[GRASS-SVN] r35320 - grass/branches/develbranch_6/raster/r.out.gdal
svn_grass at osgeo.org
Sat Jan 10 16:23:33 EST 2009
Author: neteler
Date: 2009-01-10 16:23:33 -0500 (Sat, 10 Jan 2009)
New Revision: 35320
grass/branches/develbranch_6/raster/r.out.gdal/export_band.c
make warnings suppressable with 'GRASS_VERBOSE=0' (for R interface) (merge from trunk, r35319)
Modified: grass/branches/develbranch_6/raster/r.out.gdal/export_band.c
--- grass/branches/develbranch_6/raster/r.out.gdal/export_band.c 2009-01-10 21:23:05 UTC (rev 35319)
+++ grass/branches/develbranch_6/raster/r.out.gdal/export_band.c 2009-01-10 21:23:33 UTC (rev 35320)
@@ -288,12 +288,12 @@
if (n_nulls > 0) { /* TODO: && nodata_param NOT specified */
if (maptype == CELL_TYPE)
- G_warning(_("Input raster map contains cells with NULL-value (no-data). "
+ G_important_message(_("Input raster map contains cells with NULL-value (no-data). "
"The value %d was used to represent no-data values in the input map. "
"You can specify nodata value by %s parameter."),
(int)nodataval, nodatakey);
else
"The value %g was used to represent no-data values in the input map. "
