[GRASS-SVN] r35344 - grass/branches/develbranch_6/gui/wxpython/docs
svn_grass at osgeo.org
Sun Jan 11 18:44:10 EST 2009
Author: martinl
Date: 2009-01-11 18:44:10 -0500 (Sun, 11 Jan 2009)
New Revision: 35344
grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html
wxGUI manual page updated (new icons)
(merge from trunk, r35343)
Modified: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html
--- grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html 2009-01-11 23:42:17 UTC (rev 35343)
+++ grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html 2009-01-11 23:44:10 UTC (rev 35344)
@@ -86,64 +86,76 @@
<dl>
-<dt><img src="icons/silk/application_add.png">
- <img src="icons/grass/gui-startmon.gif"> Open new Map Display Window</dt>
+<dt><img src="icons/grass2/monitor-create.png">
+ <img src="icons/grass/gui-startmon.gif">
+ <img src="icons/silk/application_add.png"> <em>Open new Map Display Window</em></dt>
<dd>Opens a new map display and creates empty layer tree tab in Layer Manager.</dd>
-<dt><img src="icons/silk/page_white.png">
- <img src="icons/grass/file-new.gif">Creates new workspace file</dt>
+<dt><img src="icons/grass2/create.png">
+ <img src="icons/grass/file-new.gif">
+ <img src="icons/silk/page_white.png"> <em>Creates new workspace file</em></dt>
<dd>Removes all layers in the layer tree and creates a new, empty tree
where new layers can be added.</dd>
-<dt><img src="icons/silk/page_white_get.png">
- <img src="icons/grass/file-new.gif">Load map layers (raster, vector) into workspace</dt>
+<dt><img src="icons/grass2/layer-open.png">
+ <img src="icons/silk/page_white_get.png"> <em>Load map layers (raster, vector) into workspace</em></dt>
<dd>Loads selected raster or vector maps into current layer tree.</dd>
-<dt><img src="icons/silk/folder.png">
- <img src="icons/grass/file-open.gif">Open an existing workspace file</dt>
+<dt><img src="icons/grass2/open.png">
+ <img src="icons/grass/file-open.gif">
+ <img src="icons/silk/folder.png"> <em>Open an existing workspace file</em></dt>
<dd>Opens an previously saved workspace file, containing a set of display
layers and their option settings.</dd>
-<dt><img src="icons/silk/page_save.png">
- <img src="icons/grass/file-save.gif"> Save layers composition to workspace
- file</dt>
+<dt><img src="icons/grass2/save.png">
+ <img src="icons/grass/file-save.gif">
+ <img src="icons/silk/page_save.png"> <em>Save layers composition to workspace
+ file</em></dt>
<dd>Saves current set of layers and their options to a workspace
file.</dd>
-<dt><img src="icons/silk/image_add.png">
- <img src="icons/grass/element-cell.gif"> Add raster-based map layer</dt>
+<dt><img src="icons/grass2/layer-raster-add.png">
+ <img src="icons/grass/element-cell.gif">
+ <img src="icons/silk/image_add.png"> <em>Add raster-based map layer</em></dt>
<dd>Adds raster map to layer tree, see <em><a href="d.rast.html">d.rast</a></em>. Includes also shaded relief map, RGB or HIS map or raster flow arrows map.</dd>
-<dt><img src="icons/silk/picture_empty.png">
- <img src="icons/grass/module-d.shadedmap.gif"> Add shaded relief map layer</dt>
+<dt><img src="icons/grass2/layer-shaded-relief-add.png">
+ <img src="icons/grass/module-d.shadedmap.gif">
+ <img src="icons/silk/picture_empty.png"> <em>Add shaded relief map layer</em></dt>
<dd>Adds shaded relief raster map layer,
see <em><a href="d.shadedmap.html">d.shadedmap</a></em>.</dd>
-<dt><img src="icons/silk/rgb.png">
