[GRASS-SVN] r35490 - grass/trunk/vector/v.net
svn_grass at osgeo.org
Mon Jan 19 17:31:58 EST 2009
Author: martinl
Date: 2009-01-19 17:31:57 -0500 (Mon, 19 Jan 2009)
New Revision: 35490
Added:
grass/trunk/vector/v.net/arcs.c
grass/trunk/vector/v.net/args.c
grass/trunk/vector/v.net/connect.c
grass/trunk/vector/v.net/main.c
grass/trunk/vector/v.net/nodes.c
grass/trunk/vector/v.net/proto.h
grass/trunk/vector/v.net/report.c
grass/trunk/vector/v.net/v.net.html
v.net: general update
new operation 'arcs'
Added: grass/trunk/vector/v.net/arcs.c
--- grass/trunk/vector/v.net/arcs.c (rev 0)
+++ grass/trunk/vector/v.net/arcs.c 2009-01-19 22:31:57 UTC (rev 35490)
@@ -0,0 +1,103 @@
+#include <stdlib.h>
+#include <grass/gis.h>
+#include <grass/Vect.h>
+#include <grass/glocale.h>
+#include "proto.h"
+static int find_node(struct Map_info *, int, int);
+void field2n(struct line_cats *, int);
+ * \brief Create network arcs (edge) based on given point vector map (nodes)
+ * \param file input file defining arcs
+ * \param Points input vector point map
+ * \param Out output vector map
+ * \param afield arcs layer
+ * \param nfield nodes layer
+ * \return number of new arcs
+int create_arcs(FILE * file, struct Map_info *Pnts,
+ struct Map_info *Out, int afield, int nfield)
+ char buff[1024];
+ int lcat, fcat, tcat;
+ int node1, node2;
+ int narcs;
+ struct line_pnts *points, *points2;
+ struct line_cats *cats;
+ points = Vect_new_line_struct();
+ points2 = Vect_new_line_struct();
+ cats = Vect_new_cats_struct();
+ narcs = 0;
+ while (G_getl2(buff, sizeof(buff) - 1, file)) {
+ if (sscanf(buff, "%d%d%d", &lcat, &fcat, &tcat) != 3)
+ G_fatal_error(_("Error reading file: '%s'"), buff);
+ node1 = find_node(Pnts, afield, fcat);
+ node2 = find_node(Pnts, afield, tcat);
+ if (node1 < 1 || node2 < 1) {
+ G_warning(_("Skipping arc %d"), lcat);
+ continue;
+ /* geometry */
+ Vect_read_line(Pnts, points, cats, node1);
+ field2n(cats, nfield);
+ Vect_write_line(Out, GV_POINT, points, cats);
+ Vect_read_line(Pnts, points2, cats, node2);
+ Vect_write_line(Out, GV_POINT, points2, cats);
+ Vect_append_points(points, points2, GV_FORWARD);
+ /* category */
+ Vect_reset_cats(cats);
+ Vect_cat_set(cats, afield, lcat);
+ Vect_write_line(Out, GV_LINE, points, cats);
+ narcs++;
+ Vect_destroy_line_struct(points);
+ Vect_destroy_cats_struct(cats);
+ return narcs;
+int find_node(struct Map_info *Pnts, int field, int cat)
+ static struct ilist *list;
+ if (!list)
+ list = Vect_new_list();
+ /* find start node */
+ Vect_cidx_find_all(Pnts, field, GV_POINT, cat, list);
+ if (list->n_values < 1) {
+ G_warning(_("No point with category %d found"), cat);
+ return 0;
+ if (list->n_values > 1) {
+ G_warning(_("More points with category %d found"), cat);
+ return 0;
+ return list->value[0];
+void field2n(struct line_cats *cats, int nfield)
+ int n;
+ for (n = 0; n < cats->n_cats; n++) {
+ cats->field[n] = nfield;
Property changes on: grass/trunk/vector/v.net/arcs.c
___________________________________________________________________
+ text/x-csrc
+ Author Date Id
+ native
Added: grass/trunk/vector/v.net/args.c
--- grass/trunk/vector/v.net/args.c (rev 0)
+++ grass/trunk/vector/v.net/args.c 2009-01-19 22:31:57 UTC (rev 35490)
@@ -0,0 +1,137 @@
+#include "proto.h"
+void define_options(struct opt *opt)
+ opt->input = G_define_standard_option(G_OPT_V_INPUT);
+ opt->input->required = NO;
+ opt->input->label = _("Name of input vector line map (arcs)");
+ opt->input->description = _("Required for operation 'nodes', 'connect', "
+ "'report' and 'nreport'");
+ opt->input->guisection = _("Arcs");
+ opt->points = G_define_standard_option(G_OPT_V_INPUT);
+ opt->points->key = "points";
+ opt->points->label = _("Name of input vector point map (nodes)");
+ opt->points->description =
+ _("Required for operation 'connect' and 'arcs'");
+ opt->points->required = NO;
+ opt->points->guisection = _("Nodes");
+ opt->output = G_define_standard_option(G_OPT_V_OUTPUT);
