/dataquad.h>
#define SCIK1 1 /*100000 */
