[GRASS-SVN] r35485 - grass/branches/develbranch_6/lib/gtcltk
Sun Jan 18 15:59:49 EST 2009
Author: cmbarton
Date: 2009-01-18 15:59:49 -0500 (Sun, 18 Jan 2009)
New Revision: 35485
   grass/branches/develbranch_6/lib/gtcltk/select.tcl
Fixed scrolling with mouse wheel so that it works correctly across multiple platforms--though testing on Windows would be helpful. Also updated the scrolling code in select.py so that it only polls scrollable windows where the mouse pointer is located, rather than all mapped windows.
Modified: grass/branches/develbranch_6/lib/gtcltk/select.tcl
--- grass/branches/develbranch_6/lib/gtcltk/select.tcl	2009-01-18 20:42:28 UTC (rev 35484)
+++ grass/branches/develbranch_6/lib/gtcltk/select.tcl	2009-01-18 20:59:49 UTC (rev 35485)
@@ -8,9 +8,9 @@
 #   GRASS 5. Subsequent modifications by members of the GRASS Development
 #   team.
-# Last update: September 2007
+# Last update: January 2009
-# COPYRIGHT:	(C) 1999 - 2007 by the GRASS Development Team
+# COPYRIGHT:	(C) 1999 - 2009 by the GRASS Development Team
 #		This program is free software under the GNU General Public
 #		License (>=v2). Read the file COPYING that comes with GRASS
@@ -24,54 +24,62 @@
 # We use the parent because the scrollbars are in the parent, and two scrollable
 # Things shouldn't have the same parent.
-set bind_scroll_list {}
+namespace eval GSelect_ {
+    variable count 1
+    variable dblclick
+    variable array selwin
+    variable tree
+    variable bind_scroll_list
+    set bind_scroll_list {}
-proc handle_scroll {amount} {
-    global bind_scroll_list
+proc handle_scroll {amount window} {
+    set scrlwin ""
-    foreach {x y} {-1 -1} {}
+    if {[lsearch -exact $bind_scroll_list $window] != -1} {
+        #window is a scrollable window
+        set scrlwin $window
+    } else {
+        # if window is not scrollable, find the parent that is scrollable
+        foreach item $bind_scroll_list {
+            if {[string first $item $window 0] != -1} {
+                set scrlwin $item
+                break
-    set window_gone 0
+    if {$scrlwin == "" } {return}
+    if {[tk windowingsystem] eq "win32"} {
+        $scrlwin yview scroll [expr {-$amount/120}] units
+    } else {
+        $scrlwin yview scroll [expr -1*$amount] units
+proc bind_scroll {frame} {
+    lappend bind_scroll_list $frame
+    # We should thin out windows that don't exist anymore if we find them
+    set new_bind_scroll_list {}
     foreach window $bind_scroll_list {
-        if {![winfo exists $window]} {
-            set window_gone 1
-            continue
-        if {![winfo ismapped $window]} continue
-        set parent [winfo parent $window]
-        set keyboard_focus [focus -displayof $window]
-        foreach {x y} [winfo pointerxy $window] {break}
-        set mouse_focus [winfo containing -displayof $window $x $y]
-		set l [string length $parent]
-        if {[string equal -length $l $parent $keyboard_focus] || \
-            [string equal -length $l $parent $mouse_focus]} {
-            $window yview scroll [expr  {-$amount/120}] units
+        if {[winfo exists $window]} {
+            lappend new_bind_scroll_list $window
+    set bind_scroll_list $new_bind_scroll_list
-    # We should thin out windows that don't exist anymore if we find them
-    if {$window_gone} {
-        set new_bind_scroll_list {}
-        foreach window $bind_scroll_list {
-            if {[winfo exists $window]} {
-                lappend new_bind_scroll_list $window
-        set bind_scroll_list $new_bind_scroll_list
-proc bind_scroll {frame} {
-    lappend bind_scroll_list $frame
+bind all <MouseWheel> "handle_scroll %D %W"