- <img src="icons/grass/channel-rgb.gif"> Add RGB raster layer</dt>
+<dt><img src="icons/grass2/layer-rgb-add.png">
+ <img src="icons/grass/channel-rgb.gif">
+ <img src="icons/silk/rgb.png"> <em>Add RGB raster layer</em></dt>
<dd>Combines and displays three raster maps defined as red, green, and blue
channels, see <em><a href="d.rgb.html">d.rgb</a></em>.</dd>
-<dt><img src="icons/silk/his.png">
- <img src="icons/grass/channel-his.gif"> Add HIS raster layer</dt>
+<dt><img src="icons/grass2/layer-his-add.png">
+ <img src="icons/grass/channel-his.gif">
+ <img src="icons/silk/his.png"> <em>Add HIS raster layer</em></dt>
<dd>Combines and displays two or three raster maps defined as hue,
intensity, and (optionally) saturation channels,
see <em><a href="d.his.html">d.his</a></em>.</dd>
-<dt><img src="icons/silk/arrow_out.png">
- <img src="icons/grass/module-d.rast.arrow.gif"> Add raster arrows layer</dt>
+<dt><img src="icons/grass2/layer-cell-cats-add.png">
+ <img src="icons/grass/module-d.rast.arrow.gif">
+ <img src="icons/silk/arrow_out.png"> <em>Add raster arrows layer</em></dt>
<dd>Adds map of raster cells with directional arrows drawn. Arrow
direction and length are determined by separate aspect/directional map
and (optional) slope/intensity map,
see <em><a href="d.rast.arrow.html">d.rast.arrow</a></em>.</dd>
-<dt><img src="icons/silk/map_add.png">
- <img src="icons/grass/element-vector.gif"> Add vector-based map layer</dt>
+<dt><img src="icons/grass2/layer-vector-add.png">
+ <img src="icons/grass/element-vector.gif">
+ <img src="icons/silk/map_add.png"> <em>Add vector-based map layer</em></dt>
<dd>Adds a vector map layer, see <em><a href="d.vect.html">d.vect</a></em>. Includes also thematic vector map or thematic charts layer.</dd>
-<dt><img src="icons/silk/thematic.png">
- <img src="icons/grass/module-d.vect.thematic.gif"> Add thematic map layer
- (for all vector types)</dt>
+<dt><img src="icons/grass2/layer-vector-thematic-add.png">
+ <img src="icons/grass/module-d.vect.thematic.gif">
+ <img src="icons/silk/thematic.png"> <em>Add thematic map layer
+ (for all vector types)</em></dt>
<dd>Adds layer for thematic display values from a numeric attribute
column associated with a vector map. Options include: thematic display
type (graduated colors or point sizes), methods for creating display
@@ -154,9 +166,10 @@
printing,
see <em><a href="d.vect.thematic.html">d.vect.thematic</a></em>.</dd>
-<dt><img src="icons/silk/chart_bar.png">
- <img src="icons/grass/module-d.vect.chart.gif"> Add thematic charts layer
-(for vector points)</dt>
+<dt><img src="icons/grass2/layer-vector-chart-add.png">
+ <img src="icons/grass/module-d.vect.chart.gif">
+ <img src="icons/silk/chart_bar.png"> <em>Add thematic charts layer
+(for vector points)</em></dt>
<dd>Adds layer in which pie or bar charts can be automatically created
at vector point locations. Charts display values from selected columns
in the associated attribute table. Options include: chart type, layer
@@ -164,8 +177,9 @@
on attribute column),
see <em><a href="d.vect.chart.html">d.vect.chart</a></em>.</dd>
-<dt><img src="icons/silk/cog_add.png">
- <img src="icons/grass/gui-cmd.gif"> Add command layer</dt>
+<dt><img src="icons/grass2/layer-command-add.png">
+ <img src="icons/grass/gui-cmd.gif">
+ <img src="icons/silk/cog_add.png"> <em>Add command layer</em></dt>
<dd>Adds a layer in which a GRASS GIS command or command list can be entered.
For a command list use the pipe symbol as ";" as separator.
