[GRASS-SVN] r35367 - grass/branches/releasebranch_6_4/raster/r.cost
Mon Jan 12 10:49:38 EST 2009
Author: martinl
Date: 2009-01-12 10:49:38 -0500 (Mon, 12 Jan 2009)
New Revision: 35367
   grass/branches/releasebranch_6_4/raster/r.cost/btree.c
   grass/branches/releasebranch_6_4/raster/r.cost/main.c
r.cost: message cosmetics
Modified: grass/branches/releasebranch_6_4/raster/r.cost/btree.c
--- grass/branches/releasebranch_6_4/raster/r.cost/btree.c	2009-01-12 15:03:53 UTC (rev 35366)
+++ grass/branches/releasebranch_6_4/raster/r.cost/btree.c	2009-01-12 15:49:38 UTC (rev 35367)
@@ -13,7 +13,7 @@
  *               input raster map layer whose cell category values
  *               represent cost.
- * COPYRIGHT:    (C) 2006 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2006-2009 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -55,7 +55,8 @@
     /*      new_cell = (struct cost *)(G_malloc(sizeof(struct cost))); */
     new_cell = get();
     if (new_cell == NULL) {
-	G_message(_("new_cell is NULL"));
+	G_message(_("NULL value computed (row %d, col %d)"),
+		  row, col);
     new_cell->min_cost = min_cost;
     new_cell->row = row;
@@ -124,25 +125,26 @@
 		next_cell = next_cell->lower;
 		continue;
-	    G_message("1 ");
+	    G_debug(2, "1 ");
 	    return NULL;
-	    do_quit(min_cost, row, col);
+	    do_quit(min_cost, row, col); /* ??? */
 	else {
 	    if (next_cell->higher != NULL) {
 		next_cell = next_cell->higher;
 		continue;
-	    G_message("2 ");
+	    G_debug(2, "2 ");
 	    return NULL;
 static int do_quit(double min_cost, int row, int col)
-    G_warning(_("Can't find %d,%d:%f"), row, col, min_cost);
+    G_warning(_("Unable to find row %d, col %d: %f"),
+	      row, col, min_cost);
     show_all();
     exit(EXIT_FAILURE);
@@ -367,7 +369,7 @@
 int show_all(void)
     if (start_cell == NULL) {
-	G_warning(_("Nothing to show"));
+	G_debug(1, "Nothing to show");
 	return 1;
     show(start_cell);
@@ -382,13 +384,13 @@
     if (next == NULL)
 	return 0;
     for (next_cell = next; next_cell != NULL; next_cell = next_cell->nexttie)
-	fprintf(stderr, "%p %d,%d,%f %p %p %p %p\n",
-		next_cell,
-		next_cell->row,
-		next_cell->col,
-		next_cell->min_cost,
-		next_cell->nexttie,
-		next_cell->lower, next_cell->higher, next_cell->above);
+	G_message("%p %d,%d,%f %p %p %p %p",
+		  next_cell,
+		  next_cell->row,
+		  next_cell->col,
+		  next_cell->min_cost,
+		  next_cell->nexttie,
+		  next_cell->lower, next_cell->higher, next_cell->above);
     show(next->lower);
     show(next->higher);
@@ -398,7 +400,7 @@
 int check_all(char *str)
     if (start_cell->above != NULL) {
-	G_fatal_error(_("Bad Start Cell"));
+	G_fatal_error(_("Bad start cell"));
     check(str, start_cell);
Modified: grass/branches/releasebranch_6_4/raster/r.cost/main.c
--- grass/branches/releasebranch_6_4/raster/r.cost/main.c	2009-01-12 15:03:53 UTC (rev 35366)
+++ grass/branches/releasebranch_6_4/raster/r.cost/main.c	2009-01-12 15:49:38 UTC (rev 35367)
@@ -13,7 +13,7 @@
  *               represent cost.