+if {[tk windowingsystem] eq "x11"} {
+    bind all <Button-4> "handle_scroll 1 %W"
+    bind all <Button-5> "handle_scroll -1 %W"
-bind all <MouseWheel> "handle_scroll %D"
-bind all <Button-4> "handle_scroll 120"
-bind all <Button-5> "handle_scroll -120"
 proc GSelect { element args } {
@@ -82,11 +90,6 @@
-namespace eval GSelect_ {
-    variable count 1
-    variable dblclick
-    variable array selwin
 proc GSelect_::create { element args } {
     # main procedure for creating and managing selection window, which a tree
@@ -95,6 +98,7 @@
     global env id
     variable selwin
     variable count
+    variable tree
     incr count
     set id $count
@@ -104,7 +108,7 @@
     set selwin($id,selected) {}
     if {[lsearch -exact $args "title"] > -1} {
-	append title " - [lindex $args [expr [lsearch -exact $args title]+1]]"
+        append title " - [lindex $args [expr [lsearch -exact $args title]+1]]"
     # Leave selection on top of caller window till it's closed
@@ -133,7 +137,7 @@
     set tree  [Tree $sw.tree \
                    -relief flat -borderwidth 0 -width 15 -highlightthickness 0\
-		   -redraw 1 -dropenabled 1 -dragenabled 1 \
+                   -redraw 1 -dropenabled 1 -dragenabled 1 \
                    -opencmd   "GSelect_::moddir 1 $sw.tree" \
                    -closecmd  "GSelect_::moddir 0 $sw.tree"]
@@ -146,9 +150,6 @@
     set h 400
     wm geometry $selwin($id,self) ${w}x$h$x$y
-    pack $sw    -side top  -expand yes -fill both
-    pack $tree  -side top -expand yes -fill both
     $tree bindText  <ButtonPress-1>        "GSelect_::select $id $tree"
     $tree bindImage <ButtonPress-1>        "GSelect_::select $id $tree"
     $tree bindText  <Double-ButtonPress-1> "GSelect_::selectclose $id $tree"
@@ -170,16 +171,16 @@
             if { ! [ file exists $windfile ] } { continue }
             if { $dir == $current_mapset } {
                 $tree insert end root ms_$dir -text $dir -data $dir -open 1 \
-                -image [Bitmap::get openfold] -drawcross auto
+                    -image [Bitmap::get openfold] -drawcross auto
             } else {
                 $tree insert end root ms_$dir -text $dir -data $dir -open 0 \
-                -image [Bitmap::get folder] -drawcross auto
+                    -image [Bitmap::get folder] -drawcross auto
             set path "$location_path/$dir/$element/"
             foreach fp [ lsort -dictionary [glob -nocomplain $path/*] ]  {
-            set file [file tail $fp]
-            $tree insert end ms_$dir $file@$dir -text $file -data $file \
-                -image [Bitmap::get file] -drawcross never
+                set file [file tail $fp]
+                $tree insert end ms_$dir $file@$dir -text $file -data $file \
+                    -image [Bitmap::get file] -drawcross never
@@ -208,9 +209,6 @@
     button $selwin($id,self).ok -text [G_msg "Ok"] -command "destroy $selwin($id,self)"
     button $selwin($id,self).cancel -text [G_msg "Cancel"] -command "GSelect_::terminate $id"
-    pack $selwin($id,self).ok $selwin($id,self).cancel -side left -expand yes
     # ScrollView
     toplevel $selftop -relief raised -borderwidth 2
     wm protocol $selftop WM_DELETE_WINDOW {
@@ -220,6 +218,10 @@
     wm withdraw $selftop
     wm transient $selftop $selwin($id,self)
     ScrollView $selftop.sv -window $tree -fill black
+    pack $sw   -side top  -expand yes -fill both
+    pack $tree  -side top -expand yes -fill both
+    pack $selwin($id,self).ok $selwin($id,self).cancel -side left -expand yes
     pack $selftop.sv -fill both -expand yes
     wm protocol $selwin($id,self) WM_DELETE_WINDOW "GSelect_::terminate $id"
