[GRASS-SVN] r35281 - grass/trunk/scripts/d.rast.edit
svn_grass at osgeo.org
Wed Jan 7 21:10:26 EST 2009
Author: glynn
Date: 2009-01-07 21:10:26 -0500 (Wed, 07 Jan 2009)
New Revision: 35281
grass/trunk/scripts/d.rast.edit/d.rast.edit.py
Try to fail more gracefully if wx isn't present (--help etc should still work)
Modified: grass/trunk/scripts/d.rast.edit/d.rast.edit.py
--- grass/trunk/scripts/d.rast.edit/d.rast.edit.py 2009-01-08 01:58:44 UTC (rev 35280)
+++ grass/trunk/scripts/d.rast.edit/d.rast.edit.py 2009-01-08 02:10:26 UTC (rev 35281)
@@ -4,7 +4,7 @@
# MODULE: d.rast.edit
# AUTHOR(S): Glynn Clements <glynn at gclements.plus.com>
-# COPYRIGHT: (C) 2007,2008 Glynn Clements
+# COPYRIGHT: (C) 2007,2008,2009 Glynn Clements
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
@@ -90,16 +90,27 @@
#% answer: 100
#%End
-import wxversion
-wxversion.select(['2.8','2.6'])
-#wxversion.select(['2.6','2.8'])
-import wx
import sys
import math
import atexit
import grass
+try:
+ import wxversion
+ wxversion.select(['2.8','2.6'])
+ # wxversion.select(['2.6','2.8'])
+ import wx
+except Exception:
+ # ensure that --help, --interface-description etc work even without wx
+ if __name__ == "__main__":
+ if len(sys.argv) == 2:
+ arg = sys.argv[1]
+ if arg[0:2] == '--' or arg in ["help", "-help"]:
+ grass.parser()
+ # Either we didn't call g.parser, or it returned
+ # At this point, there's nothing to be done except re-raise the exception
+ raise
wind_keys = {
'north': ('n', float),
'south': ('s', float),
