[GRASS-SVN] r35377 -
grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline
svn_grass at osgeo.org
Mon Jan 12 17:39:55 EST 2009
Author: neteler
Date: 2009-01-12 17:39:55 -0500 (Mon, 12 Jan 2009)
New Revision: 35377
grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/main.c
Roberto Antol?\195?\173n: generate better messages (usage error tracking) (merge from trunk, r35375)
Modified: grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/main.c
--- grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/main.c 2009-01-12 22:39:29 UTC (rev 35376)
+++ grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/main.c 2009-01-12 22:39:55 UTC (rev 35377)
@@ -36,9 +36,11 @@
/* Variables' declarations */
- int nsply, nsplx, nlines, nrows, ncols, subregion_row, subregion_col;
+ int nsply, nsplx, nlines, nrows, ncols;
+ int nsubregion_col, nsubregion_row, subregion_row, subregion_col;
int last_row, last_column, grid, bilin, ext, flag_auxiliar, cross; /* booleans */
double passoN, passoE, lambda, mean;
+ double N_extension, E_extension, orloE, orloN;
char *mapset, *dvr, *db, *vector, *map, table_name[1024], title[64];
@@ -215,7 +217,7 @@
if (vector && map)
G_fatal_error(_("Choose either vector or raster output, not both"));
-#ifdef nodef
+#ifdef notdef
if (!vector && !map && !cross_corr_flag->answer)
G_fatal_error(_("No raster nor vector output"));
#endif
@@ -231,13 +233,13 @@
/* Open input ext vector */
if (!in_ext_opt->answer) {
ext = FALSE;
- G_warning(_("No vector map to interpolate. "
+ G_message(_("No vector map of sparse points to interpolate. "
"Interpolation will be done with <%s> vector map"),
in_opt->answer);
else {
ext = TRUE;
- G_warning(_("<%s> vector map will be interpolated"),
+ G_message(_("Vector map <%s> of sparse points will be interpolated"),
in_ext_opt->answer);
if ((mapset = G_find_vector2(in_ext_opt->answer, "")) == NULL)
@@ -353,6 +355,16 @@
/* Interpolation begins */
G_debug(1, "Interpolation()");
+ if (map) {
+ nrows = G_window_rows();
+ ncols = G_window_cols();
+ if (!G_alloc_matrix(nrows, ncols))
+ G_fatal_error(_("Interpolation: The region resolution is too high: "
+ "%d cells. Consider to change it."),
+ nrows * ncols);
/* Open driver and database */
driver = db_start_driver_open_database(dvr, db);
if (driver == NULL)
@@ -367,21 +379,11 @@
Vect_region_box(&elaboration_reg, &general_box);
/* Alloc raster matrix */
- if (raster) {
- double nrows_ncols;
+ if (map)
+ if (!(raster_matrix = G_alloc_matrix(nrows, ncols)))
+ G_fatal_error(_("Cannot allocate memory for auxiliar matrix."
+ "Consider changing region resolution"));
- nrows = G_window_rows();
- ncols = G_window_cols();
- nrows_ncols = (double)nrows *ncols;
- if ((nrows_ncols) > 30000000) /* about 5500x5500 cells */
- G_fatal_error(_("Interpolation: The region resolution is too high: %d cells. "
- "Consider to change it."), nrows_ncols);
- /*raster_matrix = G_alloc_fmatrix (nrows, ncols); Is it neccesary a double precision?? */
- raster_matrix = G_alloc_matrix(nrows, ncols);
/* Fixxing parameters of the elaboration region */
P_zero_dim(&dims); /* Set to zero the dim struct */
dims.latoE = NSPLX_MAX * passoE;
@@ -389,6 +391,18 @@
dims.overlap = OVERLAP_SIZE * passoE;
P_get_orlo(bilin, &dims, passoE, passoN); /* Set the last two dim elements */
+ N_extension = original_reg.ns_res * original_reg.rows;
+ E_extension = original_reg.ew_res * original_reg.cols;
+ orloE = dims.latoE - dims.overlap - 2 * dims.orlo_h;
+ orloN = dims.latoN - dims.overlap - 2 * dims.orlo_v;
+ nsubregion_col = 2 + ((E_extension - dims.latoE) / orloE);
+ nsubregion_row = 2 + ((N_extension - dims.latoN) / orloN);
+ if (nsubregion_col < 0)
+ nsubregion_col = 0;
+ if (nsubregion_row < 0)
+ nsubregion_row = 0;
/* Creating line and categories structs */
points = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
@@ -403,6 +417,7 @@
elaboration_reg.south = original_reg.north;
+ G_percent(0, 1, 10);
subregion_row = 0;
last_row = FALSE;
while (last_row == FALSE) { /* For each row */
@@ -441,6 +456,7 @@
subregion_col = 0;
while (last_column == FALSE) { /* For each column */
int npoints = 0;
+ int nsubzones = 0, subzone = 0;
subregion_col++;
P_set_regions(&elaboration_reg, &general_box, &overlap_box, dims,
@@ -518,6 +534,8 @@
if (bspline_field > 0) {
int cat, ival, ret, type;
+ if (!(type & GV_POINTS))
+ continue;
cat = observ[i].cat;
if (cat < 0)
continue;
@@ -670,6 +688,14 @@
G_free_ivector(lineVect);
+ else
+ G_warning(_("No data within this subzone. "
+ "Consider changing the spline step."));
+ subzone = (subregion_row - 1) * nsubregion_col + subregion_col;
+ nsubzones = nsubregion_row * nsubregion_col;
+ G_percent(subzone, nsubzones, 10);
} /*! END WHILE; last_column = TRUE */
} /*! END WHILE; last_row = TRUE */
@@ -713,7 +739,7 @@
G_write_history(out_map_opt->answer, &history);
- G_done_msg("");
+ G_done_msg(" ");
exit(EXIT_SUCCESS);
} /*END MAIN */