+ * COPYRIGHT:    (C) 2006-2008 by the GRASS Development Team
@@ -123,10 +123,10 @@
     module = G_define_module();
     module->keywords = _("raster, cost surface, cumulative costs");
     module->description =
-	_("Outputs a raster map layer showing the "
+	_("Creates a raster map showing the "
 	  "cumulative cost of moving between different "
 	  "geographic locations on an input raster map "
-	  "layer whose cell category values represent cost.");
+	  "whose cell category values represent cost.");
     opt2 = G_define_standard_option(G_OPT_R_INPUT);
     opt2->description =
@@ -134,26 +134,23 @@
     opt1 = G_define_standard_option(G_OPT_R_OUTPUT);
-    opt7 = G_define_option();
+    opt7 = G_define_standard_option(G_OPT_V_INPUT);
     opt7->key = "start_points";
-    opt7->type = TYPE_STRING;
-    opt7->gisprompt = "old,vector,vector";
     opt7->required = NO;
-    opt7->description = _("Starting points vector map");
+    opt7->description = _("Name of starting vector points map");
+    opt7->guisection = _("Start");
-    opt8 = G_define_option();
+    opt8 = G_define_standard_option(G_OPT_V_INPUT);
     opt8->key = "stop_points";
-    opt8->type = TYPE_STRING;
-    opt8->gisprompt = "old,vector,vector";
     opt8->required = NO;
-    opt8->description = _("Stop points vector map");
+    opt8->description = _("Name of stop vector points map");
+    opt8->guisection = _("Stop");
-    opt9 = G_define_option();
+    opt9 = G_define_standard_option(G_OPT_R_INPUT);
     opt9->key = "start_rast";
-    opt9->type = TYPE_STRING;
-    opt9->gisprompt = "old,cell,raster";
     opt9->required = NO;
-    opt9->description = _("Starting points raster map");
+    opt9->description = _("Name of starting raster points map");
+    opt9->guisection = _("Start");
     opt3 = G_define_option();
     opt3->key = "coordinate";
@@ -161,7 +158,8 @@
     opt3->key_desc = "x,y";
     opt3->multiple = YES;
     opt3->description =
-	_("The map E and N grid coordinates of a starting point (E,N)");
+	_("Map grid coordinates of a starting point (E,N)");
+    opt3->guisection = _("Start");
     opt4 = G_define_option();
     opt4->key = "stop_coordinate";
@@ -169,7 +167,8 @@
     opt4->key_desc = "x,y";
     opt4->multiple = YES;
     opt4->description =
-	_("The map E and N grid coordinates of a stopping point (E,N)");
+	_("Map grid coordinates of a stopping point (E,N)");
+    opt4->guisection = _("Stop");
     opt5 = G_define_option();
     opt5->key = "max_cost";
@@ -178,7 +177,7 @@
     opt5->required = NO;
     opt5->multiple = NO;
     opt5->answer = "0";
-    opt5->description = _("An optional maximum cumulative cost");
+    opt5->description = _("Optional maximum cumulative cost");
     opt6 = G_define_option();
     opt6->key = "null_cost";
@@ -205,11 +204,12 @@
     flag3 = G_define_flag();
     flag3->key = 'n';
-    flag3->description = _("Keep null values in output map");
+    flag3->description = _("Keep null values in output raster map");
     flag4 = G_define_flag();
     flag4->key = 'r';
     flag4->description = _("Start with values in raster map");
+    flag4->guisection = _("Start");
     /* please, remove before GRASS 7 released */
     v_flag = G_define_flag();
@@ -289,11 +289,11 @@
     if ((opt6->answer == NULL) ||
 	(sscanf(opt6->answer, "%lf", &null_cost) != 1)) {
-	G_message(_("Null cells excluded from cost evaluation."));
+	G_debug(1, "Null cells excluded from cost evaluation");
 	G_set_d_null_value(&null_cost, 1);
     else if (keep_nulls)
-	G_message(_("Input null cell will be retained into output map"));
+	G_debug(1, "Null cell will be retained into output raster map");
     if (opt7->answer) {
 	search_mapset = G_find_vector(opt7->answer, "");
@@ -303,7 +303,7 @@
     if (!G_is_d_null_value(&null_cost)) {
 	if (null_cost < 0.0) {
-	    G_warning(_("Warning: assigning negative cost to null cell. Null cells excluded."));
+	    G_warning(_("Assigning negative cost to null cell. Null cells excluded."));
@@ -346,16 +346,16 @@
     switch (data_type) {
     case (CELL_TYPE):
-	G_message(_("Source map is: Integer cell type"));
+	G_debug(1, "Source map is: Integer cell type");
 	break;
     case (FCELL_TYPE):
-	G_message(_("Source map is: Floating point (float) cell type"));
+	G_debug(1, "Source map is: Floating point (float) cell type");
 	break;
     case (DCELL_TYPE):
-	G_message(_("Source map is: Floating point (double) cell type"));
+	G_debug(1, "Source map is: Floating point (double) cell type");