+ opt->output->required = NO;
+ opt->action = G_define_option();
+ opt->action->key = "operation";
+ opt->action->type = TYPE_STRING;
+ opt->action->required = YES;
+ opt->action->multiple = NO;
+ opt->action->options = "nodes,connect,arcs,report,nreport";
+ opt->action->description = _("Operation to be performed");
+ opt->action->descriptions =
+ _("nodes;"
+ "new point is placed on each node (line end) "
+ "if doesn't exist;"
+ "connect;"
+ "connect still unconnected points to vector network "
+ "by inserting new line(s);"
+ "arcs;"
+ "new line is created from start point "
+ "to end point;"
+ "report;"
+ "print to standard output "
+ "{line_category start_point_category end_point_category};"
+ "nreport;"
+ "{point_category line_category[,line_category...]}");
+ opt->afield_opt = G_define_standard_option(G_OPT_V_FIELD);
+ opt->afield_opt->key = "alayer";
+ opt->afield_opt->gisprompt = "new_layer,layer,layer";
+ opt->afield_opt->label = _("Arc layer");
+ opt->afield_opt->guisection = _("Arcs");
+ opt->nfield_opt = G_define_standard_option(G_OPT_V_FIELD);
+ opt->nfield_opt->key = "nlayer";
+ opt->nfield_opt->answer = "2";
+ opt->nfield_opt->gisprompt = "new_layer,layer,layer";
+ opt->nfield_opt->label = _("Node layer");
+ opt->nfield_opt->guisection = _("Nodes");
+ opt->thresh_opt = G_define_option();
+ opt->thresh_opt->key = "thresh";
+ opt->thresh_opt->type = TYPE_DOUBLE;
+ opt->thresh_opt->required = NO;
+ opt->thresh_opt->multiple = NO;
+ opt->thresh_opt->label = "Threshold";
+ opt->thresh_opt->description =
+ _("Required for operation 'connect'. Connect points in given threshold.");
+ opt->file = G_define_standard_option(G_OPT_F_INPUT);
+ opt->file->key = "file";
+ opt->file->label = _("Name of input file");
+ opt->file->description =
+ _("Required for operation 'arcs'. '-' for standard input.");
+ opt->file->required = NO;
+ opt->cats_flag = G_define_flag();
+ opt->cats_flag->key = 'c';
+ opt->cats_flag->label = _("Assign unique categories to new points");
+ opt->cats_flag->description = _("For operation 'nodes'");
+ opt->cats_flag->guisection = _("Nodes");
+void parse_arguments(const struct opt *opt,
+ int *afield, int *nfield, double *thresh, int *act)
+ *afield = atoi(opt->afield_opt->answer);
+ *nfield = atoi(opt->nfield_opt->answer);
+ *thresh = 0.0;
+ if (strcmp(opt->action->answer, "nodes") == 0)
+ *act = TOOL_NODES;
+ else if (strcmp(opt->action->answer, "connect") == 0)
+ *act = TOOL_CONNECT;
+ else if (strcmp(opt->action->answer, "report") == 0)
+ *act = TOOL_REPORT;
+ else if (strcmp(opt->action->answer, "nreport") == 0)
+ *act = TOOL_NREPORT;
+ else if (strcmp(opt->action->answer, "arcs") == 0)
+ *act = TOOL_ARCS;
+ else
+ G_fatal_error(_("Unknown operation"));
+ if (*act == TOOL_NODES || *act == TOOL_CONNECT ||
+ *act == TOOL_REPORT || *act == TOOL_NREPORT) {
+ if (opt->input->answer == NULL)
+ G_fatal_error(_("Required parameter <%s> not set"),
+ opt->input->key);
+ if (*act == TOOL_NODES || *act == TOOL_CONNECT) {
+ if (opt->output->answer == NULL)
+ opt->output->key);
+ if (*act == TOOL_CONNECT) {
+ if (opt->points->answer == NULL)
+ opt->points->key);
+ if (opt->thresh_opt->answer == NULL)
+ opt->thresh_opt->key);
+ *thresh = atof(opt->thresh_opt->answer);
+ if (*thresh < 0.0)
+ G_fatal_error(_("Threshold value must be >= 0"));
+ if (*act == TOOL_ARCS && !opt->file->answer) {
+ G_fatal_error(_("Required parameter <%s> not set"), opt->file->key);
Property changes on: grass/trunk/vector/v.net/args.c
+ text/x-csrc
+ Author Date Id
+ native
Modified: grass/trunk/vector/v.net/connect.c
--- grass/trunk/vector/v.net/connect.c 2009-01-19 21:06:38 UTC (rev 35489)
+++ grass/trunk/vector/v.net/connect.c 2009-01-19 22:31:57 UTC (rev 35490)
@@ -1,24 +1,6 @@
- * MODULE: v.net
- * AUTHOR(S): Martin Landa <landa.martin gmail.com>
- * PURPOSE: Network maintenance
- * COPYRIGHT: (C) 2007 by the GRASS Development Team
- * This program is free software under the
- * GNU General Public License (>=v2).
