[GRASS-SVN] r35479 - grass/branches/releasebranch_6_4/db/base
    svn_grass at osgeo.org
    Sun Jan 18 01:23:14 EST 2009
Author: neteler
Date: 2009-01-18 01:23:14 -0500 (Sun, 18 Jan 2009)
New Revision: 35479
   grass/branches/releasebranch_6_4/db/base/execute.c
remove test if SELECT statement is used (merge from trunk, r35478)
Modified: grass/branches/releasebranch_6_4/db/base/execute.c
--- grass/branches/releasebranch_6_4/db/base/execute.c	2009-01-18 06:21:53 UTC (rev 35478)
+++ grass/branches/releasebranch_6_4/db/base/execute.c	2009-01-18 06:23:14 UTC (rev 35479)
@@ -135,7 +135,7 @@
 static int get_stmt(FILE * fd, dbString * stmt)
-    char buf[4000], buf2[4000], buf3[7];
+    char buf[4000], buf2[4000];
     int len, row = 0;
     db_init_string(stmt);
@@ -145,11 +145,6 @@
 	G_chop(buf2);
 	len = strlen(buf2);
-	G_strncpy(buf3, buf2, 6);
-	if (G_strcasecmp(buf3, "select") == 0)
-	    G_fatal_error(_("Use db.select for SELECT SQL statements"));
-	len = strlen(buf2);
 	if (buf2[len - 1] == ';') {	/* end of statement */
 	    buf2[len - 1] = 0;	/* truncate ';' */
 	    db_append_string(stmt, buf2);	/* append truncated */
