[GRASS-SVN] r35418 -
grass/branches/releasebranch_6_4/scripts/i.fusion.brovey
svn_grass at osgeo.org
Thu Jan 15 13:21:35 EST 2009
Author: neteler
Date: 2009-01-15 13:21:35 -0500 (Thu, 15 Jan 2009)
New Revision: 35418
Added:
grass/branches/releasebranch_6_4/scripts/i.fusion.brovey/rgb_brovey.png
grass/branches/releasebranch_6_4/scripts/i.fusion.brovey/rgb_originals.png
grass/branches/releasebranch_6_4/scripts/i.fusion.brovey/description.html
example added
Modified: grass/branches/releasebranch_6_4/scripts/i.fusion.brovey/description.html
--- grass/branches/releasebranch_6_4/scripts/i.fusion.brovey/description.html 2009-01-15 17:53:11 UTC (rev 35417)
+++ grass/branches/releasebranch_6_4/scripts/i.fusion.brovey/description.html 2009-01-15 18:21:35 UTC (rev 35418)
@@ -21,6 +21,43 @@
region coordinates are respected. The three pan-sharpened output
channels may be combined with <em>d.rgb</em> or <em>r.composite</em>.
+<H2>EXAMPLE</H2>
+Calculation of Brovey fusion map from North Carolina Landsat scene:
+<div class="code"><pre>
+g.region rast=lsat7_2002_20 -p
+# R, G, B composite at 28.5m
+d.rgb b=lsat7_2002_10 g=lsat7_2002_20 r=lsat7_2002_30
+# Brovey fusion
+i.fusion.brovey -l ms1=lsat7_2002_20 ms2=lsat7_2002_40 \
+ ms3=lsat7_2002_50 pan=lsat7_2002_80 \
+ outputprefix=brovey
+# display at 14.25m
+g.region rast=brovey.blue -p
+d.rgb b=brovey.blue g=brovey.green r=brovey.red
+</pre></div>
+Results:
+<p>
+<center>
+<img src="rgb_originals.png" alt="R, G, B composite of Landsat at 28.5m">
+<br>
+<i>R, G, B composite of Landsat at 28.5m</i>
+</center>
+<p>
+<center>
+<img src="rgb_brovey.png" alt="R, G, B composite of Landsat Brovey fusion at 14.25m">
+<br>
+<i>R, G, B composite of Landsat Brovey fusion at 14.25m</i>
+</center>
+Colors may be optionally optimized.
<H2>SEE ALSO</H2>
<EM>
@@ -52,5 +89,5 @@
<H2>AUTHOR</H2>
-Markus Neteler, ITC-irst
+Markus Neteler, ITC-irst, Italy
<p><i>Last changed: $Date$</i>
Added: grass/branches/releasebranch_6_4/scripts/i.fusion.brovey/rgb_brovey.png
(Binary files differ)
Property changes on: grass/branches/releasebranch_6_4/scripts/i.fusion.brovey/rgb_brovey.png
___________________________________________________________________
+ image/png
Added: grass/branches/releasebranch_6_4/scripts/i.fusion.brovey/rgb_originals.png
Property changes on: grass/branches/releasebranch_6_4/scripts/i.fusion.brovey/rgb_originals.png
+ image/png