- * Read the file COPYING that comes with GRASS
- * for details.
#include <stdlib.h>
-#include <grass/glocale.h>
#include "proto.h"
@@ -27,10 +9,10 @@
* If there is no connection between network edge and point, new edge
* is added, the line broken, and new point added to nfield layer
- * \param[in] In,Points input vector maps
- * \param[in] Out output vector map
- * \param[in] nfield nodes layer
- * \param[in] thresh threshold value to find neareast line
+ * \param In,Points input vector maps
+ * \param thresh threshold value to find neareast line
Modified: grass/trunk/vector/v.net/main.c
--- grass/trunk/vector/v.net/main.c 2009-01-19 21:06:38 UTC (rev 35489)
+++ grass/trunk/vector/v.net/main.c 2009-01-19 22:31:57 UTC (rev 35490)
@@ -4,12 +4,11 @@
* MODULE: v.net
* AUTHOR(S): Radim Blazek
- * Operation 'connect' added by Martin Landa
- * <landa.martin gmail.com>, 2007/07
+ * Martin Landa <landa.martin gmail.com> (connect/arcs)
- * COPYRIGHT: (C) 2001-2008 by the GRASS Development Team
+ * COPYRIGHT: (C) 2001-2009 by the GRASS Development Team
@@ -21,183 +20,155 @@
#include <stdio.h>
#include <string.h>
#include "proto.h"
int main(int argc, char **argv)
struct GModule *module;
- struct Option *input, *points;
- struct Option *output;
- struct Option *action;
- struct Option *afield_opt, *nfield_opt, *thresh_opt;
- struct Flag *cats_flag;
- struct Map_info In, Out, Points;
+ struct opt opt;
+ struct Map_info *In, *Out, *Points;
+ FILE *file_arcs;
int afield, nfield;
int act;
double thresh;
- /* Initialize the GIS calls */
+ char message[4096];
+ /* initialize the GIS calls */
G_gisinit(argv[0]);
module = G_define_module();
module->keywords = _("vector, networking");
module->description = _("Performs network maintenance.");
- /* Define the options */
- input = G_define_standard_option(G_OPT_V_INPUT);
+ define_options(&opt);
- points = G_define_standard_option(G_OPT_V_INPUT);
- points->key = "points";
- points->label = _("Name of input point vector map");
- points->description = _("Required for operation 'connect'");
- points->required = NO;
- output = G_define_standard_option(G_OPT_V_OUTPUT);
- output->required = NO;
- action = G_define_option();
- action->key = "operation";
- action->type = TYPE_STRING;
- action->required = NO;
- action->multiple = NO;
- action->answer = "nodes";
- action->options = "nodes,connect,report,nreport";
- action->description = _("Operation to be performed");
- action->descriptions =
- _("nodes;new point is placed on each node (line end) "
- "if doesn't exist;"
- "connect;connect still unconnected points to vector network "
- "by inserting new line(s);" "report;print to standard output "
- "{line_category start_point_category end_point_category};"
- "nreport;print to standard output "
- "{point_category line_category[,line_category...]}");
- afield_opt = G_define_standard_option(G_OPT_V_FIELD);
- afield_opt->key = "alayer";
- afield_opt->gisprompt = "new_layer,layer,layer";
- afield_opt->label = _("Arc layer");
- nfield_opt = G_define_standard_option(G_OPT_V_FIELD);
- nfield_opt->key = "nlayer";
- nfield_opt->answer = "2";
- nfield_opt->gisprompt = "new_layer,layer,layer";
- nfield_opt->label = _("Node layer");
- thresh_opt = G_define_option();
- thresh_opt->key = "thresh";
- thresh_opt->type = TYPE_DOUBLE;
- thresh_opt->required = NO;
- thresh_opt->multiple = NO;
- thresh_opt->label = "Threshold";
- thresh_opt->description =
- _("Required for operation 'connect'. Connect points in given threshold.");
