[GRASS-SVN] r35429 - grass/trunk/swig/python
svn_grass at osgeo.org
Fri Jan 16 04:54:26 EST 2009
Author: glynn
Date: 2009-01-16 04:54:25 -0500 (Fri, 16 Jan 2009)
New Revision: 35429
grass/trunk/swig/python/Makefile
grass/trunk/swig/python/test.py
Retain local copies of modules
Fix test script
Modified: grass/trunk/swig/python/Makefile
--- grass/trunk/swig/python/Makefile 2009-01-16 05:23:44 UTC (rev 35428)
+++ grass/trunk/swig/python/Makefile 2009-01-16 09:54:25 UTC (rev 35429)
@@ -27,7 +27,7 @@
EXTRA_SWIG = my_typemaps.i common.i
EXTRA_CFLAGS = $(PYMOD_CFLAGS)
-EXTRA_CLEAN_FILES := $(foreach M,$(MODULES),$(M)_wrap.o $(M)_wrap.c $(M).pyc $(M).py)
+EXTRA_CLEAN_FILES := $(foreach M,$(MODULES),$(M)_wrap.o $(M)_wrap.c $(M).pyc $(M).py _$(M).so)
CLEAN_SUBDIRS = NumPtr
include $(MODULE_TOPDIR)/include/Make/Python.make
@@ -59,8 +59,10 @@
.PHONY: numptr
-.KEEP: $(patsubst %,$(OBJDIR)/%_wrap.o,$(MODULES))
+.SECONDARY: $(patsubst %,$(OBJDIR)/%_wrap.o,$(MODULES))
+.SECONDARY: $(patsubst %,_%.so,$(MODULES))
date_wrap.c: $(ARCH_INCDIR)/datetime.h
date_wrap.c: $(ARCH_INCDIR)/P_datetime.h
grass_wrap.c: $(ARCH_INCDIR)/gis.h
Modified: grass/trunk/swig/python/test.py
--- grass/trunk/swig/python/test.py 2009-01-16 05:23:44 UTC (rev 35428)
+++ grass/trunk/swig/python/test.py 2009-01-16 09:54:25 UTC (rev 35429)
@@ -5,7 +5,7 @@
import os, sys
-import python_grass7 as g7lib
+import grass
if not os.environ.has_key("GISBASE"):
print "You must be in GRASS GIS to run this program."
@@ -14,16 +14,16 @@
rname = 'elevation.dem'
mapset = 'PERMANENT'
-g7lib.G_gisinit('')
-g7lib.G_find_cell2(rname,'')
+grass.G_gisinit('')
+grass.G_find_cell2(rname,'')
print mapset
print 'prints 0 if map was found'
print 'roads:'
-print g7lib.G_raster_map_type('roads',mapset)
+print grass.G_raster_map_type('roads',mapset)
print 'elevation.dem:'
-print g7lib.G_raster_map_type(rname,mapset)
+print grass.G_raster_map_type(rname,mapset)
