[GRASS-SVN] r35509 - grass/branches/develbranch_6/gui/wxpython
svn_grass at osgeo.org
Tue Jan 20 14:48:20 EST 2009
Author: neteler
Date: 2009-01-20 14:48:20 -0500 (Tue, 20 Jan 2009)
New Revision: 35509
grass/branches/develbranch_6/gui/wxpython/README
better explain _gdi_.so stuff
Modified: grass/branches/develbranch_6/gui/wxpython/README
--- grass/branches/develbranch_6/gui/wxpython/README 2009-01-20 19:48:04 UTC (rev 35508)
+++ grass/branches/develbranch_6/gui/wxpython/README 2009-01-20 19:48:20 UTC (rev 35509)
@@ -54,6 +54,7 @@
On Debian GNU/Linux install package:
apt-get install python-opengl
2 - STARTUP WITH GRASS INITIALIZATION
If you want to launch wxPython GUI automatically when you start
@@ -69,6 +70,7 @@
$ grass64 -wxpython
3 - STARTUP FROM GRASS TERMINAL
Simply run
@@ -81,6 +83,7 @@
$ g.gui gui=wxpython workspace=myworkspace.gxw
4 - CLI Display scripts
Note: This section is out-dated!
@@ -128,6 +131,7 @@
displayed. You should be also able to store the display content as well as
clear the display and start from scratch.
5 - DEBUGGING
To enable GUI debug messages on given level set GRASS_DEBUG_WX
@@ -135,6 +139,7 @@
$ export GRASS_WX_DEBUG=3
6 - ICON THEMES
Currently two icon themes are available:
@@ -145,28 +150,40 @@
User can change icon theme in Preferences dialog
('Config->Preferences').
7 - VECTOR DIGITIZER
To enable digitizer you need to compile 'vdigit'
component. Note that you must configure GRASS with C++ (--with-cxx),
Python (--with-python) and wxWidgets (--with-wxwidgets) support.
-NOTE: There is no need to do the following symlink or ldconfig on OSX.
+NOTE: There is no need to do the following symlink or ldconfig on MacOSX.
First, create a symlink to _gdi_.so shared library
-$ sudo ln -s `locate _gdi_.so` /usr/local/lib/libgdi.so
+- find out architecture (32 or 64bit):
+ $ echo "$HOSTTYPE"
-e.g.
+- find the _gdi_.so file and check if compliant:
+ $ locate _gdi_.so
+ $ file /path/to/_gdi_.so
-$ sudo ln -s /usr/lib/python2.4/site-packages/wx-2.8-gtk2-unicode/wx/_gdi_.so /usr/local/lib/libgdi.so
+ It will report "ELF 32-bit..." or "ELF 64-bit..". If you have
+ multiple results with locate, link below the appropriate file.
+- link as library:
+ $ sudo ln -s /path/to/_gdi_.so /usr/local/lib/libgdi.so
+ e.g.
+ $ sudo ln -s /usr/lib64/python2.4/site-packages/wx-2.8-gtk2-unicode/wx/_gdi_.so /usr/local/lib/libgdi.so
Then update LD_LIBRARY_PATH or add '/usr/local/lib' to /etc/ld.so.conf
(in this case run 'sudo ldconfig').
-TODO: Don't use direct linking here.
+TODO grass-dev: Avoid direct linking here, implement a better solution.
Then you can compile the driver
$ cd gui/wxpython/vdigit
$ make
