[GRASS-SVN] r35331 - grass/branches/releasebranch_6_4/vector/v.in.db
svn_grass at osgeo.org
Sun Jan 11 16:20:17 EST 2009
Author: martinl
Date: 2009-01-11 16:20:17 -0500 (Sun, 11 Jan 2009)
New Revision: 35331
grass/branches/releasebranch_6_4/vector/v.in.db/main.c
v.in.db: message cosmetics
(merge from devbr6, r35328)
Modified: grass/branches/releasebranch_6_4/vector/v.in.db/main.c
--- grass/branches/releasebranch_6_4/vector/v.in.db/main.c 2009-01-11 21:19:56 UTC (rev 35330)
+++ grass/branches/releasebranch_6_4/vector/v.in.db/main.c 2009-01-11 21:20:17 UTC (rev 35331)
@@ -6,7 +6,7 @@
* PURPOSE: Create new vector from db table.
- * COPYRIGHT: (C) 2000-2007 by the GRASS Development Team
+ * COPYRIGHT: (C) 2000-2007, 2009 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -25,7 +25,7 @@
int main(int argc, char *argv[])
- int i, cat, with_z, more, ctype, ret;
+ int i, cat, with_z, more, ctype, ret, nrows;
char buf[2000];
int count;
double coor[3];
@@ -49,7 +49,7 @@
G_gisinit(argv[0]);
module = G_define_module();
- module->keywords = _("vector, import");
+ module->keywords = _("vector, import, database, points");
module->description =
_("Creates new vector (points) map from database table containing coordinates.");
@@ -59,10 +59,12 @@
driver_opt = G_define_standard_option(G_OPT_DRIVER);
driver_opt->options = db_list_drivers();
- driver_opt->answer = db_get_default_driver_name();
+ driver_opt->answer = (char *) db_get_default_driver_name();
+ driver_opt->guisection = _("Connection");
database_opt = G_define_standard_option(G_OPT_DATABASE);
- database_opt->answer = db_get_default_database_name();
+ database_opt->answer = (char *) db_get_default_database_name();
+ database_opt->guisection = _("Connection");
xcol_opt = G_define_standard_option(G_OPT_COLUMN);
xcol_opt->key = "x";
@@ -81,7 +83,7 @@
keycol_opt = G_define_standard_option(G_OPT_COLUMN);
keycol_opt->key = "key";
keycol_opt->required = YES;
- keycol_opt->description = _("Name of column containing category number");
+ keycol_opt->label = _("Name of column containing category number");
keycol_opt->description = _("Must refer to an integer column");
where_opt = G_define_standard_option(G_OPT_WHERE);
@@ -111,9 +113,8 @@
fi = Vect_default_field_info(&Map, 1, NULL, GV_1TABLE);
/* Open driver */
- driver =
- db_start_driver_open_database(driver_opt->answer,
- database_opt->answer);
+ driver = db_start_driver_open_database(driver_opt->answer,
+ database_opt->answer);
if (driver == NULL) {
G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
fi->database, fi->driver);
@@ -164,9 +165,14 @@
table = db_get_cursor_table(&cursor);
+ nrows = db_get_num_rows(&cursor);
+ G_debug(2, "%d points selected", nrows);
count = 0;
+ G_message(_("Writing features..."));
while (db_fetch(&cursor, DB_NEXT, &more) == DB_OK && more) {
+ G_percent(count, nrows, 2);
/* key column */
column = db_get_table_column(table, 0);
ctype = db_sqltype_to_Ctype(db_get_column_sqltype(column));
@@ -186,8 +192,7 @@
else
coor[i] = db_get_value_double(value);
Vect_reset_line(Points);
Vect_reset_cats(Cats);
@@ -199,11 +204,12 @@
count++;
+ G_percent(1, 1, 1);
- G_message(_("%d points written to vector map"), count);
db_close_database_shutdown_driver(driver);
/* Copy table */
+ G_message(_("Copying attributes..."));
if (where_opt->answer)
ret =
db_copy_table_where(driver_opt->answer, database_opt->answer,
@@ -226,7 +232,7 @@
Vect_build(&Map);
Vect_close(&Map);
- G_done_msg(" ");
+ G_done_msg(_("%d points written to vector map."), count);
return (EXIT_SUCCESS);