For example:
@@ -181,30 +195,35 @@
</pre></div>
</dd>
-<dt><img src="icons/silk/folder_add.png">
- <img src="icons/grass/gui-group.gif"> Add layer group</dt>
+<dt><img src="icons/grass2/layer-group-add.png">
+ <img src="icons/grass/gui-group.gif">
+ <img src="icons/silk/folder_add.png"> <em>Add layer group</em></dt>
<dd>Adds an empty layer group. Layers can then be added to the group.</dd>
-<dt><img src="icons/silk/images.png">
- <img src="icons/grass/module-d.grid.gif"> Add overlay grids and lines</dt>
+<dt><img src="icons/grass2/layer-grid-add.png">
+ <img src="icons/grass/module-d.grid.gif">
+ <img src="icons/silk/images.png"> <em>Add overlay grids and lines</em></dt>
<dd>Adds layer to display regular grid (for all locations), or geodesic and
rhumblines (for latitude/longitude locations only), see <em><a href="d.grid.html">d.grid</a>, <a href="d.geodesic.html">d.geodesic</a>, <a href="d.rhumbline.html">d.rhumbline</a></em>.</dd>
-<dt><img src="icons/silk/tag_blue_add.png">
- <img src="icons/grass/module-d.labels.gif"> Add labels layer for vector
-objects (from existing labels file)</dt>
+<dt><img src="icons/grass2/layer-label-add.png">
+ <img src="icons/grass/module-d.labels.gif">
+ <img src="icons/silk/tag_blue_add.png"> <em>Add labels layer for vector
+objects (from existing labels file)</em></dt>
<dd>Add raster text layer from a labels file for vector objects
created with the <em><a href="v.label.html">v.label</a></em> module
(accessed from button in options panel). A labels file can also be
created with a text editor,
see <em><a href="d.labels.html">d.labels</a></em>.</dd>
-<dt><img src="icons/silk/bin_closed.png">
- <img src="icons/grass/edit-cut.gif"> Remove layer for layer tree</dt>
-<dd>Removes selected layer or layer group from layer tree.</dd>
+<dt><img src="icons/grass2/layer-remove.png">
+ <img src="icons/grass/edit-cut.gif">
+ <img src="icons/silk/bin_closed.png"> <em>Remove map layer from layer tree</em></dt>
+<dd>Removes selected map layer or map layer group from layer tree.</dd>
-<dt><img src="icons/silk/application_view_columns.png">
- <img src="icons/grass/db-values.gif"> Open <a href="wxGUI.Attribute_Table_Manager.html">Attribute Table Manager</a> for selected vector map</dt>
+<dt><img src="icons/grass2/table.png">
+ <img src="icons/grass/db-values.gif">
+ <img src="icons/silk/application_view_columns.png"> <em>Open <a href="wxGUI.Attribute_Table_Manager.html">Attribute Table Manager</a> for selected vector map</em></dt>
<dd>Displays attribute data of selected vector map.</dd>
</dl>
@@ -241,30 +260,35 @@
<dl>
-<dt><img src="icons/silk/map_go.png">
- <img src="icons/grass/gui-display.gif"> Display active layers (current region)</dt>
+<dt><img src="icons/grass2/show.png">
+ <img src="icons/grass/gui-display.gif">
+ <img src="icons/silk/map_go.png"> <em>Display active layers (current region)</em></dt>
<dd>Displays all active layers from layer tree at current resolution
and region extents for that map display window.</dd>
-<dt><img src="icons/silk/arrow_refresh.png">
- <img src="icons/grass/gui-redraw.gif"> Re-render and display all active
-layers and zoom to current region</dt>
+<dt><img src="icons/grass2/layer-redraw.png">
+ <img src="icons/grass/gui-redraw.gif">
+ <img src="icons/silk/arrow_refresh.png"> <em>Re-render and display all active
+layers and zoom to current region</em></dt>
<dd>Resets the region to the display resolution and extents and forces
re-display and re-rendering all active layers.</dd>
-<dt><img src="icons/silk/cross.png">
- <img src="icons/grass/gui-erase.gif"> Erase display content</dt>
+<dt><img src="icons/grass2/erase.png">
+ <img src="icons/grass/gui-erase.gif">
+ <img src="icons/silk/cross.png"> <em>Erase display content</em></dt>
<dd>Erases the currently selected map display to a white background;
also removes all frames,
see <em><a href="d.erase.html">d.erase</a>, <a href="d.frame.html">d.frame
-e</a></em>.</dd>
-<dt><img src="icons/silk/cursor.png">
- <img src="icons/grass/gui-pointer.gif"> Arrow cursor</dt>
+<dt><img src="icons/grass2/pointer.png">
+ <img src="icons/grass/gui-pointer.gif">
+ <img src="icons/silk/cursor.png"> <em>Arrow cursor</em></dt>
<dd>Select arrow cursor for map display.</dd>
-<dt><img src="icons/silk/information.png">
- <img src="icons/grass/gui-query.gif"> Query tool (select a map first)</dt>
+<dt><img src="icons/grass2/info.png">
+ <img src="icons/grass/gui-query.gif">
+ <img src="icons/silk/information.png"> <em>Query tool (select a map first)</em></dt>
<dd>Query selected raster, RGB raster (all three map channels will be
queried), or vector map(s) using the mouse. Map(s) must be selected
before query. Vector charts and thematic vector maps cannot be
@@ -272,8 +296,9 @@
window,
see <em><a href="r.what.html">r.what</a>, <a href="v.what.html">v.what</a></em>.</dd>
- <img src="icons/grass/gui-pan.gif"> Pan</dt>
+<dt><img src="icons/grass2/pan.png">
+ <img src="icons/grass/gui-pan.gif">
+ <img src="icons/silk/arrow_out.png"> <em>Pan</em></dt>
<dd>Interactive selection of a new center of view in the active
display monitor. Drag the pan cursor while pressing the left mouse
button to pan. Panning changes the location of the region displayed
@@ -281,8 +306,9 @@
does <em>not</em> affect the computational region for other GIS
processes, see <em><a href="g.region.html">g.region</a></em>.</dd>
-<dt><img src="icons/silk/zoom_in.png">
- <img src="icons/grass/gui-zoom_in.gif"> Zoom in</dt>
+<dt><img src="icons/grass2/zoom-in.png">
+ <img src="icons/grass/gui-zoom_in.gif">
+ <img src="icons/silk/zoom_in.png"> <em>Zoom in</em></dt>
<dd>Interactive zooming with the mouse in the active display monitor.