 	break;
-    G_message(_(" %d rows, %d cols"), nrows, ncols);
+    G_debug(1, "  %d rows, %d cols", nrows, ncols);
     srows = scols = SEGCOLSIZE;
     if (maxmem > 0)
@@ -369,7 +369,7 @@
     /*   Create segmented format files for cost layer and output layer  */
-    G_message(_("Creating some temporary files..."));
+    G_verbose_message(_("Creating some temporary files..."));
     in_fd = creat(in_file, 0666);
     segment_format(in_fd, nrows, ncols, srows, scols, sizeof(double));
@@ -390,8 +390,8 @@
     /*   Write the cost layer in the segmented file  */
-    G_message(_("Reading %s"), cost_layer);
+    G_message(_("Reading raster map <%s>..."),
+	      G_fully_qualified_name(cost_layer, cost_mapset));
 	int i;
 	double p;
@@ -447,24 +447,21 @@
 		break;
+	G_percent(1, 1, 1);
     segment_flush(&in_seg);
-    G_percent(row, nrows, 2);
     /* Initialize output map with NULL VALUES */
     /*   Initialize segmented output file  */
-    G_message(_("Initializing output "));
+    G_message(_("Initializing output..."));
 	double *fbuff;
 	int i;
 	fbuff = (double *)G_malloc(ncols * sizeof(double));
-	if (fbuff == NULL)
-	    G_fatal_error(_("Unable to allocate memory for segment fbuff == NULL"));
 	G_set_d_null_value(fbuff, ncols);
 	for (row = 0; row < nrows; row++) {
@@ -474,8 +471,8 @@
 		segment_put(&out_seg, &fbuff[i], row, i);
 	segment_flush(&out_seg);
 	G_free(fbuff);
@@ -496,7 +493,7 @@
 	fp = G_fopen_sites_old(opt7->answer, search_mapset);
 	if (G_site_describe(fp, &dims, &cat, &strs, &dbls))
-	    G_fatal_error("Failed to guess site file format\n");
+	    G_fatal_error(_("Failed to guess site file format"));
 	site = G_site_new_struct(cat, dims, strs, dbls);
 	for (; (G_site_get(fp, site) != EOF);) {
@@ -546,7 +543,7 @@
 	fp = G_fopen_sites_old(opt8->answer, search_mapset);
+	    G_fatal_error(_("Failed to guess site file format\n"));
@@ -590,7 +587,7 @@
 	fd = G_open_cell_old(opt9->answer, search_mapset);
 	if (fd < 0)
-	    G_fatal_error(_("can't open raster map [%s] needed for input coordinates"),
+	    G_fatal_error(_("Unable to open raster map <%s>"),
 			  opt9->answer);
 	data_type2 = G_get_raster_map_type(fd);
@@ -602,7 +599,7 @@
 	if (!cell2)
 	    G_fatal_error(_("Unable to allocate memory"));
-	G_message(_("Reading %s"), opt9->answer);
+	G_message(_("Reading raster map <%s>..."), opt9->answer);
 	    if (G_get_raster_row(fd, cell2, row, data_type2) < 0)
@@ -629,7 +626,7 @@
 		ptr2 = G_incr_void_ptr(ptr2, dsize2);
+	G_percent(1, 1, 2);
 	G_close_cell(fd);
 	G_free(cell2);
@@ -666,7 +663,7 @@
      *   3) Free the memory allocated to the present cell.
-    G_message(_("Finding cost path"));
+    G_message(_("Finding cost path..."));
     n_processed = 0;
     total_cells = nrows * ncols;
     at_percent = 0;
@@ -891,7 +888,7 @@
 	pres_cell = get_lowest();
 	if (pres_cell == NULL) {
-	    G_message(_("End of map!"));
+	    G_message(_("No data"));
 	    goto OUT;
 	if (ct == pres_cell)
@@ -907,10 +904,9 @@
     /*  Copy segmented map to output map  */
-    G_message(_("Writing %s"), cum_cost_layer);
+    G_message(_("Writing raster map <%s>..."), cum_cost_layer);
     if (keep_nulls) {
-	G_message(_("Will copy input map null values into output map"));
 	cell2 = G_allocate_raster_buf(data_type);
@@ -918,12 +914,12 @@
 	int *p;
 	int *p2;
-	G_message(_("Integer cell type.\nWriting..."));
 	    if (keep_nulls) {
 		if (G_get_raster_row(cost_fd, cell2, row, data_type) < 0)
-		    G_fatal_error(_("Error getting input null cells"));
+		    G_fatal_error(_("Unable to read raster map <%s> row %d"),
+				  cost_layer, row);
 	    p = cell;
 	    p2 = cell2;
@@ -951,12 +947,12 @@
 	float *p;
 	float *p2;
-	G_message(_("Float cell type.\nWriting..."));
 	    if (keep_nulls) {
+				  cost_layer, row);
 	    p = cell;
 	    p2 = cell2;
@@ -984,12 +980,12 @@
 	double *p;
 	double *p2;
-	G_message(_("Double cell type.\nWriting..."));
 	    if (keep_nulls) {
+				  cost_layer, row);
 	    p = cell;
 	    p2 = cell2;
@@ -1013,11 +1009,8 @@
 	    G_put_raster_row(cum_fd, cell, data_type);
-    G_message(_("Peak cost value: %f"), peak);
     segment_release(&in_seg);	/* release memory  */
     segment_release(&out_seg);
     G_close_cell(cost_fd);
@@ -1039,6 +1032,9 @@
      * G_make_color_wave(&colors,min, max);
      * G_write_colors (cum_cost_layer,current_mapset,&colors);
+    G_done_msg(_("Peak cost value: %f."), peak);
     exit(EXIT_SUCCESS);
