[GRASS-SVN] r35439 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Fri Jan 16 14:57:52 EST 2009
Author: martinl
Date: 2009-01-16 14:57:52 -0500 (Fri, 16 Jan 2009)
New Revision: 35439
grass/trunk/gui/wxpython/gui_modules/gdialogs.py
grass/trunk/gui/wxpython/gui_modules/menuform.py
grass/trunk/gui/wxpython/gui_modules/workspace.py
wxGUI: grc2gwx: gridline support added
(merge from relbr64, r35438)
Modified: grass/trunk/gui/wxpython/gui_modules/gdialogs.py
--- grass/trunk/gui/wxpython/gui_modules/gdialogs.py 2009-01-16 19:53:45 UTC (rev 35438)
+++ grass/trunk/gui/wxpython/gui_modules/gdialogs.py 2009-01-16 19:57:52 UTC (rev 35439)
@@ -10,7 +10,7 @@
- TextLayerDialog
- LoadMapLayersDialog
- MultiImportDialog
- - LayerList (used by MultiImport)
+ - LayersList (used by MultiImport)
- SetOpacityDialog
(C) 2008 by the GRASS Development Team
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2009-01-16 19:53:45 UTC (rev 35438)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2009-01-16 19:57:52 UTC (rev 35439)
@@ -1072,13 +1072,20 @@
maxValue = 1e6
txt2 = wx.SpinCtrl(parent=which_panel, id=wx.ID_ANY, size=globalvar.DIALOG_SPIN_SIZE,
min=minValue, max=maxValue)
+ txt2.SetName("SpinCtrl")
style = wx.BOTTOM | wx.LEFT
else:
txt2 = wx.TextCtrl(parent=which_panel, value = p.get('default',''))
+ txt.SetName("TextCtrl")
style = wx.EXPAND | wx.BOTTOM | wx.LEFT
- if p.get('value','') != '':
- txt2.SetValue(p['value']) # parameter previously set
+ if p.get('value', '') != '':
+ # parameter previously set
+ if txt2.GetName() == "SpinCtrl":
+ txt2.SetValue(int(p['value']))
+ else:
+ txt2.SetValue(p['value'])
which_sizer.Add(item=txt2, proportion=0,
flag=style, border=5)
Modified: grass/trunk/gui/wxpython/gui_modules/workspace.py
--- grass/trunk/gui/wxpython/gui_modules/workspace.py 2009-01-16 19:53:45 UTC (rev 35438)
+++ grass/trunk/gui/wxpython/gui_modules/workspace.py 2009-01-16 19:57:52 UTC (rev 35439)
@@ -664,7 +664,9 @@
self.inVector = False
elif self.inGroup:
self.inGroup = False
+ elif self.inGridline:
+ self.inGridline = False
elif element == 'opacity':
self.layers[-1]['opacity'] = float(self._get_value(line))
@@ -783,6 +785,64 @@
if value != '':
self.layers[-1]['cmd'].append('cats=%s' % value)
+ # gridline
+ elif element == 'gridline':
+ self.inGridline = True
+ self.layers.append({
+ "type" : 'grid',
+ "name" : self._get_value(line),
+ "checked" : None,
+ "opacity" : None,
+ "cmd" : ['d.grid'],
+ "group" : self.inGroup,
+ "display" : 0})
+ elif element == 'gridcolor':
+ value = self._get_value(line)
+ if value != '':
+ self.layers[-1]['cmd'].append('color=%s' % self._color_name_to_rgb(value))
+ elif element == 'gridborder':
+ if value != '':
+ self.layers[-1]['cmd'].append('bordercolor=%s' % self._color_name_to_rgb(value))
+ elif element == 'textcolor':
+ if value != '':
+ self.layers[-1]['cmd'].append('textcolor=%s' % self._color_name_to_rgb(value))
+ elif element in ('gridsize',
+ 'gridorigin'):
+ if value != '':
+ self.layers[-1]['cmd'].append('%s=%s' % (element[4:], value))
+ elif element in 'fontsize':
+ if value != '':
+ self.layers[-1]['cmd'].append('%s=%s' % (element, value))
+ elif element == 'griddraw':
+ if value == '0':
+ self.layers[-1]['cmd'].append('-n')
+ elif element == 'gridgeo':
+ if value == '1':
+ self.layers[-1]['cmd'].append('-g')
+ elif element == 'borderdraw':
+ if value == '0':
+ self.layers[-1]['cmd'].append('-b')
+ elif element == 'textdraw':
+ if value == '0':
+ self.layers[-1]['cmd'].append('-t')
else:
self.error += _(' row %d:') % line_id + line + os.linesep
self.num_error += 1
