[GRASS-SVN] r35462 - grass/trunk/vector/v.in.ascii
svn_grass at osgeo.org
Sat Jan 17 12:00:59 EST 2009
Author: martinl
Date: 2009-01-17 12:00:59 -0500 (Sat, 17 Jan 2009)
New Revision: 35462
grass/trunk/vector/v.in.ascii/main.c
v.in.ascii: input parameter required, guisection cosmetics
Modified: grass/trunk/vector/v.in.ascii/main.c
--- grass/trunk/vector/v.in.ascii/main.c 2009-01-17 15:06:01 UTC (rev 35461)
+++ grass/trunk/vector/v.in.ascii/main.c 2009-01-17 17:00:59 UTC (rev 35462)
@@ -8,7 +8,7 @@
* PURPOSE: Converts a vector map in ASCII format to a vector map
* in binary format
- * COPYRIGHT: (C) 2000-2007 by the GRASS Development Team
+ * COPYRIGHT: (C) 2000-2009 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -51,11 +51,9 @@
/************************** Command Parser ************************************/
old = G_define_standard_option(G_OPT_F_INPUT);
- old->required = NO;
- old->description =
- _("ASCII file to be imported, if not given reads from standard input");
- old->guisection = _("Required");
+ old->label = _("Name of input file to be imported");
+ old->description = ("'-' for standard input");
new = G_define_standard_option(G_OPT_V_OUTPUT);
format_opt = G_define_option();
@@ -65,12 +63,14 @@
format_opt->multiple = NO;
format_opt->options = "point,standard";
format_opt->descriptions = _("point;simple x,y[,z] list;"
- "standard;GRASS's vector ASCII format");
+ "standard;GRASS vector ASCII format");
format_opt->answer = "point";
format_opt->description = _("Input file format");
+ format_opt->guisection = _("Input format");
delim_opt = G_define_standard_option(G_OPT_F_SEP);
+ delim_opt->guisection = _("Input format");
skip_opt = G_define_option();
skip_opt->key = "skip";
skip_opt->type = TYPE_INTEGER;
@@ -79,27 +79,28 @@
skip_opt->answer = "0";
skip_opt->description =
_("Number of header lines to skip at top of input file (points mode)");
+ skip_opt->guisection = _("Points");
columns_opt = G_define_option();
columns_opt->key = "columns";
columns_opt->type = TYPE_STRING;
columns_opt->required = NO;
columns_opt->multiple = NO;
- columns_opt->guisection = _("Columns");
+ columns_opt->guisection = _("Points");
columns_opt->label = _("Column definition in SQL style (points mode)");
columns_opt->description = _("For example: "
"'x double precision, y double precision, cat int, "
"name varchar(10)'");
xcol_opt = G_define_option();
xcol_opt->key = "x";
xcol_opt->type = TYPE_INTEGER;
xcol_opt->required = NO;
xcol_opt->multiple = NO;
xcol_opt->answer = "1";
- xcol_opt->guisection = _("Columns");
- xcol_opt->description =
- _("Number of column used as x coordinate (first column is 1) for points mode");
+ xcol_opt->guisection = _("Points");
+ xcol_opt->label = ("Number of column used as x coordinate (points mode)");
+ xcol_opt->description = _("First column is 1");
ycol_opt = G_define_option();
ycol_opt->key = "y";
@@ -107,9 +108,9 @@
ycol_opt->required = NO;
ycol_opt->multiple = NO;
ycol_opt->answer = "2";
- ycol_opt->guisection = _("Columns");
- ycol_opt->description =
- _("Number of column used as y coordinate (first column is 1) for points mode");
+ ycol_opt->guisection = _("Points");
+ ycol_opt->label = _("Number of column used as y coordinate (points mode)");
+ ycol_opt->description = _("First column is 1");
zcol_opt = G_define_option();
zcol_opt->key = "z";
@@ -117,11 +118,9 @@
zcol_opt->required = NO;
zcol_opt->multiple = NO;
zcol_opt->answer = "0";
- zcol_opt->guisection = _("Columns");
- zcol_opt->label =
- _("Number of column used as z coordinate (first column is 1) for "
- "points mode");
- zcol_opt->description = _("If 0, z coordinate is not used");
+ zcol_opt->guisection = _("Points");
+ zcol_opt->label = _("Number of column used as z coordinate (points mode)");
+ zcol_opt->description = _("First column is 1. If 0, z coordinate is not used");
catcol_opt = G_define_option();
catcol_opt->key = "cat";
@@ -129,12 +128,12 @@
catcol_opt->required = NO;
catcol_opt->multiple = NO;
catcol_opt->answer = "0";
- catcol_opt->guisection = _("Columns");
+ catcol_opt->guisection = _("Points");
catcol_opt->label =
- _("Number of column used as category (first column is 1) for points mode");
+ _("Number of column used as category (points mode)");
catcol_opt->description =
- _("If 0, unique category is assigned to each row and written to new column 'cat'");
+ _("First column is 1. If 0, unique category is assigned to each row and written to new column 'cat'");
zcoorf = G_define_flag();
zcoorf->key = 'z';
zcoorf->description = _("Create 3D vector map");
@@ -142,28 +141,30 @@
e_flag = G_define_flag();
e_flag->key = 'e';
e_flag->description =
- _("Create a new empty vector map and exit. Nothing is read from input");
+ _("Create a new empty vector map and exit. Nothing is read from input.");
noheader_flag = G_define_flag();
noheader_flag->key = 'n';
noheader_flag->description =
_("Don't expect a header when reading in standard format");
+ noheader_flag->guisection = _("Input format");
t_flag = G_define_flag();
t_flag->key = 't';
t_flag->description = _("Do not create table in points mode");
- t_flag->guisection = _("Columns");
+ t_flag->guisection = _("Points");
notopol_flag = G_define_flag();
notopol_flag->key = 'b';
notopol_flag->description = _("Do not build topology in points mode");
+ notopol_flag->guisection = _("Points");
region_flag = G_define_flag();
region_flag->key = 'r';
region_flag->description =
_("Only import points falling within current region (points mode)");
+ region_flag->guisection = _("Points");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -196,7 +197,7 @@
if (xcol+1 < 1 || ycol+1 < 1 || zcol+1 < 0 || catcol+1 < 0)
G_fatal_error(_("Column numbers must not be negative"));
- if (old->answer != NULL) {
+ if (strcmp(old->answer, "-")) {
if ((ascii = fopen(old->answer, "r")) == NULL) {
G_fatal_error(_("Unable to open ASCII file <%s>"), old->answer);
@@ -204,7 +205,7 @@
else {
ascii = stdin;
fs = delim_opt->answer;
if (strcmp(fs, "\\t") == 0)
fs = "\t";
@@ -531,7 +532,7 @@
asc_to_bin(ascii, &Map);
+ if (ascii != stdin)
fclose(ascii);
if (notopol_flag->answer) {