- cats_flag = G_define_flag();
- cats_flag->key = 'c';
- cats_flag->label = _("Assign unique categories to new points");
- cats_flag->description = _("For operation 'nodes'");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- afield = atoi(afield_opt->answer);
- nfield = atoi(nfield_opt->answer);
- thresh = 0.0;
+ parse_arguments(&opt, &afield, &nfield, &thresh, &act);
- if (strcmp(action->answer, "nodes") == 0)
- act = TOOL_NODES;
- else if (strcmp(action->answer, "connect") == 0)
- act = TOOL_CONNECT;
- else if (strcmp(action->answer, "report") == 0)
- act = TOOL_REPORT;
- else if (strcmp(action->answer, "nreport") == 0)
- act = TOOL_NREPORT;
- else
- G_fatal_error(_("Unknown operation"));
- if (act == TOOL_NODES || act == TOOL_CONNECT) {
- if (output->answer == NULL)
- G_fatal_error(_("Output vector map must be specified"));
+ In = Points = Out = NULL;
+ file_arcs = NULL;
+ message[0] = '\0';
+ /* open input map */
+ if (act != TOOL_ARCS) {
+ In = (struct Map_info *)G_malloc(sizeof(struct Map_info));
+ Vect_set_open_level(2);
+ if (Vect_open_old(In, opt.input->answer, "") == -1)
+ G_fatal_error(_("Unable to open vector map <%s>"),
+ opt.input->answer);
- if (act == TOOL_CONNECT) {
- if (points->answer == NULL)
- G_fatal_error(_("Point vector map must be specified"));
- if (thresh_opt->answer == NULL)
- G_fatal_error(_("Threshold value must be specified"));
- thresh = atof(thresh_opt->answer);
- if (thresh < 0.0)
- G_fatal_error(_("Threshold value must be >= 0"));
- /* open input map */
- Vect_set_open_level(2);
- Vect_open_old(&In, input->answer, "");
- if (act == TOOL_NODES || act == TOOL_CONNECT) { /* nodes */
+ if (act == TOOL_NODES || act == TOOL_CONNECT || act == TOOL_ARCS) {
int is3d;
- Vect_check_input_output_name(input->answer, output->answer,
- GV_FATAL_EXIT);
+ /* non-report operations */
+ /* check input-output */
+ Vect_check_input_output_name(opt.input->answer,
+ opt.output->answer, GV_FATAL_EXIT);
+ if (act == TOOL_CONNECT || act == TOOL_ARCS) {
/* open points map */
- Vect_set_open_level(1);
- Vect_set_fatal_error(GV_FATAL_PRINT);
- if (Vect_open_old(&Points, points->answer, "") == -1) {
- Vect_close(&In);
+ Points = (struct Map_info *)G_malloc(sizeof(struct Map_info));
+ if (act == TOOL_CONNECT)
+ Vect_set_open_level(1);
+ else
+ if (Vect_open_old(Points, opt.points->answer, "") == -1) {
+ if (In)
+ Vect_close(In);
- points->answer);
+ opt.points->answer);
+ if (act == TOOL_ARCS) {
+ /* open input file */
+ if (strcmp(opt.file->answer, "-")) {
+ if ((file_arcs = fopen(opt.file->answer, "r")) == NULL) {
+ G_fatal_error(_("Unable to open file <%s>"),
+ opt.file->answer);
+ else {
+ file_arcs = stdin;
/* create output map */
- is3d = Vect_is_3d(&In);
- if (1 > Vect_open_new(&Out, output->answer, is3d)) {
- Vect_close(&In);
+ Out = (struct Map_info *)G_malloc(sizeof(struct Map_info));
+ is3d = WITHOUT_Z;
+ if (In)
+ is3d = Vect_is_3d(In);
+ else if (Points)
+ is3d = Vect_is_3d(Points);
+ if (Vect_open_new(Out, opt.output->answer, is3d) == -1) {
+ if (In)
+ Vect_close(In);
G_fatal_error(_("Unable to open vector map <%s> at topology level %d"),
- output->answer, 2);
+ opt.output->answer, 2);
- Vect_copy_head_data(&In, &Out);
- Vect_hist_copy(&In, &Out);
- Vect_hist_command(&Out);
+ /* copy header */
+ if (In) {
+ Vect_copy_head_data(In, Out);
+ Vect_hist_copy(In, Out);
+ Vect_hist_command(Out);
if (act == TOOL_NODES) {
- nodes(&In, &Out, cats_flag->answer, nfield);
+ /* nodes */