Drawing a box or just click with the mouse (left button) and zoom-in
cursor causes the display to zoom in so that the area defined by the
@@ -293,8 +319,9 @@
-<dt><img src="icons/silk/zoom_out.png">
- <img src="icons/grass/gui-zoom_out.gif"> Zoom out</dt>
+<dt><img src="icons/grass2/zoom-out.png">
+ <img src="icons/grass/gui-zoom_out.gif">
+ <img src="icons/silk/zoom_out.png"> <em>Zoom out</em></dt>
Drawing a box or just click with the mouse (left button) and zoom-out
cursor causes the display to zoom in so that the area displayed
@@ -306,13 +333,15 @@
other GIS processes,
-<dt><img src="icons/silk/zoom_back.png">
- <img src="icons/grass/gui-zoom_back.gif"> Revert zoom</dt>
+<dt><img src="icons/grass2/zoom-last.png">
+ <img src="icons/grass/gui-zoom_back.gif">
+ <img src="icons/silk/zoom_back.png"> </em>Revert zoom</em></dt>
<dd>Returns to the previous zoom. Up to 10 levels of zoom back are
maintained, see <em><a href="g.region.html">g.region</a></em>.</dd>
-<dt><img src="icons/silk/zoom.png">
- <img src="icons/grass/gui-mapzoom.gif"> Zoom menu</dt>
+<dt><img src="icons/grass2/zoom-more.png">
+ <img src="icons/grass/gui-mapzoom.gif">
+ <img src="icons/silk/zoom.png"> <em>Zoom menu</em></dt>
<dd>Automatic zoom settings menu. Zoom to match the extents of a selected
map, zoom to match the computational region (set with
<em>g.region</em>), zoom to match the extents of a saved region or
@@ -321,61 +350,71 @@
current display extents (does not change the resolution).
