[GRASS-SVN] r35371 - grass/branches/develbranch_6/raster/r.drain
svn_grass at osgeo.org
Mon Jan 12 11:37:18 EST 2009
Author: martinl
Date: 2009-01-12 11:37:18 -0500 (Mon, 12 Jan 2009)
New Revision: 35371
grass/branches/develbranch_6/raster/r.drain/main.c
r.drain: standard header, be more verbose
(merge from relbr64, r35370)
Modified: grass/branches/develbranch_6/raster/r.drain/main.c
--- grass/branches/develbranch_6/raster/r.drain/main.c 2009-01-12 16:23:58 UTC (rev 35370)
+++ grass/branches/develbranch_6/raster/r.drain/main.c 2009-01-12 16:37:18 UTC (rev 35371)
@@ -1,36 +1,27 @@
-* COPYRIGHT: (C) 2000 by the GRASS Development Team
-* This program is free software under the GNU General Public
-* License (>=v2). Read the file COPYING that comes with GRASS
-* for details.
+ * MODULE: r.drain
+ * AUTHOR(S): Kewan Q. Khawaja <kewan techlogix.com>
+ * Update to FP (2000): Pierre de Mouveaux <pmx at audiovu.com> <pmx at free.fr>
+ * bugfix in FCELL, DCELL: Markus Neteler 12/2000
+ * Rewritten by Roger Miller 7/2001 based on subroutines from
+ * r.fill.dir and on the original r.drain.
+ * 24 July 2004: WebValley 2004, error checking and vector points added by
+ * Matteo Franchi Liceo Leonardo Da Vinci Trento
+ * Roberto Flor ITC-irst
+ * PURPOSE: This is the main program for tracing out the path that a
+ * drop of water would take if released at a certain location
+ * on an input elevation map.
+ * COPYRIGHT: (C) 2000,2009 by the GRASS Development Team
+ * This program is free software under the GNU General Public
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
-/* This is the original attribution from r.drain */
-* This is the main program for tracing out the path that a *
-* drop of water would take if released at a certain location *
-* on an input elevation map. The program was written by *
-* Kewan Q. Khawaja *
-* kewan at techlogix.com *
-* update to FP (2000): Pierre de Mouveaux <pmx at audiovu.com><pmx at free.fr>*
-* bugfix in FCELL, DCELL: Markus Neteler 12/2000 *
-* Rewritten by Roger Miller 7/2001 based on subroutines from *
-* r.fill.dir and on the original r.drain. *
-* 24 July 2004: WebValley 2004, error checking and vector points added by *
-* Matteo Franchi Liceo Leonardo Da Vinci Trento *
-* Roberto Flor ITC-irst *
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
@@ -102,31 +93,27 @@
module = G_define_module();
module->keywords = _("raster");
module->description =
- _("Traces a flow through an elevation model on a raster map layer.");
+ _("Traces a flow through an elevation model on a raster map.");
- opt1 = G_define_standard_option(G_OPT_R_INPUT);
- opt1->description =
- _("Name of existing raster map containing elevation surface");
+ opt1 = G_define_standard_option(G_OPT_R_ELEV);
+ opt1->key = "input";
opt2 = G_define_standard_option(G_OPT_R_OUTPUT);
- opt2->description = _("Output drain raster map");
coordopt = G_define_option();
coordopt->key = "coordinate";
coordopt->type = TYPE_STRING;
coordopt->required = NO;
coordopt->multiple = YES;
coordopt->key_desc = "x,y";
- coordopt->description = _("The E and N coordinates of starting point(s)");
+ coordopt->description = _("Map coordinates of starting point(s) (E,N)");
+ coordopt->guisection = _("Start");
- vpointopt = G_define_option();
+ vpointopt = G_define_standard_option(G_OPT_V_INPUTS);
vpointopt->key = "vector_points";
- vpointopt->type = TYPE_STRING;
vpointopt->required = NO;
- vpointopt->multiple = YES;
- vpointopt->gisprompt = "old,vector,vector";
- vpointopt->key_desc = "name";
- vpointopt->description = _("Vector map(s) containing starting point(s)");
+ vpointopt->description = _("Name of vector map(s) containing starting point(s)");
+ vpointopt->guisection = _("Start");
flag1 = G_define_flag();
flag1->key = 'c';
@@ -310,6 +297,8 @@
G_close_cell(map_id);
+ G_verbose_message(_("Calculating flow directions..."));
/* fill one-cell pits and take a first stab at flow directions */
filldir(fe, fd, nrows, &bnd, m);
@@ -370,7 +359,10 @@
/* build the output map */
+ G_message(_("Writing raster map <%s>..."),
+ new_map_name);
for (i = 0; i < nrows; i++) {
+ G_percent(i, nrows, 2);
G_set_c_null_value(out_buf, ncols);
thispoint = list;
while (thispoint->next != NULL) {
@@ -379,12 +371,10 @@
thispoint = thispoint->next;
G_put_c_raster_row(new_id, out_buf);
+ G_percent(1, 1, 1);
else { /* mode = 1 or 2 */
/* Output will be of the same type as input */
/* open a new file and allocate an output buffer */
new_id = G_open_raster_new(new_map_name, in_type);
@@ -422,7 +412,10 @@
+ new_map_name);
set_null_value(out_buf, ncols);
thispoint = list;
@@ -433,6 +426,7 @@
put_row(new_id, out_buf);
/* close files and free buffers */
@@ -452,6 +446,8 @@
G_free(in_buf);
G_free(out_buf);
+ G_done_msg(" ");
exit(EXIT_SUCCESS);
