[GRASS-SVN] r35407 -
grass/branches/releasebranch_6_4/vector/v.buffer2
svn_grass at osgeo.org
Wed Jan 14 12:59:37 EST 2009
Author: martinl
Date: 2009-01-14 12:59:37 -0500 (Wed, 14 Jan 2009)
New Revision: 35407
grass/branches/releasebranch_6_4/vector/v.buffer2/main.c
v.buffer2: cosmetics in guisections
(merge from devbr6, r35405)
Modified: grass/branches/releasebranch_6_4/vector/v.buffer2/main.c
--- grass/branches/releasebranch_6_4/vector/v.buffer2/main.c 2009-01-14 17:55:29 UTC (rev 35406)
+++ grass/branches/releasebranch_6_4/vector/v.buffer2/main.c 2009-01-14 17:59:37 UTC (rev 35407)
@@ -153,8 +153,10 @@
type_opt = G_define_standard_option(G_OPT_V_TYPE);
type_opt->options = "point,line,boundary,centroid,area";
type_opt->answer = "point,line,area";
+ type_opt->guisection = _("Selection");
field_opt = G_define_standard_option(G_OPT_V_FIELD);
+ field_opt->guisection = _("Selection");
dista_opt = G_define_option();
dista_opt->key = "distance";
@@ -162,6 +164,7 @@
dista_opt->required = NO;
dista_opt->description =
_("Buffer distance along major axis in map units");
+ dista_opt->guisection = _("Distance");
distb_opt = G_define_option();
distb_opt->key = "minordistance";
@@ -169,7 +172,7 @@
distb_opt->required = NO;
distb_opt->description =
_("Buffer distance along minor axis in map units");
- distb_opt->guisection = _("Advanced");
+ distb_opt->guisection = _("Distance");
angle_opt = G_define_option();
angle_opt->key = "angle";
@@ -177,15 +180,12 @@
angle_opt->required = NO;
angle_opt->answer = "0";
angle_opt->description = _("Angle of major axis in degrees");
- angle_opt->guisection = _("Advanced");
- bufcol_opt = G_define_option();
- bufcol_opt->key = "bufcol";
- bufcol_opt->type = TYPE_STRING;
- bufcol_opt->required = NO;
+ bufcol_opt = G_define_standard_option(G_OPT_COLUMN);
+ bufcol_opt->key = "bufcolumn";
bufcol_opt->description =
- _("Attribute column to use for buffer distances");
- bufcol_opt->guisection = _("Advanced");
+ _("Name of column to use for buffer distances");
+ bufcol_opt->guisection = _("Distance");
scale_opt = G_define_option();
scale_opt->key = "scale";
@@ -193,16 +193,15 @@
scale_opt->required = NO;
scale_opt->answer = "1.0";
scale_opt->description = _("Scaling factor for attribute column values");
- scale_opt->guisection = _("Advanced");
tol_opt = G_define_option();
tol_opt->key = "tolerance";
tol_opt->type = TYPE_DOUBLE;
tol_opt->required = NO;
tol_opt->answer = "0.01";
- tol_opt->guisection = _("Advanced");
tol_opt->description =
_("Maximum distance between theoretical arc and polygon segments as multiple of buffer");
+ tol_opt->guisection = _("Distance");
straight_flag = G_define_flag();
straight_flag->key = 's';