See <em><a href="g.region.html">g.region</a></em>.</dd>
-<dt><img src="icons/silk/application_lightning.png">
- <img src="icons/grass/gui-rastanalyze.gif"> Analyze menu</dt>
+<dt><img src="icons/grass2/layer-raster-analyze.png">
+ <img src="icons/grass/gui-rastanalyze.gif">
+ <img src="icons/silk/application_lightning.png"> <em>Analyze menu</em></dt>
<dd>Contains functions for distance measurement, creating histogram or
profile tool.</dd>
-<dt><img src="icons/silk/sum.png">
- <img src="icons/grass/gui-measure.gif"> Distance measurement tool</dt>
+<dt><img src="icons/grass2/measure-length.png">
+ <img src="icons/grass/gui-measure.gif">
+ <img src="icons/silk/sum.png"> <em>Distance measurement tool</em></dt>
<dd>Interactive measurement of lengths defined with the mouse. The
length of each segment and the cumulative length of all segments
measuered is displayed in the command output window frame. Lengths are
measured in the current measurement unit,
see <em><a href="d.measure.html">d.measure</a></em>.</dd>
-<dt><img src="icons/silk/wand.png">
- <img src="icons/grass/gui-profile.gif"> Profile tool</dt>
+<dt><img src="icons/grass2/layer-raster-profile.png">
+ <img src="icons/grass/gui-profile.gif">
+ <img src="icons/silk/wand.png"> <em>Profile tool</em></dt>
<dd>Interactively create profile of a raster map. Profile transect is
drawn with the mouse in map display. The profile may be of the
displayed map or a different map,
see <em><a href="gm_profile.html">Profile Tool help
page</a></em>.</dd>
+<dt><img src="icons/grass2/layer-raster-histogram.png">
<img src="icons/grass/module-d.histogram.gif"> Display histogram of selected raster map</td>
<dd>Displays histogram of selected raster map or image in new window,
see <em><a href="d.histogram.html">d.histogram</a</em>.</dd>
-<dt><img src="icons/silk/overlays.png">
+<dt><img src="icons/grass2/element-add.png">
+ <img src="icons/silk/overlays.png">
<img src="icons/grass/gui-rastanalyze.gif"> Add overlay</dt>
<dd>Adds overlay to map display like barscale, north arrow, text.</dd>
-<dt><img src="icons/silk/page_white_picture.png">
- <img src="icons/grass/module-d.barscale.gif"> Add scalebar and north arrow</dt>
+<dt><img src="icons/grass2/scalebar-add.png">
+ <img src="icons/grass/module-d.barscale.gif">
+ <img src="icons/silk/page_white_picture.png"> <em>Add scalebar and north arrow</em></dt>
<dd>Adds layer to display a combined scalebar and north arrow. Options
include scalebar placement (using screen coordinates or a mouse),
scalebar format, and scalebar colors,
see <em><a href="d.barscale.html">d.barscale</a></em>.</dd>
-<dt><img src="icons/silk/page_green.png">
- <img src="icons/grass/module-d.legend.gif"> Add legend of raster map</dt>
+<dt><img src="icons/grass2/legend-add.png">
+ <img src="icons/grass/module-d.legend.gif">
+ <img src="icons/silk/page_green.png"> <em>Add legend of raster map</em></dt>
<dd>Adds layer to display with legend of selected raster map,
see <a href="d.legend.html">d.legend</a></em>.</dd>
-<dt><img src="icons/silk/textfield_add.png">
- <img src="icons/grass/module-d.text.gif"> Add text layer</dt>
+<dt><img src="icons/grass2/text-add.png">
+ <img src="icons/grass/module-d.text.gif">
+ <img src="icons/silk/textfield_add.png"> <em>Add text layer</em></dt>
<dd>Adds layer to display a line of text using default GRASS font
(selected with <em><a href="d.font.html">d.font</a></em>). Options
include: text placement (screen coordinates); and text size, bolding,
and color, see <em><a href="d.text.html">d.text</a></em>.</dd>
-<dt><img src="icons/silk/picture_save.png">
- <img src="icons/grass/file-save.gif"> Export map display</dt>
+<dt><img src="icons/grass2/map-export.png">
+ <img src="icons/silk/picture_save.png"> <em>Export map display</em></dt>
<dd>Exports visible map display to different raster graphic formats.</dd>
-<dt><img src="icons/silk/printer.png">
- <img src="icons/grass/file-print.gif"> Print map</dt>
+<dt><img src="icons/grass2/print.png">
+ <img src="icons/grass/file-print.gif">
+ <img src="icons/silk/printer.png"> <em>Print map</em></dt>
<dd>Prints map on the UNIX <i>lpr</i> printer or PostScript device;
saves visible map display (including PostScript text and labels) to PDF
or EPS file. Requires <tt>ghostscript</tt> for all output except EPS.</dd>
@@ -389,13 +428,14 @@
<h3>Icon Theme</h3>
-Currently are supported two icon theme sets:
+Currently are supported three icon theme sets:
<ul>
- <li>original <em>GRASS theme</em></li>
- <li><em>Silk theme</em> based
+ <li><em>new</em> <a href="http://www.szczepanek.pl/icons.grass/v.0.1/">GRASS theme</a> v0.1 (<tt>grass2</tt>)</li>
+ <li><em>original TCL/TK-based</em> GRASS theme (<tt>grass</tt>)</li>
+ <li><em>Silk theme</em>-based
on <a href="http://www.famfamfam.com/lab/icons/silk/">Silk icon
- set</a>, v1.3</li>
+ set</a>, v1.3 (<tt>silk</tt>)</li>
</ul>
<h2>SEE ALSO</h2>