+ int nnodes;
+ nnodes = nodes(In, Out, opt.cats_flag->answer, nfield);
+ sprintf (message, _("%d new points (nodes) written to output."), nnodes);
- else { /* TOOL_CONNECT */
+ else { /* connect or arcs */
int narcs;
- narcs = connect_arcs(&In, &Points, &Out, nfield, thresh);
+ narcs = connect_arcs(In, Points, Out, nfield, thresh);
+ else
+ narcs = create_arcs(file_arcs, Points, Out, afield, nfield);
- G_message(_("%d arcs added to network (nlayer %d)"), narcs,
- nfield);
- Vect_close(&Points);
+ sprintf(message, _("%d lines (arcs) written to output."), narcs, nfield);
- if (Vect_copy_tables(&In, &Out, 0))
- G_warning(_("Failed to copy attribute table to output map"));
+ if (In) {
+ G_message (_("Copying attributes..."));
+ if (Vect_copy_tables(In, Out, 0))
+ G_warning(_("Failed to copy attribute table to output map"));
/* support */
- Vect_build_partial(&Out, GV_BUILD_NONE);
- Vect_build(&Out);
+ Vect_build_partial(Out, GV_BUILD_NONE);
+ Vect_build(Out);
- Vect_close(&In);
- Vect_close(&Out);
+ if (Points)
+ Vect_close(Points);
+ if (Out)
+ Vect_close(Out);
else { /* report */
- report(&In, afield, nfield, act);
+ report(In, afield, nfield, act);
+ if (In)
+ Vect_close(In);
+ if (file_arcs)
+ fclose(file_arcs);
+ G_done_msg(message);
return (EXIT_SUCCESS);
Modified: grass/trunk/vector/v.net/nodes.c
--- grass/trunk/vector/v.net/nodes.c 2009-01-19 21:06:38 UTC (rev 35489)
+++ grass/trunk/vector/v.net/nodes.c 2009-01-19 22:31:57 UTC (rev 35490)
@@ -1,20 +1,3 @@
- * MODULE: v.net
- * AUTHOR(S): Radim Blazek
- * COPYRIGHT: (C) 2001 by the GRASS Development Team
- * for details.
#include <stdlib.h>
@@ -25,8 +8,10 @@
int i, node, nnodes, line, nlines, count, type, found;
double x, y, z;
struct line_pnts *Points, *Pout;
struct line_cats *Cats;
int cat;
Points = Vect_new_line_struct();
@@ -82,11 +67,9 @@
- G_message(_("%d new points written to output"), count);
Vect_destroy_line_struct(Points);
Vect_destroy_line_struct(Pout);
Vect_destroy_cats_struct(Cats);
- return 0;
+ return count;
Modified: grass/trunk/vector/v.net/proto.h
--- grass/trunk/vector/v.net/proto.h 2009-01-19 21:06:38 UTC (rev 35489)
+++ grass/trunk/vector/v.net/proto.h 2009-01-19 22:31:57 UTC (rev 35490)
@@ -2,14 +2,34 @@
#define TOOL_CONNECT 1
#define TOOL_REPORT 2
#define TOOL_NREPORT 3
+#define TOOL_ARCS 4
+struct opt {
+ struct Option *input, *points;
+ struct Option *output;
+ struct Option *action;
+ struct Option *afield_opt, *nfield_opt, *thresh_opt;
+ struct Option *file;
+ struct Flag *cats_flag;
+/* arcs.c */
+int create_arcs(FILE *, struct Map_info *,
+ struct Map_info *, int, int);
+/* argc.c */
+void define_options(struct opt *);
+void parse_arguments(const struct opt *,
+ int *, int *, double *, int *);
/* connect.c */
-int connect_arcs(struct Map_info *In, struct Map_info *Pnts,
- struct Map_info *Out, int nfield, double thresh);
+int connect_arcs(struct Map_info *, struct Map_info *,
+ struct Map_info *, int, double);
/* nodes.c */
-int nodes(struct Map_info *In, struct Map_info *Out, int add_cats,
- int nfield);
+int nodes(struct Map_info *, struct Map_info *, int,
+ int);
/* report.c */
-int report(struct Map_info *In, int afield, int nfield, int action);
+int report(struct Map_info *, int, int,
+ int);
Modified: grass/trunk/vector/v.net/report.c
--- grass/trunk/vector/v.net/report.c 2009-01-19 21:06:38 UTC (rev 35489)
+++ grass/trunk/vector/v.net/report.c 2009-01-19 22:31:57 UTC (rev 35490)
@@ -1,20 +1,3 @@
- * MODULE: v.net
- * for details.
