[GRASS-SVN] r35422 - grass/branches/develbranch_6/scripts/i.tasscap
svn_grass at osgeo.org
Thu Jan 15 13:30:08 EST 2009
Author: neteler
Date: 2009-01-15 13:30:08 -0500 (Thu, 15 Jan 2009)
New Revision: 35422
Added:
grass/branches/develbranch_6/scripts/i.tasscap/tasscap1.png
grass/branches/develbranch_6/scripts/i.tasscap/tasscap2.png
grass/branches/develbranch_6/scripts/i.tasscap/tasscap3.png
grass/branches/develbranch_6/scripts/i.tasscap/tasscap4.png
grass/branches/develbranch_6/scripts/i.tasscap/description.html
example added
Modified: grass/branches/develbranch_6/scripts/i.tasscap/description.html
--- grass/branches/develbranch_6/scripts/i.tasscap/description.html 2009-01-15 18:27:55 UTC (rev 35421)
+++ grass/branches/develbranch_6/scripts/i.tasscap/description.html 2009-01-15 18:30:08 UTC (rev 35422)
@@ -1,9 +1,58 @@
<H2>DESCRIPTION</H2>
-<EM>i.tasscap</EM> calculates Tasseled Cap (Kauth Thomas) transformation for
-LANDSAT-TM data (TM4, TM5, TM7).
+<EM>i.tasscap</EM> calculates Tasseled Cap (Kauth Thomas, TC) transformation for
+LANDSAT-TM data (TM4, TM5, TM7). The following TC components are generated:
+<ul>
+<li> tasscap.1: corresponds to brightness,
+<li> tasscap.2: corresponds to greenness,
+<li> tasscap.3: corresponds to wetness,
+<li> tasscap.4: corresponds to atmospheric haze.
+</ul>
+<H2>EXAMPLE</H2>
+Calculation of TC maps from North Carolina Landsat scene:
+<div class="code"><pre>
+g.region rast=lsat7_2002_10 -p
+i.tasscap -7 band1=lsat7_2002_10 band2=lsat7_2002_20 \
+ band3=lsat7_2002_30 band4=lsat7_2002_40 \
+ band5=lsat7_2002_50 band7=lsat7_2002_70 \
+ outprefix=tasscap
+</pre></div>
+Results:
+<p>
+<center>
+<img src="tasscap1.png" alt="'Brightness' Tasseled Cap component 1">
+<br>
+<i>'Brightness' Tasseled Cap component 1</i>
+</center>
+<p>
+<center>
+<img src="tasscap2.png" alt="'Greenness' Tasseled Cap component 2">
+<br>
+<i>'Greenness' Tasseled Cap component 2</i>
+</center>
+<p>
+<center>
+<img src="tasscap3.png" alt="'Wetness' Tasseled Cap component 3">
+<br>
+<i>'Wetness' Tasseled Cap component 3</i>
+</center>
+<p>
+<center>
+<img src="tasscap4.png" alt="'Atmospheric haze' Tasseled Cap component 4">
+<br>
+<i>'Atmospheric haze' Tasseled Cap component 4</i>
+</center>
<H2>REFERENCES</H2>
<ul>
Added: grass/branches/develbranch_6/scripts/i.tasscap/tasscap1.png
(Binary files differ)
Property changes on: grass/branches/develbranch_6/scripts/i.tasscap/tasscap1.png
___________________________________________________________________
+ image/png
Added: grass/branches/develbranch_6/scripts/i.tasscap/tasscap2.png
Property changes on: grass/branches/develbranch_6/scripts/i.tasscap/tasscap2.png
+ image/png
Added: grass/branches/develbranch_6/scripts/i.tasscap/tasscap3.png
Property changes on: grass/branches/develbranch_6/scripts/i.tasscap/tasscap3.png
+ image/png
Added: grass/branches/develbranch_6/scripts/i.tasscap/tasscap4.png
Property changes on: grass/branches/develbranch_6/scripts/i.tasscap/tasscap4.png
+ image/png
