[GRASS-SVN] r35493 - in grass/trunk/raster/r.watershed: front ram
seg
svn_grass at osgeo.org
Tue Jan 20 05:50:15 EST 2009
Author: mmetz
Date: 2009-01-20 05:50:15 -0500 (Tue, 20 Jan 2009)
New Revision: 35493
grass/trunk/raster/r.watershed/front/main.c
grass/trunk/raster/r.watershed/front/r.watershed.html
grass/trunk/raster/r.watershed/ram/init_vars.c
grass/trunk/raster/r.watershed/seg/init_vars.c
Input maps depression and blocking terrain: use non-NULL and non-zero cells, previously prepared maps should work as before. Updated documentation.
Modified: grass/trunk/raster/r.watershed/front/main.c
--- grass/trunk/raster/r.watershed/front/main.c 2009-01-20 07:54:16 UTC (rev 35492)
+++ grass/trunk/raster/r.watershed/front/main.c 2009-01-20 10:50:15 UTC (rev 35493)
@@ -63,7 +63,7 @@
opt2 = G_define_option();
opt2->key = "depression";
opt2->label = _("Input map: locations of real depressions");
- opt2->description = _("All non-NULL cells are considered as real depressions");
+ opt2->description = _("All non-NULL and non-zero cells are considered as real depressions");
opt2->required = NO;
opt2->type = TYPE_STRING;
opt2->gisprompt = "old,cell,raster";
@@ -91,7 +91,7 @@
opt5->label =
_("Input map: terrain blocking overland surface flow, for USLE");
opt5->description =
- _("All non-NULL cells are considered as blocking terrain");
+ _("All non-NULL and non-zero cells are considered as blocking terrain");
opt5->required = NO;
opt5->type = TYPE_STRING;
opt5->gisprompt = "old,cell,raster";
Modified: grass/trunk/raster/r.watershed/front/r.watershed.html
--- grass/trunk/raster/r.watershed/front/r.watershed.html 2009-01-20 07:54:16 UTC (rev 35492)
+++ grass/trunk/raster/r.watershed/front/r.watershed.html 2009-01-20 10:50:15 UTC (rev 35493)
@@ -53,14 +53,18 @@
<dt><em>elevation</em>
-<dd>Input map: Elevation on which entire analysis is based.
+<dd>Input map: Elevation on which entire analysis is based. NULL (nodata)
+cells are ignored, zero and negative values are valid elevation data.
+Gaps in the elevation map that are located within the area of interest
+must be filled beforehand, e.g. with <em>r.fillnulls</em>, to avoid
+distortions.
<dt><em>depression</em>
<dd>Input map: Map layer of actual depressions or sinkholes in the
landscape that are large enough to slow and store surface runoff from
-a storm event. Any non-NULL (not nodata) values indicate depressions.
-Water will flow into depressions, but not out of depressions.
+a storm event. All cells that are not NULL and not zero indicate
+depressions. Water will flow into but not out of depressions.
<dt><em>flow</em>
@@ -81,7 +85,8 @@
<dd>Input map: terrain that will block overland surface flow. Terrain
that will block overland surface flow and restart the slope length
-for the RUSLE. Any non-NULL (not nodata) values indicate blocking terrain.
+for the RUSLE. All cells that are not NULL and not zero indicate blocking
+terrain.
<dt><em>threshold</em>
@@ -166,7 +171,7 @@
<dd>Output map: slope steepness (S) factor for the Universal Soil
Loss Equation (RUSLE). Equations taken from article entitled
<em>Revised Slope Steepness Factor for the Universal Soil
-Loss Equation</em> (McCool et al. 1987). Since the LS factor is a small
+Loss Equation</em> (McCool et al. 1987). Since the S factor is a small
number (usually less than one), the GRASS output map is of type DCELL.
</dd>
</dl>
@@ -290,9 +295,13 @@
to run the program. Masking out unimportant areas can significantly
reduce processing time if the watersheds of interest occupy a small
percentage of the overall area.
<p>
-Zero (0) and negative data values will be treated as elevation data (not no_data).
+Gaps (NULL cells) in the elevation map that are located within the area
+of interest will heavily influence flow accumulation: water will
+flow into but not out of these gaps. These gaps must be filled beforehand,
+e.g. with <em>r.fillnulls</em>.
+<p>
+Zero (0) and negative values will be treated as elevation data (not no_data).
<h4>Further processing of output layers</h4>
<p>
@@ -460,8 +469,10 @@
<a href="g.region.html">g.region</a>,
<a href="r.cost.html">r.cost</a>,
<a href="r.drain.html">r.drain</a>,
+<a href="r.fillnulls.html">r.fillnulls</a>,
<a href="r.flow.html">r.flow</a>,
<!-- <a href="r.flowmd.html">r.flowmd</a>, -->
+<a href="r.mask.html">r.mask</a>,
<a href="r.neighbors.html">r.neighbors</a>,
<a href="r.param.scale.html">r.param.scale</a>,
<a href="r.resamp.interp.html">r.resamp.interp</a>,
Modified: grass/trunk/raster/r.watershed/ram/init_vars.c
--- grass/trunk/raster/r.watershed/ram/init_vars.c 2009-01-20 07:54:16 UTC (rev 35492)
+++ grass/trunk/raster/r.watershed/ram/init_vars.c 2009-01-20 10:50:15 UTC (rev 35493)
@@ -211,7 +211,7 @@
G_get_c_raster_row(fd, buf, r);
for (c = 0; c < ncols; c++) {
asp_value = buf[c];
- if (!G_is_c_null_value(&asp_value))
+ if (!G_is_c_null_value(&asp_value) && asp_value)
asp[SEG_INDEX(asp_seg, r, c)] = 1;
@@ -228,7 +228,7 @@
block_value = buf[c];
- if (!G_is_c_null_value(&block_value))
+ if (!G_is_c_null_value(&block_value) && block_value)
FLAG_SET(swale, r, c);
Modified: grass/trunk/raster/r.watershed/seg/init_vars.c
--- grass/trunk/raster/r.watershed/seg/init_vars.c 2009-01-20 07:54:16 UTC (rev 35492)
+++ grass/trunk/raster/r.watershed/seg/init_vars.c 2009-01-20 10:50:15 UTC (rev 35493)
@@ -241,7 +241,7 @@
asp_value = buf[c];
- if (!G_is_c_null_value(&asp_value)) {
+ if (!G_is_c_null_value(&asp_value) && asp_value) {
cseg_put(&asp, &one, r, c);
else {
@@ -270,7 +270,7 @@
- if (!G_is_c_null_value(&block_value)) {
+ if (!G_is_c_null_value(&block_value) && block_value) {
bseg_put(&swale, &one, r, c);
else {