#include <stdlib.h>
@@ -25,7 +8,9 @@
int i, j, k, line, ltype, nnodes;
int cat_line, cat_node[2];
struct line_cats *Cats, *Cats2;
int node;
double x, y, z;
Modified: grass/trunk/vector/v.net/v.net.html
--- grass/trunk/vector/v.net/v.net.html 2009-01-19 21:06:38 UTC (rev 35489)
+++ grass/trunk/vector/v.net/v.net.html 2009-01-19 22:31:57 UTC (rev 35490)
@@ -1,9 +1,9 @@
<h2>DESCRIPTION</h2>
-<em>v.net</em> is used for vector network maps maintenance.
-It reports about the current network graph status.
-It also permits to globally insert missing nodes and to connect
-unconnected nodes to the graph within a given distance threshold.
+<em>v.net</em> is used for vector network maps maintenance. It
+reports the current network graph status. It also permits to globally
+insert missing nodes or arcs and to connect unconnected nodes to the
+graph within a given distance threshold.
<h3>NOTES</h3>
@@ -11,37 +11,45 @@
graph, <em><a href="wxGUI.Vector_Digitizing_Tool.html">wxGUI vector
digitizer</a></em> or <em><a href="v.edit.html">v.edit</a></em> can be
used. Separately,
-<a HREF="lrs.html">Linear Referencing System</a> is available
-in GRASS.
+<a href="lrs.html">Linear Referencing System</a> is available in
+GRASS.
<h3>EXAMPLES</h3>
-Spearfish based examples:<P>
+<a href="http://www.grassbook.org/data_menu3rd.php">NC dataset</a> based examples.
+<p>
Create nodes globally for all line ends and intersections:
-<br>
<div class="code"><pre>
-v.net in=streams out=streams_node
+v.net input=streams output=streams_node operation=nodes
</pre></div>
-<P>
Merge in nodes from a separate map within given threshold:
-<br>
-echo "1|601653.5|4922869.2|start
-2|593330.8|4924096.6|end" | v.in.ascii cat=1 x=2 y=3 out=startend col="cat integer, \
- east double precision, north double precision, label varchar(43)"
+v.net input=streams points=firestations out=streems_net operation=connect thresh=500
+</pre></div>
-#create lines map connecting points to network (on layer 2)
-v.net myroads points=startend out=myroads_net op=connect thresh=200
+For generating network for given vector point map is required input file in format
+<div class="code"><pre>
+[category of edge] [category of start node] [category of end node]
</pre></div>
+v.net points=geodetic_swwake_pts output=geodetic_swwake_pts_net operation=arcs file=- << EOF
+> 1 28000 28005
+> 2 27945 27958
+> 3 27886 27897
+> EOF
+</pre></div>
<h2>SEE ALSO</h2>
<em>
<a href="wxGUI.Vector_Digitizing_Tool.html">wxGUI vector digitizer</a>,
- <a HREF="v.edit.html">v.edit</a>,
+ <a HREF="v.edit.html">v.edit</a><br>
<a HREF="v.net.iso.html">v.net.iso</a>,
<a HREF="v.net.path.html">v.net.path</a>,
<a HREF="v.net.steiner.html">v.net.steiner</a>,
@@ -50,7 +58,10 @@
<h2>AUTHORS</h2>
-Radim Blazek, ITC-Irst, Trento, Italy<BR>
-Martin Landa, FBK-Irst, Trento, Italy
+Radim Blazek, ITC-irst, Trento, Italy<br>
-<p><i>Last changed: $Date$</i>
+Martin Landa, FBK-irst (formerly ITC-irst), Trento, Italy and CTU in
+Prague, Czech Republic (operation 'connect' and 'arcs')
+<p>
+<i>Last changed: $Date$</i>
